Bad VVT gears
Discussion in '2nd Gen Tundras (2007-2013)' started by Simpleton, Oct 5, 2024.
  1. Oct 5, 2024 at 5:58 PM
    Simpleton
    Simpleton [OP] New Member
    2012 Tundra 5.7 V8
    Can anyone help confirm if a VVT gear on the intake cam should be locked when the motor is not running? The reason I ask is I’m replacing timing chains and during installation the drivers side cam sprockets I am able to rotate the intake VVT gear freely without the cam moving.
  2. Oct 5, 2024 at 6:07 PM
    snivilous
    snivilous snivspeedshop.com
    SW UT
    300k+ Supercharged 2008
    Someone smarter than me will comment, on my 2JZ I was rebuilding the other day when I took it apart the VVT gear was locked, on reassembly it could spin freely since there was no oil in it. If it's not leaking I wouldn't be worried personally, once it gets oil pressure it will lockup where it wants.
    Mater and FrenchToasty like this.
  3. Oct 7, 2024 at 6:52 AM
    Simpleton
    2012 Tundra 5.7 V8
    Thank you for your expertise! I’m really hoping this is the case as the replacement is $500 and I’m hesitant to put everything back together before I feel 100% about it as it’s a big job.
  4. Oct 9, 2024 at 9:35 PM
    lr172
    lr172 New Member
    07 DC
    If the 5.7 is similar to the 4.0, there is no vvt gear. The cam gear your seeing is attached to a hydraulic actuator and that attaches to the cam. The hydraulic actuator is filled with sealed oil and therefore should not rotate is the actuator seals are good.the actuator has two chamber. The vvt solenoid is a three way and it adds oil to on chamber while releasing oil fro the other to change the offset from the gear to the cam. In order to work, the gear must remain fixed to the cam at all times. It should feel like a solid connection
    in your cas it may have leaked down due to sitting for a while or you did something like removing a vvt solenoid, to release the oil. As long as the chains are installed according to fsm, this will all address itself on startup
    Mater likes this.
