Bad vibration
Discussion in '1st Gen Tundras (2000-2006)' started by 05newb, Mar 13, 2018.
  1. Mar 13, 2018 at 12:04 PM
    05newb
    05newb [OP] New Member
    '05 SR5 Access Cab-2wd-4.0L
    K&N intake, Removed badges
    This started a few weeks ago and has caused my stress and anxiety to go through the roof every time I drive now. From 45 mph To 60 mph my truck makes a deep strong rumble/vibration noise. When I let off the throttle it completely goes away, it is only under power. I just had my tires balanced and rotated. I’m wanting to say it’s in the transmission or driveshaft, or rear end. A key factor is this: the RPMs do not change the vibration sound, only change in speed. I’ve checked the driveshaft, and it only has a small amount of play. There is a rubber piece in the middle of the driveshaft where the small amount of play is at. It doesn’t matter if it’s in third fourth or overdrive, the vibration is the same so maybe that eliminates transmission? When I downshift, I get a quick hi pitched squeak noise like something is slipping at first, I don’t know. Any ideas are greatly appreciated, I am at a loss.
  2. Mar 13, 2018 at 12:10 PM
    15whtrd
    15whtrd Mr. Blonde
    Your driveshaft will always be spinning the same speed when you are in the miles per hour you were talking about. Regardless of what gear it is in. I would definitely look closer at that carrier bearing. Might be a good time to think about those U joints too. Make sure no weights are missing on the driveshaft. It could be out of balance.
  3. Mar 13, 2018 at 12:11 PM
    blizz86
    blizz86 New Member
    Could be the U joints? imbalance in driveshaft is a possibility as well
  4. Mar 13, 2018 at 12:15 PM
    05newb
    I did not even know the driveshaft had to be balanced. I will look into that, and can you elaborate more on what a carrier bearing is?
  5. Mar 13, 2018 at 12:16 PM
    15whtrd
    15whtrd Mr. Blonde
    It’s that center here rubber piece you were talking about. You have a two piece driveshaft correct?
  6. Mar 13, 2018 at 12:38 PM
    05newb
    Correct I do, I just did a quick YouTube search and understand it now. Should there be any movement whatsoever in that carrier bearing? I can push on it real hard and move the driveshaft, it but it does not have much play otherwise.
  7. Mar 13, 2018 at 12:40 PM
    15whtrd
    15whtrd Mr. Blonde
    Hopefully someone else will chime in with a little more experience on these carrier bearings. But I don’t think you should be able to move it much. Imagine the torque that is being put on it when under load. How many miles do you have on the truck?
  8. Mar 13, 2018 at 12:41 PM
    05newb
    125,000 miles.
  9. Mar 13, 2018 at 12:43 PM
    15whtrd
    15whtrd Mr. Blonde
    I realize you said you had the tires rotated. Maybe try moving them around again. Try the rears on the front and see if the problem goes away.
    Edit: Take it back to them and have them swap them around for you. Tell them you think the tires may be still out of balance. And you would like them swapped temporarily to confirm if it is the tires or your truck.
  10. Mar 13, 2018 at 1:41 PM
    05newb
    Well, it was doing this before I had them rotated and balanced and I was hoping that would take care of the problem but it didn’t change anything.
    15whtrd[QUOTED] likes this.
  11. Mar 13, 2018 at 1:44 PM
    15whtrd
    15whtrd Mr. Blonde
    I want to say my best guess is still the carrier bearing. I’m not 100% to be honest. I have not experienced this exact dilemma on any of my vehicles. But I know they go out. My friend had something similar going on on his Dakota. I know it’s not a Toyota but it does have a center carrier bearing. We replaced it and it cured it.
  12. Mar 13, 2018 at 1:50 PM
    nk1794
    nk1794 Always torque to spec
    San Jose, CA
    Can you provide any sound clips? I'm curious to know what this is.
    15whtrd likes this.
  13. Mar 13, 2018 at 2:00 PM
    05newb
    I have recorded a few clips. Tonight I will try to upload them on YouTube and provide the link. It’s difficult to hear, mainly just hear my dash rattling from vibration.
    nk1794[QUOTED] likes this.
  14. Mar 13, 2018 at 2:03 PM
    15whtrd
    15whtrd Mr. Blonde
    If it’s not raining when I get home I’ll check my 2wd 03 Sequoia. I’m not sure if they share the same driveshaft but I’m pretty sure it has a carrier bearing. I’ll check for slop. That thing is smooth as butter to drive.
  15. Mar 13, 2018 at 2:05 PM
    05newb
    Thanks! When I push on my driveshaft it’s just a small but difficult budge.
  16. Mar 13, 2018 at 2:30 PM
    nk1794
    San Jose, CA
    See if this is helpful.
    15whtrd likes this.
  17. Mar 13, 2018 at 2:46 PM
    15whtrd
    15whtrd Mr. Blonde
    Do the U joints on these need to be pressed in and out or are they replaceable by hand?
  18. Mar 13, 2018 at 3:05 PM
    nk1794
    San Jose, CA
  19. Mar 13, 2018 at 3:26 PM
    nk1794
    San Jose, CA
  20. Mar 13, 2018 at 3:29 PM
    15whtrd
    15whtrd Mr. Blonde
    I was going to check but the minute I got home it started dumping rain.
  21. Mar 13, 2018 at 3:33 PM
    nk1794
    San Jose, CA
  22. Mar 13, 2018 at 4:20 PM
    05newb
    driverdog, 15whtrd and nk1794[QUOTED] like this.
  23. Mar 13, 2018 at 4:21 PM
    nk1794
    San Jose, CA
    :yes::cheers:
    15whtrd likes this.
  24. Mar 13, 2018 at 4:32 PM
    05newb
    We will see if it fixes mine. Hopefully I can figure out how to get it all apart and back together
  25. Mar 13, 2018 at 4:44 PM
    nk1794
    San Jose, CA
    Good luck. Let us know how it goes.
    15whtrd and 05newb[QUOTED][OP] like this.
  26. Mar 17, 2018 at 1:20 PM
    05newb
    Truck is fixed. It was this U joint gone bad that caused all my issues. I dropped the driveshaft thinking I would be replacing the carrier bearing, but when I inspected the u joints I knew what the real problem was. I never changed anything else besides this joint. Thanks for all the help guys. Last night I did the rotors and brakes, and today this. It has never driven so smooth! image.jpg
    nk1794, 15whtrd and driverdog like this.
  27. Mar 17, 2018 at 3:07 PM
    15whtrd
    15whtrd Mr. Blonde
    I meant to update this for you. I checked my Sequoia and it has no carrier bearing. I have a one piece driveshaft so I would’ve been no help.
    nk1794 likes this.
  28. Mar 17, 2018 at 3:10 PM
    nk1794
    San Jose, CA
    I think he found the culprit.
  29. Mar 17, 2018 at 3:29 PM
    15whtrd
    15whtrd Mr. Blonde
    Yeah your post is what reminded me. Sorry I didn’t follow through man. Glad you found it!
  30. Mar 17, 2018 at 3:32 PM
    nk1794
    San Jose, CA
    :cheers:
