Bad info
Discussion in 'New Member Introductions' started by MikeyO, Feb 16, 2020.
  1. Feb 16, 2020 at 10:44 AM
    MikeyO
    MikeyO [OP] New Member
    Tundra
    Love my truck, I feel like the service department has lied to me. They say that the oil is good for 10000 miles. I have 18000 now I’ve had 2 oil changes and my oil seem dirty after service. They also told me I don’t have to change my transmission fluid ever. I disagree with everything. I think Toyota wants me to ware out my truck so I’ll buy another one. Whatever.
    Prostar 190 likes this.
  2. Feb 16, 2020 at 10:46 AM
    teedubbya
    teedubbya I like fat booty
    Austin TX
    2019 trd pro voodoo 4runner
    Hahahahahahahaha
  3. Feb 16, 2020 at 10:48 AM
    teedubbya
    Austin TX
    First of all, some newer tundras are spec’d for 10k oil change intervals.
    the transmission fluid...well, he’s not necessary wrong. You could probably run the truck into the ground without ever changing the transmission fluid, but it is recommended to change it around 100k miles.
    also, why would they want your truck to break? If my truck broke, I don’t think I’d buy another one.
  4. Feb 16, 2020 at 10:49 AM
    TheBeast The Beach
    my 18 camry first oil change was 10K and 5K after so this is the new trend.
    MikeyO[OP] likes this.
  5. Feb 16, 2020 at 10:53 AM
    TXMiamiFan
    Jose
    2016 White Crew Max TRD
    Welcome from Colorado
    ColoradoTJ and MikeyO[OP] like this.
  6. Feb 16, 2020 at 12:33 PM
    Pinay
    Pinay New Member
    Monet
    Mahal kita Kuya
    Yeah well glad to have you on the forum!! Welcome!b
    1lowlife, MikeyO[OP] and Medic343 like this.
  7. Feb 16, 2020 at 1:04 PM
    ChrisTRDPro
    ChrisTRDPro New Member
    MT
    2017 Tundra TRD Pro CM
    There are many labs you can send an oil sample to that will do an analysis for you and tell you how much life is left. I change mine every 7-8k, but have run to 10k and was told I could easily push that out to 15k. The synthetic oils nowadays are very good.
  8. Feb 16, 2020 at 1:08 PM
    JLS in WA
    JLS in WA New Member
    2008 White DC Limited 4x4
    Drahthaar Transport Unit
    This. No need to wonder. I plan on using synthetic oil, a TRD pro filter (or equivalent) and send in a sample at 8k miles. Just because oil is dirty looking doesn’t mean it’s no good and not doing it’s job. Coloration does not tell you the story, unless it’s signs of moisture, coolant, fuels, etc.
    MikeyO[OP] and Bob_Wiley like this.
  9. Feb 16, 2020 at 2:06 PM
    CMB
    CMB New Member
    Cecil County MD.
    2010 Tundra DC 4X4 SR5
    Not nearly enough room here!
    You're probably right, the people I know who run out and buy the same brand that fails are "big 3" owners......over and over again!:notsure:
  10. Feb 16, 2020 at 3:04 PM
    Welcome from NY.
    Maybe they didn't change the oil filter and that's why it's dirty.
    Some mechanics don't like removing the skid plate. My first oil change they didn't! Then it was all changed again with a filter and fresh oil.
    NewImprovedRon and MikeyO[OP] like this.
  11. Feb 16, 2020 at 4:02 PM
    Welcome from TEXAS
  12. Feb 16, 2020 at 4:48 PM
    Sas
    Sas Humor is everywhere
    OKC, OK
    '17 SR5 CM TSS 4WD MGM 5.7 FF
    Lost track after #1.
    RTFM.
  13. Feb 16, 2020 at 4:49 PM
    Welcome from Ohio.
  14. Feb 17, 2020 at 4:49 AM
    MikeyO
    Tundra
    I was thinking they may not have changed the filter too. 10 k seems to me to be too long, I wrenched on automobiles for years, it was always 3k on oil. Now it’s 5 to 6. And Toyota says 10. Oils have come a long way. However I’m gonna do it a little sooner. Thanks for all the reply’s. Great truck a real 4x4 , got some mountain pin striping already. Really handles the off road and hills with no problem. I have a 2019 limited T R D I’m in love with him.
  15. Feb 17, 2020 at 5:41 AM
    Cthulhu
    @MikeyO another thing to consider is whether or not your truck is FFV. If not FFV, maintenance schedule recommends every 10,000. If FFV, it recommends every 5,000. A LOT of dealerships don't know that FFV has a 5,000 mi interval. Mine didn't. I had to "teach" them.
    1lowlife and ZPMAN like this.
  16. Feb 18, 2020 at 6:23 PM
    MikeyO
    Tundra
    Yeah, my truck is regular unleaded gas. They told me about some vehicles having a different kind of fuel needing sooner oil changes.
  17. Feb 18, 2020 at 6:38 PM
    15whtrd
    15whtrd Mr. Blonde
    Flex fuel.
    welcome from SoCal!
    NewImprovedRon likes this.
  18. Feb 18, 2020 at 7:00 PM
    WNY PAT
    WNY PAT New Member
    Oops. Double post.
  19. Feb 18, 2020 at 7:09 PM
    WNY PAT
    WNY PAT New Member
    Welcome! I wouldn’t worry about the oil changes. If you want to know whether it needs more frequent changes, change it out at 7500 miles the first time and send the sample to Blackstone for an analysis. The famous million mile Tundra (oil field delivery vehicle) followed the 10K interval and used only Toyota oil and filters and the engine internals were still great when the engineers took the motor apart and inspected the components.
  20. Feb 18, 2020 at 7:14 PM
    abomb60
    abomb60 Maker of things
    Massachusetts
    2018 Tundra 1794 MGM
    I change mine every 6 to 8 months. Honestly I drive so little it would be 3 years before I hit 15,000 miles so I do it based on time not mileage. After the next oil change I’ll probably send a sample off just for giggles and curiosity.
    NewImprovedRon and WNY PAT like this.
  21. Feb 18, 2020 at 7:27 PM
    Suprafantx
    Suprafantx New Member
    2020 4X4 White Tundra TSS
    I like the way you try to have your truck services more than it needed. I am sure your truck will hit 300k-400k miles easily. I used to use mobil1 synthetic extended life which is good for 15,000 miles and I changed out the oil every 10,000 miles. Recently, I am using mobil1 ultimate full synthetic which is good for 1 year or 20,000 miles and I do oil change every 15,000 miles. All my vehicles never had any problems with the oil, few of them are over 200,000 miles and I sell them but engines are still running like new. If your dealer are is using synthetic oil, you only need to change the oil every 10,000 miles. I still remember I used do oil change every 3,000 miles.
  22. Feb 18, 2020 at 9:09 PM
    WNY PAT
    WNY PAT New Member
    Our 4 runner only gets driven about 6,000ish miles a year. The dealer recommended (and the manual confirms) to change it out at 12 months. I’ve been following that schedule. Will be interested to see your analysis. I never think much about it - but it’ll be reassuring to see yours come back fine.
  23. Feb 18, 2020 at 10:28 PM
    ChrisTRDPro
    MT
    Time does almost nothing to new synthetic oils, it's all about mileage/run time. I do less than 1k miles in one of my vehicles and I sent oil samples at 1 and 2 year increments and am now doing 3 year oil changes because that's when I hit the 3,000 mile oil change interval.
    WNY PAT likes this.
  24. Feb 18, 2020 at 11:41 PM
    Open owner’s manual, follow maintenance schedule.
    Would I do 10k mike interval? No. Maybe 7500...and that would only if it was all highway, no towing.
    For the transmission, we do have a member with 400k miles and never serviced the transmission. I would say he is the exception, not the rule.
    NewImprovedRon, WNY PAT and GODZILLA like this.
  25. Feb 19, 2020 at 12:02 AM
    Viking
    Viking New Member
    Jerry
    2007 metalic brown double cab Tundra
    I believe the biggest problem with not putting a lot of miles on a vehicle is the runs that are too short to bring the engine up to full heat, short cold runs will allow crankcase gasses to become acidic and I've seen crankshafts were the journals were gray from bearing deposits on them, kind of like electro plating. I always strive to get the engine up to running temps even if I travel just a short distance.
    GODZILLA likes this.
  26. Feb 19, 2020 at 1:50 AM
    SprinterAE86
    SprinterAE86 New Member
    Ian
    Charlottetown, PE, Canada
    2012 Toyota Sequoia Platinum
    I changed my oil at 1.5k after breaking it in. I have free oil charges up to 24k. I am going tol still do 5k intervals. Fill and drain alternating dealer oil change.
    I have a top sider oil extractor, I do not have to crawl under the truck to drain the oil. I'll let the dealer take care of the oil filter replacement.
    My transmission on my 05 was the first gen without a dip stick. They did say it does not have to be serviced. I only tapped it off when I developed a leak at the rear seal due to center carrier bearing failure after 200k if I remember correctly. I had 255/265k when I traded it in.
  27. Feb 19, 2020 at 4:45 AM
    RitcheyRch
    RitcheyRch New Member
    Richard
    Star, Idaho
    TRD Lowered and Supercharged
    welcome from So Cal
