Backup Sensor Problem
Discussion in '2nd Gen Tundras (2007-2013)' started by skrisa, Sep 21, 2021.
  1. Sep 21, 2021 at 7:04 AM
    skrisa
    skrisa [OP] New Member
    07 tundra
    Ive replaced all 4 of my sensors on my 07 Tundra bumper and they still dont work. What else could be wrong. Do i need to reset them?
  2. Sep 21, 2021 at 7:25 AM
    frichco228
    frichco228 Valued Member
    2016 Crewmax 4WD, TRD Offroad
    Is the switch for the BSM turned on? Could be a bad switch, break in the wiring somewhere or a fuse could be blown.
  3. Sep 21, 2021 at 9:35 AM
    skrisa
    07 tundra
    Thanks for your reply. There is no BSM switch in my truck . The bumper sensor switch is turned on. The front sensors work . Ive checked the wiring and all looks good.
  4. Sep 21, 2021 at 10:32 AM
    audiowize
    audiowize New Member
    Paul B.
    2008 Tundra SR-5 4x4 5.7
    Do your reverse lights come on when the truck is in reverse? How about the "R" on the dash?
  5. Sep 21, 2021 at 2:16 PM
    skrisa
    07 tundra
    Yes the reverse lights come on and so does the R light up on the dash when i put the truck i reverse.
  6. Sep 21, 2021 at 2:17 PM
    audiowize
    Paul B.
    I would follow the wiring harness from the rear sensors to where the plug to the harness that's along the frame. I would unplug that connection and check for corrosion.
  7. Sep 21, 2021 at 2:19 PM
    skrisa
    07 tundra
    I will check that Thanks
  8. Sep 22, 2021 at 12:19 PM
    skrisa
    07 tundra
    Thanks for your reply audiowize. Yes i checked the plugin and no corrosion. I followed the wiring to the engine compartment where the wiring ends into a small black box beside the air filter black box. I unplugged each connection and found no corrosion.I checked the fuse box under the hood and nothing is marked Backup sensors. I also checked the inside fusebox and there is a 10amp fuse marked Bkup Lt the fuse was ok. What Next?
  9. Sep 22, 2021 at 12:27 PM
    Saltyhero13
    Saltyhero13 Throbbing Member
    Are they not activating at all or just not detecting? If its the later you can try and rotate the sensors 90 degrees. In your case I would rotate one at a time before testing.
  10. Sep 22, 2021 at 6:38 PM
    NueveTundra
    NueveTundra Mod list in Bio
    Planet Earth
    07, Black Tundra SR5 CrewMax
    Is there power at pig tails for sensors?
  11. Sep 23, 2021 at 10:55 AM
    skrisa
    07 tundra
    Thanks for the reply. No there is no power to the pigtails for the sensors. No they r not activating or detecting and no the can't be turned 90 degrees because the wiring is not long enough and the retainer clips have a groove in them that fits into the bumper.So if u force to turn them they will break.I went to the Toyota dealer and they said the sensors need to be programmed into the computer. I've made an appointment and I will be back on This forum when i get my truck back from the dealer to tell u what they did. Thanks again to every body for your help.
    Saltyhero13 and NueveTundra like this.
  12. Sep 28, 2021 at 6:16 AM
    skrisa
    07 tundra
    Well I got my truck back from the dealer and they couldn't fix the problem but suggested maybe change the clearance sonar ecu $365.00 plus labor. If that doesn't work maybe change the sensors. $1342.00 plus labor. I ordered the ecu and I will change it myself. I will get back here when i change the ecu. Thanks
  13. Sep 28, 2021 at 1:18 PM
    audiowize
    Paul B.
    I think one of your problems is the dealer.
    Tundratoofun likes this.
  14. Sep 28, 2021 at 7:24 PM
    skrisa
    07 tundra
    yes i agree
  15. Oct 2, 2021 at 12:58 PM
    skrisa
    07 tundra
    well I changed the computer assembly module #89340-34010 and no change. my problem is when i put the shifter in reverse the 3 bottom lights on the dash blink 5 times and they stay on. im confused what else could be the problem?
