Back-up camera not displaying
Discussion in '2.5 Gen Tundras (2014-2021)' started by Akhiloo4, Apr 23, 2020.
  1. Apr 23, 2020 at 12:03 PM
    Akhiloo4
    Akhiloo4 [OP] New Member
    2017 Tundra TSS SR5 crewmax
    Light bar, beat sonic phone screen sharing, front camera, wireless charger, full chrome delete
    Hello Tundra fam!
    I just installed the wireless charger from sparks auto. Everything works and functions except my back-up camera and front camera. When the truck is put into reverse, the camera doesn’t display, and if I push the front camera button, nothing displays, the home screen is only displayed.
    This started to happen after the wireless charger was installed.
    thanks
  2. Apr 23, 2020 at 1:53 PM
    tttrdpro
    tttrdpro Former Naval Person
    SWGA
    2024 GMC 2500 AT4
    In progress…
    Like Ron said check for a blown fuse. If you don’t find one, I would undo the wiring changes you made and go from there.
    GODZILLA likes this.
  3. Apr 23, 2020 at 1:55 PM
    Akhiloo4
    Yes, i did disconnect the negative terminal before install. Which fuse would be fir the camera?
  4. Apr 23, 2020 at 2:00 PM
    19TurdPro
    19TurdPro New Member
    2019 Tundra TRD Pro
    I blew the fuse reverse lights in my 3rd Gen. I believe it's a 15 amp fuse labeled "tail".
  5. Apr 23, 2020 at 2:01 PM
    19TurdPro
    2019 Tundra TRD Pro
    On my truck the neutral safety switch is on that same fuse so if you tried to drive your truck right now every warning light on your dash will light up.
  6. Apr 24, 2020 at 2:35 PM
    DIYDad
    DIYDad New Member
    2020 Tundra 1794
    front camera button? what's that?
    BravoDeltaRomeo likes this.
  7. Apr 24, 2020 at 2:39 PM
    19TurdPro
    2019 Tundra TRD Pro
    There is a harness called a FRAC that allows you to install a front camera, and the button allows you to enable it on the OEM screen.
  8. Apr 25, 2020 at 8:10 AM
    WAtundra4x4
    WAtundra4x4 Retired from active retirement.
    Den
    Wet side WA
    2018 Cement Tundra TRD crewmax limited
    Forward looking camera, Stub Antenna, 3M clearshield. A few other non lifted items.
    What did you hook up the wireless charger to? Disconnect the wireless charger and retest? Is there 12 v to the wireless charger?
    I just installed a FRAC harness this past week and noticed there is a fuse in that harness. If you hooked up the wireless charger to the front camera power, it would explain what happened.
  9. Apr 25, 2020 at 8:54 AM
    spdrcer26
    spdrcer26 New Member
    Bakersfield, CA
    2017 Crewmax
    Like others said- try going backwards tracing your previous steps then try the camera without the charger hooked up- if the cameras don’t work it is probably a fuse issue.
