Back up camera issues
Discussion in '2.5 Gen Tundras (2014-2021)' started by jewsNbrews, Jul 22, 2019.
  1. Jul 22, 2019 at 4:29 PM
    jewsNbrews
    jewsNbrews [OP] SSEM #8 level 3, RGBA #5 lab tested lab approved
    Jewiston Idaho
    2019 TRD PRO
    Bolt on
    I have searched and seen delayed or blue screens. My issue is that my camera turns on when backing up but will then not turn back on after being in drive. I have to turn the truck off, restart it, and the camera will work like it's supposed to. When it initially wouldn't come on I was thinking connection, but the fact that it works after it is restarted makes me think otherwise. Has anyone else had this issue before?
    Black Wolf likes this.
  2. Jul 22, 2019 at 4:55 PM
    jewsNbrews
    Jewiston Idaho
    2019 TRD PRO
    Bolt on
    Still under warranty, but I have to travel. Will buy locally, dont trust them to work on it. Shitty service personnel, and I just dont trust them.
    15whtrd and OR18TRD[QUOTED] like this.
  3. Jul 22, 2019 at 4:56 PM
    jewsNbrews
    Jewiston Idaho
    2019 TRD PRO
    Bolt on
    And no, it should come on no matter when its put into reverse. So something is off, wanted to see if something I could correct without driving a 100 miles to be looked at.
    15whtrd, OR18TRD and Black Wolf like this.
  4. Jul 22, 2019 at 5:43 PM
    AZTundra
    Paul
    Phoenix, AZ
  5. Jul 22, 2019 at 6:03 PM
    Patch999
    Kyle
    TX
    2017 Bad@$$ TRD Pro
    That’s a strange one. Did you notice it recently or has it been doing it? You would think the trigger would either work or not.
    jewsNbrews[OP] likes this.
  6. Jul 22, 2019 at 6:07 PM
    jewsNbrews
    Jewiston Idaho
    2019 TRD PRO
    Bolt on
    Just started. Happened twice. Only reason I notice is because I back into parking and my drive way.
  7. Jul 22, 2019 at 6:10 PM
    jewsNbrews
    Jewiston Idaho
    2019 TRD PRO
    Bolt on
    Thanks, it says there is an update for my model. I will have to wait to get to a computer, needs USB drive to download. Only mobile when not at work.
    OR18TRD likes this.
  8. Jul 22, 2019 at 6:12 PM
    AZTundra
    Paul
    Phoenix, AZ
    Yeah, I just happened to think maybe that will do the trick. When I searched for the link to add I noticed that there is an update for mine as well. (2017 w/NAV). It's worth a try. If nothing else at least you'll have the updated firmware installed.
  9. Jul 22, 2019 at 6:12 PM
    Patch999
    Kyle
    TX
    2017 Bad@$$ TRD Pro
    We hook up a lot of aftermarket camera systems and use the reverse lights as the trigger. Have you checked to see if your reverse lights are doing the same thing?
  10. Jul 22, 2019 at 6:47 PM
    jewsNbrews
    Jewiston Idaho
    2019 TRD PRO
    Bolt on
    I will have to check, need a second person to make sure both are working properly.
    Patch999[QUOTED] likes this.
  11. Dec 6, 2020 at 9:42 PM
    gosolo
    Ray (or maybe Dale)
    NW Oregon
    Did you ever get this resolved?
  12. Dec 6, 2020 at 9:48 PM
    jewsNbrews
    Jewiston Idaho
    2019 TRD PRO
    Bolt on
    Yeah. Upgraded to a 2019 pro :rofl:
    But no, the reverse lights were working properly. The camara issue happened randomly until I traded it in.
    gosolo[QUOTED] likes this.
  13. Dec 6, 2020 at 9:51 PM
    1lowlife
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    I had this issue with an aftermarket Kenwood HU on my 2014 SR5.
    I reflashed the Maestro and now everything works fine..
  14. Dec 7, 2020 at 12:42 AM
    MGM2020
    MGM2020 New Member
    Sacramento CA
    2020 MGM Tundra SR5
    6" Rough Country Lift 37" on 22" V2 Monotube Rear L3 Lifted Struts Front
    Take it to the dealer and have them fix it under warranty
