Bad oil pressure sensor, or . . .?
Discussion in '2nd Gen Tundras (2007-2013)' started by apwisher, Nov 20, 2022.
  1. Nov 20, 2022 at 7:42 AM
    apwisher
    apwisher [OP] New Member
    Everett, WA
    2007 CM SR5/TRD 4x4 White
    canopy, TRD Sway, audio
    Greetings.
    a couple of days ago after a cold start (and confirmed again yesterday) the oil light on my dash illuminated after the engine warmed up. I checked the oil it was full, there are no unusual sounds from the engine, and everything seems normal. I checked the computer and there are no active or pending codes. The pressure gauge on the dash goes to about 3/4 when it cold started, and once the engine is warm it is right in the middle, no change there either. how often would the sensor go bad, and if so wouldn't i expect it to affect the gauge? I may just load the parts cannon and replace it, but I need to figure out where it lives and wanted to see if you folks have any other ideas.
    Thanks.
  2. Nov 24, 2022 at 10:52 PM
    blackdemon_tt
    blackdemon_tt Battery Slayer
    It may be the oil sender unit that may be going out, and that would reside next to the oil filter.... There is a youtube channel, I do cars who breaks down blown engines. I believe he has 2 5.7L vids up and can instruct where some parts are and how to remove them
    Edit: vid
    https://youtu.be/l_1zeSsoOK0
    baraynavab likes this.
  3. Dec 12, 2022 at 9:29 AM
    apwisher
    Everett, WA
    Just to close this one out... The new pressure sensor fixed it.
    hagrid likes this.
