Backup camera install question
Discussion in '2nd Gen Tundras (2007-2013)' started by mikej, Feb 25, 2024.
  1. Feb 25, 2024 at 11:23 AM
    mikej
    mikej [OP] New Member
    Hi, I have a 2011 Tundra double cab and want to install a backup camera. I bought this one off of Amazon. My question is does anyone know if these are hookups for easy install under the car?
    I have a really shaky video and to screenshots from that video.
    Here is the type of backup camera...https://www.amazon.com/dp/B07WR9C3M4?ref=ppx_yo2ov_dt_b_product_details
    Here is the shaky video https://youtu.be/o8Qal36TiXQ
    Here are the snips from the video
  2. Feb 26, 2024 at 8:50 AM
    Twest130
    Twest130 New Member
    Travis
    2000 sr5
    I think that is wiring for a camera, the issue is aftermarket cameras typically require 12 volts and OEM is something like 7 volts. Found this out the hard way. Ran a dedicated power supply and it works great.
  3. Feb 26, 2024 at 10:18 AM
    mikej
    Well thats annoying...thanks for the reply!
  4. Feb 28, 2024 at 6:38 PM
    mtucker
    mtucker New Member
    Escondido CA.
    2008 Double Cab
    Listed in my build thread
    The easiest way to get power to your backup camera is to connect to either hot wire on your reverse lights. When you go into reverse, the camera gets power from the backup lights. You still need to run the wire harness (I have the same tailgate handle) up to your radio to plug it into your head unit (aftermarket). There was a large bundle of factory wires running along the driver's side of the frame so I zip tied the camera wires every foot or so and then came up into the cab in the passenger side foot well. There is a large rubber grommet there.
    PhotoNerd likes this.
