Bad bulbs on 2016
Discussion in '2.5 Gen Tundras (2014-2021)' started by Cv2016tundra, Dec 2, 2018.
  1. Dec 2, 2018 at 8:45 PM
    Cv2016tundra
    Cv2016tundra [OP] New Member
    Cory
    2016 crew max 4x4 tx edition
    Stock
    Got a 2016 tundra crewmax 4x4 with 50k miles on it about 3weeks ago. Noticed at dealership fog light was out but they fixed it before we left. Days later I changed a burnt license plate light. Few more days later I had to change the driver side head light. (Low beam element burnt). Once I had the grill off and head lights out, I noticed my side markers had lights in them but burnt bulbs. So after all is said and done, I’m 5 burnt bulbs on a two year old truck. All are fine now but only been it about a week. Is this typical for tundras or Toyota? I have a 7 year old truck sitting next to it in driveway I haven’t change a single bulb on. Thanks for the help!
  2. Dec 2, 2018 at 9:08 PM
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
    Not typical in my experiences, no. I would suggest having the battery load tested, ensure that the battery terminals are clean of any corrosion, and are tight, including the body ground cable. Also, the alternator output should be checked to make sure the charging voltage is not exceeding 14.5V. All these items I mentioned can cause poor bulb life, and are easy to check or have checked.
  3. Dec 2, 2018 at 9:09 PM
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    My ‘16 has 46k miles and I’ve only had the driver’s side taillight go out.
  4. Dec 2, 2018 at 9:35 PM
    gosolo
    Ray (or maybe Dale)
    NW Oregon
    Welcome aboard from Oregon! Let’s see some pictures of this truck.
    :worthless:
    As for the problems you are experiencing with the lamps, I would expect they’re not OEM equipment. Lots of people replace the lamps and lots of people have problems that follow. Some replacements are good but not all of them.
