Back up camera 2013 not working
Discussion in 'General Tundra Discussion' started by Kefarley11, Dec 11, 2022.
  1. Dec 11, 2022 at 4:30 PM
    Kefarley11
    Kefarley11 [OP] New Member
    My 2013 tundra back camera has gone completely blank
  2. Dec 18, 2022 at 2:06 PM
    Diet-Zeus
    Diet-Zeus New Member
    Ryan
    2014 SR5 Double Cab, Black
    Butterfly Valve Exhaust, K&N Cold Air Intake, Stealth Lightbar, Toytec Adjustable Suspension, Total Chaos Upper Control Arms, Tonneau Cover
    I was hoping there were going to be replies in here. My 2014 back up camera is fading out (works some times, has lost signal, or gets that classic 1970's screen "wave" sometimes.) I replaced the OEM head unit with an aftermarket but I am sure the connections are solid. Maybe time to get another receiver? HELP US haha.
  3. Dec 18, 2022 at 2:10 PM
    Kefarley11
    I feel your pain...I can't get answers from the dealership or this form ...just a blank screen..probably going to buy a cheapo on Amazon
  4. Dec 18, 2022 at 2:47 PM
    doggunner
    doggunner New Member
    2014 Tundra Crew max White
    Mine stopped working few years ago. Nothing. 2014
  5. Dec 18, 2022 at 4:27 PM
    Trooper2
    JR
    Houston, TX (Suburban South)
    Has anyone checked for voltage to the camera when in reverse? If voltage is present then camera most likely needs to be replaced.
    If no voltage then possibly a bad connection or issue with Head unit, rear view mirror, or what ever screen being used.
  6. Dec 21, 2022 at 7:01 AM
    Rangergillikin
    Rangergillikin New Member
    Alabama
    2021 magnetic grey TRD Pro Crew Max.
    TracRac bed rack, Retrax bedcover, Anytime forward facing camera, Rago dash mounting plate, changed all lights to LED with 1200lumen reverse light, added LED above tag reverse light, rear bumper step, Go Rhino step sides, CCM Cat Security Shield, tool mounts on bed rails, added tie down pad eye on bed rails.
    I’ve have had a problem with mine ever since I’ve added a switch pro. I believe the problem is coming from the add-a-fuse I put in fuse box for switch pro. First time it did it I had the wires laying on top of some relays or could have been fuses. I picked those wire up and camera improved. I haven’t had time to move the wire yet but I believe they are causing some interference. I have those same wire coming into fuse box with those other wires on the left back corner if you are looking at motor from the front. I’m going to try some ferrite chokes or move wires to see if that fixes it. My backup camera will either have a lot of static or it blacks out. Doesn’t do it all the time.
