Back wheel grinding
Discussion in '2nd Gen Tundras (2007-2013)' started by Evanhawtrey, Aug 17, 2021.
  1. Aug 17, 2021 at 5:38 AM
    Evanhawtrey
    Evanhawtrey [OP] New Member
    Evan
    2012 tundra rock warrior
    I added bilstein struts up front instead of a leveling kit to raise it
    So I thought it was low rear pads.. grinding when I stopped. But it makes a rubbing noise when I drive too? Doesn’t sound like a wheel bearing does it? Maybe debris caught up in it ?
  2. Aug 17, 2021 at 6:08 AM
    frichco228
    frichco228 Valued Member
    2016 Crewmax 4WD, TRD Offroad
    could be either, take the wheel off and see if anything is amiss, check for play, sounds in bearings, look and see if pads or rotors are worn. Could be helpful to list your miles, maintenance info.
  3. Aug 17, 2021 at 8:25 AM
    audiowize
    audiowize New Member
    Paul B.
    2008 Tundra SR-5 4x4 5.7
    The backing plates on the rear brakes can corrode and they expand as they do, then they can rub on things. Rather than buying new ones, I took mine off and ground them down, then slathered them in rust converter and painted them.
    It could also be bad wheel bearings, but the only way you'll know is to pull it apart a bit.
