Backfiring
Discussion in '2.5 Gen Tundras (2014-2021)' started by G_dog1, Oct 14, 2024.
  1. Oct 14, 2024 at 7:18 AM
    G_dog1
    G_dog1 [OP] New Member
    Greetings all.
    Last night I was driving my 2018 tundra 5.7l on the highway (well warmed up), and out of no-where, it started back firing. It was loud, and I thought I was running over fireworks. The back firing lasted for a couple seconds then faded away.
    After that, when approaching a stop sign (no throttle /high intake vacuum) I heard a small back fire.
    On my last stretch of road on the way home, I accelerated relatively hard, and there were no issues to he heard….so I can’t repeat the issue.
    When I got home I scanned for codes with my OdbdII reader and got nothing.
    The truck is stock with 80,000kms on it.
    Any suggestions would help.
    Spark plugs?
    Stuck injector?
    Mass air flow sensor?
    Fuel pressure?
    O2 sensors?
    Smog stuff?
    Regards
    G_dog1
  2. Oct 14, 2024 at 7:32 AM
    Would be leaning towards injectors.
    G_dog1[OP] likes this.
  3. Oct 14, 2024 at 7:44 AM
    Johnsonman
    Johnsonman New Member
    Austin
    Sequoia
    Backfiring is caused by an excessively lean condition and sometimes just sometimes a small exhaust leak along with some leanness yet no P0171.
  4. Oct 14, 2024 at 7:56 AM
    I would have said the opposite. Backfiring caused by unburnt fuel entering a hot exhaust system
    Mdl and G_dog1[OP] like this.
  5. Oct 14, 2024 at 8:11 AM
    G_dog1
    Damn...without a code, I'm thinking a partially stuck open injector, or a sticking valve in the head.
    Pulling the plugs and doing a compressions test should tell me if a valve is sticking.
    No spark might also dump raw fuel into the exhaust....
    Mdl, Rdrcr, batman900 and 1 other person like this.
  6. Oct 28, 2024 at 7:45 AM
    G_dog1
    Well it has been a couple weeks, and I haven’t been able to reproduce the back firing issue. The engine has been running flawlessly.
    This only leaves me to believe that I had a stuck open injector…
    Mdl likes this.
