Back Up Camera for fifth wheel Transport
Discussion in '2nd Gen Tundras (2007-2013)' started by bzbcal, May 8, 2019.
  1. May 8, 2019 at 3:01 PM
    bzbcal
    bzbcal [OP] New Member
    Paul
    Sacramento Area
    2008 Double cab tow pack
    front hitch and step bumpers and kayak rack
    Has anyone figured out a place to put a back up camera when truck is used for fifth wheel use.
    License plate cameras do not work and I have not found a 3rd brake light camera for Tundra.
  2. May 8, 2019 at 3:12 PM
    Nm6300'asl
    Nm6300'asl New Member
    2022 DC SR5 4x4
    Oem tonneau, side steps, spray in liner. Trd skidplate.
    Check into a furrion observation/back up cam. Works well for us. A must have with non tow mirrors.
  3. May 8, 2019 at 4:02 PM
    SoCalPaul
    SoCalPaul New Member
    Paul
    San Fernando Valley, CA
    2006 Tundra Access Cab Limited 4wd.
    Front Bilstein 6112 shocks & Bilstein springs. Rear Bilstein 5160 remote Reservoir shocks, Wheeler’s Off-road add-a-leafs. LED lighting. Pioneer Avic 7200NEX Nav Head unit. Borla cat back exhaust.
  4. May 8, 2019 at 5:35 PM
    bzbcal
    Paul
    Sacramento Area
    I have fifth wheel hitch which means tailgate has to be down so license plate cameras do not work. Hopefully someone will have found a solution.
  5. May 8, 2019 at 6:28 PM
    SoCalPaul
    Paul
    What are you trying to see? Do you want truck mount or do you want to see behind the 5th wheel?
  6. May 8, 2019 at 6:55 PM
    bzbcal
    Paul
    Sacramento Area
    I have a wired rear view system from RVS mounted on back of trailer. I need camera to see fifth wheel king pin to hitch up to with truck.
    Thanks
  7. Jul 30, 2019 at 7:21 AM
    ND_Porkchop
    ND_Porkchop New Member
    2008 Tundra 5.7 CM DSM
    I would take the camera linked above, or something cheaper bend a little metal tab, grab a m6 bolt or whatever the factory bed rails bolt to, and bolt it up underneath near the top edge of the front of the bed.
    You should have enough angle to line up your 5th wheel. I wouldn't want to drill into the brake housing of roof because I don't like leaks...
