Baja Boss a/t 295 on stock TRD pro
Discussion in 'Wheels & Tires' started by 2k15trd pro, Sep 15, 2025 at 10:36 AM.
  1. Sep 15, 2025 at 10:36 AM
    2k15trd pro
    2k15trd pro [OP] New Member
    Today
    2015 TRD pro
    Hi guys,
    Trying to put a pair of new boots on and need some advice.
    I want baja boss A/T 295 70 r18 on my stock 2015 tundra TRD pro. Not putting a lift on. I know they will be very close to the UCA and I will need to remove the mudflap. From what i can read this is a very large tire and still might not fit.
    ?HAs anyone fit a 195 Baja boss a/t on there stock TRD pro without any modifications other than front mudflap removal? Would i be better off going with the 285?
  2. Sep 15, 2025 at 11:35 AM
    Did you search for the answer, or look at any of the threads on here about this?
  3. Sep 15, 2025 at 11:44 AM
    2k15trd pro
    Today
    2015 TRD pro
    yep.
    There's a ton of threads about it but cant find any that someone specifically put these wheels on a stock TRD pro in this size.
  4. Sep 15, 2025 at 12:41 PM
    cp44
    cp44 New Member
    Aaron
    NoVA
    Tundra TRD Pro
    I have the Baja Boss 285s on stock PRO rims and stock height. Yes, they are larger than normal 285s from other brands. I didn't have to remove any flaps but I can tell you if I go full lock while turning, I can hear a little rubbing on the liner. I can imagine that 295s will require some modifications
