Bad rear wheel bearings maybe?
Discussion in '2nd Gen Tundras (2007-2013)' started by Hogfandan24, Sep 14, 2024.
  1. Sep 14, 2024 at 12:50 PM
    Hogfandan24
    Hogfandan24 [OP] New Member
    2014 cm tss
    Can a bad wheel bearing set off the traction control? Had a broken connection in the wheel speed circuit. Replaced the rear harness and all the Christmas lights went away. But have had traction control limit acceleration twice when turning. When breaking lightly there is a nice shimmy of feedback in the steering wheel.
  2. Nov 17, 2024 at 5:14 PM
    TomsTundra
    TomsTundra New Member
    2011 DC 4.6L AT 4WD SR5
    My tundra will flash traction control light when inside wheel slips in the wet on hard turns under acceleration. The shimmy is probably more related to front brake issues. I had a light shimmy when braking that went away after replacing just the pads. My rotors indicated less than .002 tir, at least in the couple areas i tested them on.
