Back up camera dead
Discussion in '2.5 Gen Tundras (2014-2021)' started by rockmup, Jan 22, 2024.
  1. Jan 22, 2024 at 4:23 AM
    rockmup
    rockmup [OP] New Member
    Todd
    Greenwell Springs LA.
    2019, 1794
    Kinda irritated but the first real problem I've had with this truck. Still have backup lights.
    Any basic stuff to check ?
  2. Jan 22, 2024 at 5:34 AM
    MadMaxCanon
    MadMaxCanon New Member
    '21 CM SR5 4x4 6 seater
    Too many, but not enough....
    have you done any recent electrical work or anything with the tailgate or radio? Any other electrical problems? I would check wiring near your hitch.
    Is your camera completely dead? When you go into R, does the screen just go black?
  3. Jan 22, 2024 at 5:40 AM
    PermaFrostTRD
    Northern NY
    Also another thing to check is the cheap plastic mount bracket. If you still see the guidelines on your screen, then it's likely the bracket broke and your camera is down in the tailgate. Ask me how I know. Granted, if your screen is black and the camera is still visible from the tailgate, then your bracket isn't the problem and it's a wiring issue. New OEM replacement is the bracket and camera assembly together for like an absurd $800.
    ljburns likes this.
  4. Jan 22, 2024 at 9:03 AM
    rockmup
    Todd
    I've done nothing to this truck electrical and the screen is black when put in reverse.
  5. Jan 22, 2024 at 11:01 AM
    Slag_Dynamics
    Slag_Dynamics Cut. Weld. Repeat.
    Arizona
    Gone
    If it does end up being a dead camera, I may have one AND a harness.
    I’d drop the tailgate and pull off the access panel to check the connections. Also, look for fraying where the tailgate opens and closes and the wires run through.
    rockmup[OP] likes this.
  6. Jan 22, 2024 at 6:32 PM
    rockmup
    Todd
    I appreciate that. Its gonna be several weeks before I can get to it, fixing to move several states over
  7. Jan 22, 2024 at 6:56 PM
    Slag_Dynamics
    Arizona
    Gone
    Well lucky for you, I’ll be having surgery here soon. So I’ll have several weeks to wait.
  8. Jan 22, 2024 at 7:06 PM
    Look under the tailgate and see if the plug is plugged in correctly, should only take 1 minute. Hopefully that's the issue.
  9. Jan 23, 2024 at 8:37 AM
    HartysTundra
    HartysTundra New Member
    Had the same issue once. Turned out my neighbor caught someone under my truck in the middle of stealing my tailgate. Guys snipped my wires and ran off once he was called out. Check your wires…
  10. Jan 23, 2024 at 10:17 AM
    ljburns
    ljburns New Member
    This was my issue, but I found a used handle, mount, and camera on ebay for $200.
    PermaFrostTRD[QUOTED] likes this.
  11. Mar 6, 2024 at 5:32 AM
    rockmup
    Todd
    So it just randomly started working again about 2 weeks ago. lol
