Baja Designs: LP9 8" LED Auxiliary Light
Discussion in 'Lighting' started by Baja Designs, Aug 31, 2017.
  1. Aug 31, 2017 at 9:51 AM
    Baja Designs
    Baja Designs [OP] The Scientist of Lighting Vendor
    Bill
    San Marcos, CA
    Bailey here with Baja Designs. We are very excited to release the LP9 which is our NEW 8" LED Auxiliary Light. A design that was inspired by Baja Designs’ legendary 8" La Paz HID; The LP9 features modern styling and performance, with some of the most advanced LED technologies available today.
    https://www.bajadesigns.com/products/LP9-LED-Auxiliary-Lights.asp
    The LP9 utilizes 9 forward projecting LEDS to produce 11,025 Lumens at 105 watts, and 6 LEDs for Integrated Peripheral Technology (IPT) which produce 1,140 lumens at 10.5 watts per side. The IPT provides an incredible 200° spread of usable light.
    The housing was designed to provide exceptional heat dispersion by using Direct Ducted Cooling, which allows air to travel from the front of the housing to the rear. With a day-time running light, low, and high power mode, the LP9 will fulfill all your lighting needs.
    Available in a standard model that is perfect for a wide range of off-road use, as well as a Racer Edition configuration that is designed for the demands of high speed driving. The Racer Edition has similar power draw, but produces a much tighter pattern, providing higher visibility at greater distances. Both models feature uService technology, which allows customers to change the lens pattern and color depending on driving conditions, or simply when they want to refresh the lens.
    LP9, LED Spot (sku 320001) - $539.96
    LP9, LED Driving/Combo (sku 320003) - $539.96
    LP9, Racer Edition Spot (sku 330001) - $584.96
    LP9, LED Spot, Amber (sku 320011) - $548.96
    LP9, LED Driving/Combo, Amber (sku 320013) - $548.96
    LP9, Racer Edition Spot, Amber (sku 330011) - $593.96
    Coupon Code: BDForums
    10% OFF + $5 Shipping to the Lower 48!
    Thanks Everyone!
    -Bailey, Baja Designs
    www.bajadesigns.com
  2. Aug 31, 2017 at 11:44 AM
    TheBeast The Beach
    they look mean
    Baja Designs[OP] likes this.
  3. Jan 23, 2018 at 8:58 AM
    Baja Designs
    Bill
    San Marcos, CA
  4. Jan 23, 2018 at 9:14 AM
    TheBeast The Beach
    me me me ! ;)
  5. Jan 23, 2018 at 9:16 AM
    TheBeast The Beach
    can it be mounted as a chase light on the A pilar ?
  6. Jan 23, 2018 at 9:19 AM
    Baja Designs
    Bill
    San Marcos, CA
    @Wikid already beat ya to it!
    Stolen from Don's Facebook. I'm sure more pics will be posted on his Instagram (IG: arcticatundra)
    19554514_1828024090561335_64426196807746_9002a7e7be0a9c7d7d535799fde92a28f1f742f6.jpg
    Flyinryank and dcsleeper408 like this.
  7. Jan 23, 2018 at 9:20 AM
    Baja Designs
    Bill
    San Marcos, CA
    I'm sure with a strong enough bracket anything is possible! You might have a tough time seeing out the windshield when turning :)
  8. Feb 20, 2018 at 12:51 PM
    Baja Designs
    Bill
    San Marcos, CA
    The LP9 just got a little bit BOLDER!
    Introducing a new, more aggressive, cast housing for the LP9. One of the noticeable changes is the larger openings for the Direct Ducted Cooling at the top and bottom of the housing. This will increase airflow to the light and in return keep the light cooler allowing everything to run at peak performance longer. This housing also features a sleek black powder coat finish. Take a look at the website for more pictures and information!
    Post up if you have any questions! Don't forget to save nearly $60 per LP9 with your forum discount. Coupon Code: BDForums
    www.bajadesigns.com
    Flyinryank likes this.
  9. Feb 20, 2018 at 1:02 PM
    TOTU17
    TOTU17 New Member
    Very nice!!! Need some!
  10. Feb 20, 2018 at 1:11 PM
    Flyinryank
    Flyinryank New Member
    Ryan
    Las Vegas, NV
    White 2015 CM 4x4
    Mean! Any idea what bumper he is running your lights on?
  11. Feb 20, 2018 at 1:24 PM
    Baja Designs
    Bill
    San Marcos, CA
  12. Mar 25, 2018 at 7:20 AM
    Baja Designs
    Bill
    San Marcos, CA
    T-Rex266 likes this.
  13. May 1, 2018 at 7:53 AM
    Baja Designs
    Bill
    San Marcos, CA
  14. May 7, 2018 at 7:23 AM
    Baja Designs
    Bill
    San Marcos, CA
    Introducing the LP9 Sport! Available for Pre-Order NOW
    The LP9 Sport is perfect for enthusiasts that want the look and features of our successful LP9, but with a little less output intensity and price. The Sport model still includes all of the technology that makes the LP9 series so popular, from Direct Ducted Cooling - that keeps your light cool under stress - to the Integrated Peripheral Technology (IPT), which produces an incredible 200° spread of usable light. The LP9 Sport utilizes 9 forward projecting LEDS to produce 6,500 Lumens at 61 watts, and 6 LEDs for Integrated Peripheral Technology (IPT) which produce 2,550 lumens at 24 watts.
    AVAILABLE HERE FOR $459.95
    https://www.bajadesigns.com/products/LP9-Sport-LED.asp
    Estimated Ship Date - 5/30
    www.bajadesigns.com
  15. Feb 3, 2019 at 12:08 PM
    ICF2018
    ICF2018 New Member
    I know this is a tundra forum, and sadly have no where to put LP9's on the tundra but here is my review of them anyway.
    Purchased a pair of driving combo white LED LP9's in December 2018. Installed them on a 2015 Kenworth T-800 log truck that travels a ton of back roads with little to no traffic. Depending on the location of the cut block, these lights are used anywhere from 4-8 hours a day, 5 days a week. They have seen temperatures ranging from +10 to -35°C and parked in a +15°C shop overnight and they have had no issues with condensation or water, snow, frost, etc. infiltration even pressure washing them with 4000psi. These lights are no joke, the brightest lights I've ever seen! They shine about 2 km's down the road and about 300 meter's into the ditch/field on either side of the road. I wired them up with 12ga wire and 2 relays in order to utilize a SPDT switch so the switch leg wire can be fused with a 5 amp fuse insread of using a DPDT switch rated to 25 amps with a bigger fuse for a bit better safety factor. The low beam function (IPT and wide driving lights) is awesome in inclement weather as it has a very even, widely dispersed light that limits the amount of scatter vertically which allows it to cut through the snow, sleet and rain extremely well without giving you the glare that the high beam mode gives. On clear nights, the high beam is just incredible! The light is a controlled beam that goes on for what seems to be forever and allows you to safely drive at 65-70mph with great comfort knowing that you can see so far down the road and way into the ditch beside you. Spotting moose, deer and Buffalo have never been so easy. The IPT is awesome and truly does have 200° of usable light as it shine a bit behind the truck even with a bumper slightly obscuring the light in that regard. The fit and finish of the lights, lens, LED placement, use of Deutsch connectors, impecable powder coat finish, stainless hardware and mount are just leaps and bounds better than the competition. These lights are hefty and that just helps solidify that these lights are of the highest quality. I spliced the Amber clearance light function into the existing clearance light circuit and it is just the icing on the cake. It matches in color perfectly and just looks really cool. It's just a nice touch added to these already amazing lights! The 5000k color temperature of these lights are amazing, way less eye fatigue compared to the 6000k to 6500k LED that almost every other driving light or bar on the market is using. The 5000k is just pure white with no hint of blue and works really well in the snow and rain. My light bars on my pickup (42" curved, 30" straight, 4 pods from other manufacturers) do not even come close to the light output of two LP9 pro's. BD lights are on another level compared to everything else out there. Don't be fooled by raw lumens, it's how the manufacturer projects the light that makes all the difference. The price may look high but it is an extraordinary value. After seeing the amount of light that these give off, one LP9 would beat the setup on my pickup and be cheaper too. Thanks BD for putting out what I think is the best light on the market today!
  16. Feb 4, 2019 at 8:38 AM
    Baja Designs
    Bill
    San Marcos, CA
    Incredible setup!
    Glad we can help illuminate your travels. Stay safe out there
    Baja Designs
    www.bajadesigns.com
  17. Feb 10, 2019 at 3:48 PM
    ICF2018
    ICF2018 New Member
    Thanks! Will do.
    For future reference is there an option to make the LP9 driving combo have the top 3 spot optics changed to racer optics? Or would that not benefit it much for distance?
  18. Feb 11, 2019 at 2:53 PM
    Baja Designs
    Bill
    San Marcos, CA
    There isn't an option for just the top 3 optics but you can always upgrade the circuit board to racer edition internals. This will give a nice distance increase
    Baja Designs
    www.bajadesigns.com
  19. Feb 11, 2019 at 3:31 PM
    ICF2018
    ICF2018 New Member
    I assume that, that would be all 9 forward projecting LED's switched to racer edition? Including the ones behind the wide driving lens. Would that change the 42° patrern of those?
  20. Feb 12, 2019 at 11:52 AM
    Baja Designs
    Bill
    San Marcos, CA
    The LP9 Racer Edition is only available in the Spot pattern, you could run a Driving/Combo lens but it's reducing the usable light. Personally, I'd upgrade one light to Racer Edition Spot and leave the other as-is. This will give you a great distance increase while maintaining a lot of near and midfield lighting
    Baja Designs
    www.bajadesigns.com
  21. Feb 12, 2019 at 12:18 PM
    gladecreekwy
    gladecreekwy Wyoming
    J
    Jackson Wyoming
    2014 trd silver tundra
    6" lift, bumper and winch.
    $500+ each? I’ll keep dreaming
