Backing a trailer help
Discussion in '3rd Gen Tundras (2022+)' started by chastings1954, Jan 11, 2023.
  1. Jan 11, 2023 at 7:54 AM
    chastings1954
    chastings1954 [OP] New Member
    charles
    capstone
    New truck. Tried to do the caliberate trailer here in the country and it failed. Small 10ft. enclosed trailer I need to pull tomorrow and I can't back without the truck slamming on the brakes. Tried with the trailer switch on and off. How do I turn off the backing up slamming to a stop until I get a chance to do the caliberate in a big lot? Scared the crap out of me the first time it stopped.
    Thanks in advance.
    RickyBobbysTundra likes this.
  2. Jan 11, 2023 at 7:56 AM
    jcneng
    jcneng Retired
    2023 1794 Off Road Crewmax MGM
    Try turning off the radar sensors, switch on the left side of steering wheel. The button with the picture of a traffic cone on it
  3. Jan 11, 2023 at 11:54 AM
    Fr0zenTundra
    Fr0zenTundra New Member
    Wi
    '22 platinum hybrid
    Took me 3 or 4 attempts to get my trailer calibrated. It was very sensitive to speed (stay under 10mph, I ended up around 5mph when it finally worked), how sharp I was turning (get to wheel lock ASAP) and how quickly I straightened out the wheel after the turn (ASAP).
  4. Jan 11, 2023 at 1:13 PM
    RVer
    RVer New Member
    2023 Platinum CrewMax
    Does it work any better if you enter the length of the trailer into the trailer configuration rather than using the calibration method?
    MaxPower likes this.
  5. Jan 11, 2023 at 1:56 PM
    chastings1954
    charles
    capstone
    Thanks. I hit that button and it still stopped. Must have double tapped it. Worked fine when i saw the dash indicator light on.
  6. Jan 11, 2023 at 4:22 PM
    Fr0zenTundra
    Wi
    '22 platinum hybrid
    i manually entered the information about the trailer but still needed to calibrate it and set the gain on the trailer brakes.
    RVer[QUOTED] likes this.
  7. Jan 11, 2023 at 4:42 PM
    TundraMcGov.
    Jofus
    Burpinham, Babalama
    2015 MGM Limited 2x4 Sequoia
    WOW. All that to back up a trailer. At one time in this nation's history successfully backing up a trailer using just your mirrors got ya the girl.
  8. Jan 11, 2023 at 4:54 PM
    Paul Moll
    Paul Moll New Member
    Paul
    Idaho
    2023 1794 TRD off-road
    when you enter trailer dimensions is it tongue to axle or tongue to rear? ie total length.
  9. Jan 11, 2023 at 6:26 PM
    Fr0zenTundra
    Wi
    '22 platinum hybrid
    i went with the total length
  10. Jan 11, 2023 at 6:41 PM
    easleycrawler
    Travis
    Easley, South Carolina
    17 Tundra SR5 DC Black 5.7
  11. Jan 11, 2023 at 8:25 PM
    ArmygreenTRD
    ArmygreenTRD New Member
    2022 Army Green TRD, SR5 DC
    True. And at one time in our nation’s history we got mail from a guy riding a pony!
  12. Jan 12, 2023 at 6:39 AM
    porterbc
    porterbc New Member
    Brandon
    2022 Tundra Crewmax Limited TRD OFF-ROAD
    Stupid question… was the trailer still plugged into the truck.. if not it will slam brakes on.
  13. Jan 12, 2023 at 6:54 AM
    21CGtundra
    21CGtundra New Member
    Robbie
    SLC, UT
    2022 Midnight Black Tundra SR5
    2" front level, 1" Cornfed rear spacer, Rally Armor flaps, Method Con-6 wheels, 285/75 Duratrac
    This happens with my pontoon boat also. The only way I've found to stop it is to turn off every sensor you can in the in-dash menu. It is the most obnoxious thing ever! Then you have to put it in park and back to drive and can't back up with the door open to see better. Way to much shitty safety features in this one.
  14. Jan 12, 2023 at 8:40 AM
    chastings1954
    charles
    capstone
    It was plugged. This light trailer has no brakes so......
    I did get it caliberated this AM. Can't say the backup thing is much help for me.
    Trailer load of guns going to a gunshow. Emtpy on return I hope!
    wing-2 and Windsor like this.
  15. Jan 12, 2023 at 8:51 AM
    Windsor
    Windsor Why do I do this to myself?
    Homeless in Oregon
    2008 Tundra Crewmax 5.7L
    Some.
    There are times when technology is a detriment.
    22whatwedo likes this.
  16. Jan 12, 2023 at 8:52 AM
    Moe2o4
    Moe2o4 New Member
    Corey
    2020 Tundra SR5 Extended Cab TRD Offroad Package 8ft. Bed
    Bilsten 6112's with 2.5" Front Lift w/Bilstein 5160 Rear Shocks
    Honestly IMO if you can't back up a trailer without assistance you should not be attaching on to your truck..... Just my two cents!
    Mike59 and Gotink like this.
  17. Jan 12, 2023 at 9:24 AM
    rss29
    rss29 New Member
    22 WCP DC LTD
    It's more than just backup though. What I liked was the side traffic warning light in the mirror factors in the length of the trailer. I tried using that feature where it backs up for you but I couldn't figure out how to make it work. Definitely not as slick as Ford's system that uses the dial to steer the trailer.
  18. Jan 12, 2023 at 11:12 AM
    Limited 23SC
    Limited 23SC New Member
    2023 Limited
    I didn't have any adjustments to do for my 5x8 utility trailer. I did turn off the rear cross thing with a cone on the dash though. I also adjusted for the length of the trailer , but that has nothing to do with backing it up.
  19. Jan 12, 2023 at 12:12 PM
    ArmygreenTRD
    Wow! Everyone’s quick to comment. OP never stated he couldn’t manually back the truck. Par for the course that the peanut gallery chimes in when they don’t even own a 3rd gen:monocle: OP is simply trying to work the technology that’s installed and that he paid for.
    HMNYC, crewmax55, Maharisc and 4 others like this.
  20. Jan 12, 2023 at 1:57 PM
    g6t9ed
    g6t9ed Novice Tundra Modder
    2017 Black CrewMax 1794 4x4
    Not disagreeing with you and got no skin in the game but to play devil's advocate, why didn't the OP refer to the manual to see if they were doing it correctly or YouTube it?
    I get why the other side is criticizing OP. Nothing that they said shows me as an objective reader that they eliminated all common sense options before asking in the forums. Everyone's assuming. Just my thoughts.
  21. Jan 12, 2023 at 2:45 PM
    ArmygreenTRD
    Still don't get why the only negative comments are from non 3rd genners. Seems to be trolling. OP never stated that he didn’t read the manual. I guess some people assume they can go to a forum, designed and dedicated to other owners, and ask a question without having to show some kind of proof they are worthy or eliminated all other common sense options. It appears this tech is not so common sense.
    I’ve made some snarky comments, but usually only to point out others of the same. In the end, we all get to choose to be helpful or not. Like the old saying, “ got nothin’ good to say? Don’t say it at all” Just my worthless random internet guy opinion.
  22. Jan 12, 2023 at 3:47 PM
    g6t9ed
    We aren't judged by our intentions but our actions. Again, not trying to be combative but just my observations of both the requestor and responders. People like to teach how they've been taught and some people's idea of humor can be another's insult.
    One thing's for certain - people can explain it to you but they can't comprehend it for you.
    Edit: 3rd gen or not, I only made the comment about common sense and verifying the manuals because help can only come from the process of elimination. No one knows how much OP knows. Any extended time in the forums on any generation truck and it's always a commonality amongst everyone. Hence, why we all always refer to the forum rules or the Sticky threads or search bar, etc.
    ArmygreenTRD[QUOTED] likes this.
  23. Jan 12, 2023 at 4:29 PM
    Black@Blue19
    Black@Blue19 Old Salt
    Ken
    SE Texas
    For the money I do not understand why they even have something like this. Just another thing to mess up!!!
    Y0TA PR0 likes this.
  24. Jan 12, 2023 at 4:59 PM
    PBNB
    PBNB Needy
    Peter
    Vancouver, BC
    2023 Z71 3500 HD
    Lots of stuff!
    A buddy has an F150 and for about a year he messed around with that backup tech. Finally, just gave up. He has several different trailers which made this more complicated.
    When we were shopping for our truck. We thought that the backup would be interesting. Since we wanted a Limited, the decision for backup assistance was solved.
    I have a backup camera on the trailer so we had lots to fall back on. In the few trips we have taken with the Tundra, I find the mirrors enough and my wife at the back to make sure I don’t back into anything.
    Sometimes high tech came make things more complicated if it doesn’t work or is easy to implement. It makes matters worse if you are on a time frame adding pressure to the situation.
    Mattedfred likes this.
  25. Jan 12, 2023 at 7:01 PM
    ArmygreenTRD
    @g6t9ed Points well stated and taken.
    g6t9ed likes this.
  26. Jan 12, 2023 at 7:12 PM
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
    Since OP’s issue with TSS braking seems to be sorted out, I’m just going to leave this here.
    WildBillThe2nd, MS22 and PBNB like this.
  27. Jan 12, 2023 at 7:37 PM
    Silver17
    Eastern PA
    2017 TRD 4x4 Harrop SC
    Not directed at OP or anyone else as this is a new fangled tech related issue, but as a general statement in regards to trailer backing….. some people have just got it, and others it’s just not natural!
    TILLY likes this.
  28. Jan 12, 2023 at 7:47 PM
    TILLY
    TILLY Gently Used Member
    Massachusetts
    2019 MGM TRD Sport D/C
    Very true, backing up a trailer somehow messes with your head because of the way we are taught to drive. If you steer from the bottom of the steering wheel while backing up like I was taught, its much easier.
  29. Jan 16, 2023 at 11:57 AM
    WildBillThe2nd
    WildBillThe2nd New Member
    2022 Tundra, SR5, TRD-OR, Advanced Tech
    Not picking on the OP, I promise. But this made me laugh.
    I though this Car's quote would be appropreate as well.
    landphil[QUOTED] likes this.
  30. May 6, 2023 at 5:09 PM
    Cdunner
    Cdunner New Member
    2023 White Sequoia SR5 TRD Off-road
    2023 sequoia here. It also slams on the brakes with the trailer attached in reverse. It seems to think it’s going to run into the trailer it’s attached to lol. Any help would be appreciated. This is with the trailer programmed in and plugged in.
