Back window tundra trd sport 2024 have noise
Discussion in 'General Tundra Discussion' started by Lamarre4995, Sep 12, 2024.
  1. Sep 12, 2024 at 10:22 PM
    Lamarre4995
    Lamarre4995 [OP] New Member
    Daniel
    Red 2024 Tundra Trd Sport
    Hi
    I have a little noise from back window, the noise is when it’s hot outside and it’s close to stop it I need to open a little bit the window and it stop. The dealer try to put some lubricant and it doesn’t stop. If somebody have the fix for that I will be very happy
    Thanks
  2. Nov 1, 2024 at 10:01 PM
    Lamarre4995
    Daniel
    Hi
    Nobody have this rattle in the back window
  3. Nov 1, 2024 at 10:56 PM
    TacomaTRD4x402
    TacomaTRD4x402 New Member
    Southern California
    '18 Tundra TRD Sport 2WD 5.7 Crew Cab MGM
    I did a search for you and found there are several people with window rattle issues... Here is one post I found. Looks like it may be something you can have the dealer fix under warranty.
    https://www.tundras.com/threads/rear-window-rattle.132653/
    Just do a title search for"window rattle" and you'll find the answer your looking for which is take it to the dealer to fix.
  4. Nov 1, 2024 at 11:35 PM
    Lamarre4995
    Daniel
    Thanks I’ll check that but mine I have a rattle when my window is closed and it’s hot outside and it stop when I opened just 1/4 inch it stop
