Baja 40' S8 lightbar not staying on.
Discussion in 'Lighting' started by hi_rawb, Jul 12, 2023.
  1. Jul 12, 2023 at 8:09 AM
    hi_rawb
    hi_rawb [OP] New Member
    rob
    Bay Area
    2018 CM TRD SPORT 4x4
    2018 Trd Sport
    So , today not using my Lightbar often, I turned it on and it did not stay on . It would stay on and after a sec and would just turn off. My switchpro would blink twice.
    Any idea whats wrong?
  2. Jul 12, 2023 at 8:13 AM
    reywcms
    reywcms New Member
    Rey
    Beaverton,Oregon
    2017 Tundra Platnium
    Too many mods to come
    Sounds like too much draw or ground issue?
  3. Jul 12, 2023 at 8:25 AM
    hi_rawb
    rob
    Bay Area
    2018 Trd Sport
    Thank you! Will Check it out on my lunch break and also check fuse(s).
  4. Jul 13, 2023 at 4:53 AM
    Did you get it figured out?
  5. Jul 13, 2023 at 6:47 AM
    hi_rawb
    rob
    Bay Area
    2018 Trd Sport
    I did! I got a hold of SDHQ where i got the Lightbar from and this is his response.
    This is a code in which the light bar is drawing more power than the switch is programmed for. To fix this, you will go into the Switch Pros app, go to the settings for each switch, select the switch that is connected to the light bar, then change the Amperage value. A 40" S8 draws 16A, so you can set the value to 20A or anything greater than 16A in the app. This should fix the issue and everything should operate normally after this. Let us know if we can help with anything else!
    Worked perfect!!
    bulldog93 and reywcms like this.
  6. Jul 13, 2023 at 7:00 AM
    Nice! I never knew you could adjust a Switch Pro like that. :thumbsup:
