Backup camera disaster
Discussion in '2nd Gen Tundras (2007-2013)' started by superbond, Apr 20, 2020.
  1. Apr 20, 2020 at 8:32 AM
    superbond
    superbond [OP] New Member
    Hello everyone
    I just had the worse day yesterday!
    I was going to replace my backup camera as the old one had a bad picture.
    I took the tail get apart replaced the camera with a aftermarket one. Put the truck in revers to see if it worked. It work fine!
    Put the tailgate back together but my box has a box liner that is a rug. Don’t ask it came with the truck. It is nice! Well the Velcro that would be on the tailgate up along the top of the inside of the tailgate was coming off. So I had some 2” Velcro and Decided To replace it. Well I ripped it off and wiped off the residual glue that was left behind. It was cold out so I wanted to warm up the paint so the Velcro would stick. Here’s where my day just got worse!
    As I was heating up the tailgate With a propane torch and attached the Velcro
    Well the under coating and cleaner I used to clean off the old glue caught on fire. By the time I opened the tailgate and got a pail of water. All the wiring and new camera were melted. The wiring was melted all through the tailgate right up to where it comes from the tailgate to the box!
    Really!!!!!
    I need help fro any of you good people in an information on where I can get a new wire harness that leads to and in the tailgate. Preferably at a budget price. Does the wire harness break somewhere close to the tailgate so the harness isn’t so long as to go all the way to my stereo
  2. Apr 20, 2020 at 8:45 AM
    Danimal86
    Daniel
    Sacramento, CA
    2017 White Tundra SR5
    dang, would you happen to have any security camera footage of said incident? jk
    How badly melted is the wiring? If the plugs aren't melted, you could just cut the old and put new wires in its place.
    shellshock likes this.
  3. Apr 20, 2020 at 8:49 AM
    ninjajay
    Spoolston, TX
    2018 MGM 1794 TRD 4x4
    Wire is wire, you could just cut the melted part off and replace it with new wiring?
    rons23 and 15whtrd like this.
  4. Apr 20, 2020 at 9:18 AM
    Dr_Al
    Dr_Al New Member
    Al
    Adding a picture so we cans see what you have to deal with would help.
  5. Apr 20, 2020 at 9:42 AM
    Mater
    Mater New Member
    Nick
    SD
    2016 MGM Platinum
    There is a connector just on the underside of the truck bed. Lay on your back and slide in so you can see the back of the rear bumper and you should see the connector. The connector is there so people can completely remove the tailgate if they need to. I'd go on car-part/ebay/call wrecking yards and I'm sure you can find a new cable.
    Jbehredt and Boerseun like this.
  6. Apr 20, 2020 at 9:50 AM
    Make your own wiring harness.
    Why didn't you use a hair dryer?
    TRDFerguson, rons23, Pudge and 2 others like this.
  7. Apr 20, 2020 at 10:21 AM
    TheBeast The Beach
    it is most likely video wiring so it has shielding so it'a bit more complicated than just a + and ground.
    OP: see if you piggy back to a plug that is not damaged and just change with new harness. or just run new wires all the way. it really depends where you burnt it.
  8. Apr 20, 2020 at 10:52 AM
    Pudge
    CT
    2015 Blue Ribbon Platinum
    I need to see pics, video of the blaze preferred
    Mater, Jim LE 1301 and TheBeast like this.
  9. Apr 20, 2020 at 10:55 AM
    JLS in WA
    JLS in WA New Member
    2008 White DC Limited 4x4
    Drahthaar Transport Unit
  10. Apr 20, 2020 at 11:34 AM
    superbond
    Lol I wish I had a video!
    Didothat...... thank you! That is the answer I’ve been looking for.
    I have not had time to look under the truck but was hoping the would be a connection close to the tailgate.
    As for the hair dryer! I had a heat gun that pissed me off and I threw it across the garage about a week ago and never replaced it. The only hair dry I have is my 17 yr olds and well I don’t have to answer that! Lol
    Does anyone know where I can buy good used parts in your area. I leave in a small town in the middle of nowhere. Nothing here
  11. Apr 20, 2020 at 11:39 AM
    superbond
    That heat you sent me a link to looks like the same one I threw against the wall! Lol!
    No more cheap shit for me
  12. Apr 20, 2020 at 11:41 AM
    ninjajay
    Spoolston, TX
    Most backup cameras I’ve installed use RCA cable which can be spliced
  13. Apr 20, 2020 at 11:47 AM
    Mater
    Mater New Member
    Nick
    SD
    2016 MGM Platinum
    I would go to car-part.com and put in the: make, model, year of your truck, and backup camera. This will give you a listing of backup cameras, but you can call each scrap yard and explain to them the part you need and how it’s not the camera but the cable that attaches to the camera. They can then go to the yard and pull it for you/ship it. At least that is what I would do.
  14. Apr 20, 2020 at 11:49 AM
    DJFaninTN
    DJFaninTN New Member
    Panama City Beach, FL
    2018 Super White 1794
    welcome to the Dumbass Men's Club! I am not only a member but have been president once or twice.
    in all seriousness I hate that happened and I am sure someone here will have a great answer for you.
    TechWrench likes this.
  15. Apr 20, 2020 at 1:17 PM
    superbond
    Lol
    Yes you’ve all have given me good advice and I thank you all.
  16. Apr 20, 2020 at 1:20 PM
    Muddog
    Muddog New Member
    Bay Area California
    Kings front and Rear BMC Sliders 17s on toyo 35s
    :worthless:
    Tundra2 likes this.
  17. Apr 20, 2020 at 1:24 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    I 2nd this motion.
  18. Apr 23, 2020 at 3:57 AM
    superbond
    I need a new camera Anyways so I’ll try and find the tailgate harness. Dose anyone know if the harness plugs are all the same? If the plug for the camera and the harness in the tailgate is the same as the one under the box by the license plate then maybe the new camera I bought ( that burnt) my work because it had an extra at least 2 feet or more cable. Which I thought was weird
