Backfire/ popping and hesitation on hard acceleration
Discussion in '1st Gen Tundras (2000-2006)' started by Rrworker, Dec 4, 2018.
  1. Dec 4, 2018 at 7:36 PM
    Rrworker
    Rrworker [OP] New Member
    2003 Tundra SR5
    I've been noticing that I have a popping /backfiring noise with hesitation when I accelerate hard on my 03 tundra 2x4. Any ideas on what it could be? 284,Xxx on the gem and if you let off it will go away but just have to slowly give it gas and it will run out till 80 or so but that's about it.
  2. Dec 4, 2018 at 8:48 PM
    Trpl7
    Trpl7 My best friend Tate
    Rob
    Washington
    Super White 07
    Partial level kit, Total chaos UCA, coach builder shackles, magnaflow ex. Tuner, SABM, complete poly bushing suspension.
    When were the timing belts changed?
  3. Dec 5, 2018 at 5:14 AM
    Rrworker
    2003 Tundra SR5
    It's scheduled to be done this Friday.
  4. Dec 11, 2018 at 7:06 AM
    Chief 01
    Chief 01 New Member
    PA
    2020Tundra Pro Army green
    Have your ECM checked, tested
  5. Dec 11, 2018 at 7:08 AM
    Chief 01
    Chief 01 New Member
    PA
    Did the timing belt cure the problem??
  6. Dec 11, 2018 at 7:37 AM
    tenntundra
    tenntundra 2013 SR5 crewmax Barcelona red
    Walter
    Tennessee
    2013 barcelona red sr5 crewmax TRD tundra
    3" suspension lift, BMF 20" wheels 305/55/20 nitto ridge grappler tires,painted RED bushwhacker fender flares,fold up tonneu cover,100 watt led fog lights,led interior lights,borla dual exhaust,tinted windows,window vent visors, Toyota hood protector,toyota step bars,spyder carbon fiber floor mats,k&n air filter,painted brake calipers red, installed red lug nuts on wheels remote start.
    Check your MAF sensor and check for possible vacuum line leak or collapse.when you accelerate hard it pulls more vacuum.
  7. Dec 11, 2018 at 7:44 AM
    Chief 01
    Chief 01 New Member
    PA
    Replaced MAF, will check vacuum lines,thanks, cheaper than replacing the ecm
  8. Dec 11, 2018 at 7:45 AM
    Chief 01
    Chief 01 New Member
    PA
    PS bad gas mileage also all of a sudden
  9. Dec 11, 2018 at 7:47 AM
    Chief 01
    Chief 01 New Member
    PA
    Went from 16 down to 9
  10. Dec 11, 2018 at 7:54 AM
    tenntundra
    Walter
    Tennessee
    This is a long shot but try running some seafoam through the brake booster vacuum line going back into the intake.start the engine ,pull off the vacuum line,while the engine is running pour half bottle into the line to the intake.go slowly because it will stall out the engine,when you have half bottle poured in,turn off the engine.be sure the truck is level as possible and outside.let the truck sit for 10 minutes.start engine. It may be hard to stats but it will.It will smoke out the tailpipe like it's on fire but don't worry. It's burmibbout build up in the intake and valves drive it for a few miles and it should clear up.You should notice smoother idle and better response. I use it in all my vehicles.Put the rest of the can on the gas tank.Good luck!
  11. Dec 11, 2018 at 11:36 AM
    Rrworker
    2003 Tundra SR5
    Had the timing belt replaced, runs stronger than it did but still has the popping on hard acceleration. The tech thinks it could be a broke or weak intake valve spring broke or slightly twisted causing it to not close completely. I have to replace the valve cover gaskets because they've been leaking and another tech said to push down on the valve and see if it's weaker than the other ones. Hopefully I can get it back to him and get it checked out next week. I have a misfire on the #4 cylinder, replaced the coil and no difference, still the popping on hard acceleration. If no evidence of a bad spring the other tech said to swap injectors around. Will post later on the diagnosis. The timing marks all lined up as well when he changed the t-belt Friday.
  12. Dec 11, 2018 at 11:44 AM
    Rrworker
    2003 Tundra SR5
    Chief 01, you're experiencing the same problem?
    My mileage is still around 13.8 -14.4 so it's about the same, would be a little better than that but I run on about 75 ish in the morning heading to work.
  13. Dec 11, 2018 at 5:43 PM
    Chief 01
    Chief 01 New Member
    PA
    Yep, it almost feels like it shuts off and runs rough until i leave up on the throttle,then it smooths out and at red light it idles at 500 and rough and other times it at 750 and smooth, check engine light keeps coming on
  14. Dec 11, 2018 at 5:46 PM
    Chief 01
    Chief 01 New Member
    PA
    Not sure if timing belt was ever changed, scanner said something about ECM,
  15. Dec 11, 2018 at 5:49 PM
    Rrworker
    2003 Tundra SR5
    Have you disconnected the battery lately for any reason?
  16. Dec 11, 2018 at 5:57 PM
    Chief 01
    Chief 01 New Member
    PA
    No, the first codes were for 02 sensors, replaced all,then it was saying miss fire,bou bou one new coil and moved it around, then MAF/VAC code,tryed cleaning it,kept coming up so replaced it.
  17. Dec 11, 2018 at 5:58 PM
    Chief 01
    Chief 01 New Member
    PA
    Replaced all plugs also
  18. Dec 11, 2018 at 6:03 PM
    Rrworker
    2003 Tundra SR5
    Check the throttle body and see if it's corroded.
    Mine was nasty, he cleaned it up with some cleaner and did a fuel injection cleaner and got my idle back up to 950 or so.
    Blueknights75 likes this.
  19. Dec 11, 2018 at 6:04 PM
    Rrworker
    2003 Tundra SR5
    I did also and a fuel filter.
  20. Dec 11, 2018 at 6:10 PM
    Chief 01
    Chief 01 New Member
    PA
    Did all that with seafoam 3 months ago when it first started acting up
  21. Dec 11, 2018 at 6:10 PM
    Rrworker
    2003 Tundra SR5
    That's before the new belt and water pump was replaced, belt had 140k on it but nothing other than worn and stretched is all I could see, no teeth missing.
  22. Dec 11, 2018 at 6:12 PM
    Chief 01
    Chief 01 New Member
    PA
    Changing timing belt and water pump cam seals r out of my league
  23. Dec 11, 2018 at 6:19 PM
    Chief 01
    Chief 01 New Member
    PA
    Sorry for taking so long to get back to ya, making boilo and ya know ya half to test it out, don't mean to get off topic, but it's driving me nuts and emptying my wallet
  24. Dec 11, 2018 at 6:21 PM
    Rrworker
    2003 Tundra SR5
  25. Dec 11, 2018 at 6:26 PM
    Chief 01
    Chief 01 New Member
    PA
    172,000 on my 01, bought used 4 yrs. ago, no problems expect front brakes, sounds like the norm from what I hear
  26. Dec 11, 2018 at 6:28 PM
    Rrworker
    2003 Tundra SR5
    Yes me too, I was fortunate to be able to watch as he tore it down and see that it was actually replaced with a new one, factory one at that. I hope it's a valve spring though and get it resolved. He's covered up this week but said to holler at him next week. My seals weren't leaking, he changed the left side one but the bolt on the right side was so tight that he was afraid of breaking it off and then it would be a major ordeal to fix that.
  27. Dec 11, 2018 at 6:31 PM
    Chief 01
    Chief 01 New Member
    PA
    Yeah, have to keep that family tradition going,lol , 190 proof corn mash, honey and a few cinacinn sticks
    Black Wolf likes this.
  28. Dec 11, 2018 at 6:34 PM
    Rrworker
    2003 Tundra SR5
    Oh I see, sounds like you might have to pour a pint of that E90 in the tank with a 1/4 tank of gas and drive it like you stole it. Lol
  29. Dec 11, 2018 at 6:38 PM
    Chief 01
    Chief 01 New Member
    PA
    I hear ya,lol, I remember reading that the ECM will cause these issues, somewhere on a different fourm I believe
  30. Dec 11, 2018 at 6:38 PM
    Professional Hand Model
    Hand Protectors
    You check you PCV Valve lately? Sounds small but they are important. Could be gunked. Its a vent for your engine that vents out of your drivers side valve cover and into your throttle body. You’ll need to clean the port of the PCV Valve too. I did mine when replacing the Valve Cover Gaskets.
    My rpms are Steady Eddy after replacing the PCV Valve and cleaning the throttle body.
    Filthyphil and Rrworker[OP] like this.
