Back window stopped rolling
Discussion in '1st Gen Tundras (2000-2006)' started by arlail76, Nov 14, 2020.
  1. Nov 14, 2020 at 6:51 AM
    arlail76
    arlail76 [OP] New Member
    Andrew
    Stock 2004 Toyota Tundra Double Cab 2WD
    Anyone’s back window just randomly stop rolling up and down?
    I can hear a click back there for it to roll, but it doesn’t
    Bad relay maybe?
  2. Nov 14, 2020 at 8:04 AM
    torino69
    torino69 The old guy
    West Fargo, North Dakota
    2004 Toyota Tundra Limited
    None worth mentioning
    If you hear the click that's probably the relay telling it to open and if it does not open that probably means the motor is bad or something is causing it to bind. Larry
  3. Nov 14, 2020 at 2:59 PM
    arlail76
    Andrew
    Guess I’ll be taking the back panel down and checking it all out. It had been working fine
  4. Dec 19, 2020 at 1:01 PM
    arlail76
    Andrew
    So after pulling the back panel...nothing there visibly to have it in a bind...still trying to figure out how it would work perfect, then after I blew a fuse tinkering with something else...after replacing that fuse, it just doesn’t work.
  5. Dec 19, 2020 at 1:16 PM
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
  6. Dec 19, 2020 at 2:24 PM
    arlail76
    Andrew
    Guess I’m lucky that it’s stuck, closed. I was just enjoying that back window down this summer.
  7. Aug 14, 2021 at 6:39 PM
    Severm
    Severm New Member
    Hey everyone. New to this forum. I ran across this thread and thought I would inject a possible solution since I recently had the same problem. Hope it isn’t too late for some who have this situation in the future. I disconnected the plug just before the motor, soaked each side for a couple of minutes in a solution of warm water and baking soda. This gets rid of any corrosion build up from moisture that gets in that area even if you can’t see any. Dry both sets of connections thoroughly and apply dialectic grease to each terminal and plug them back together. Nine out of ten times, this will fix the problem and save $200+ and the time removing and installing the new motor and bracket. Mine now works smoothly. Hope this helps anyone with this problem.
    1Sterman and BubbaW like this.
