Back to 1st gen ??????
Discussion in '1st Gen Tundras (2000-2006)' started by Yotajake, Mar 17, 2025.
  1. Mar 17, 2025 at 6:31 PM
    Yotajake
    Yotajake [OP] New Member
    Jake
    2010 tundra 4.6 rcsb 4x4, 2009 tundra 5.7 rclb 4x4 sr5
    I have 2010 rclb tundra thinking of going to 1st gen 2005 rclb 4.7 v8
    I do tow a trailer will I notice a big difference??
  2. Mar 17, 2025 at 6:34 PM
    The Black Mamba
    The Black Mamba He must increase, but I must decrease - John 3:30
    Ryan
    DFW
    Black 00 SR5 AC 5VZ PreRunner
    Imma keep it stock
    That all depends on your trailer…
    I think @KNABORES is best suited to answer as he has first hand experience with this exact scenario.
    FrenchToasty likes this.
  3. Mar 17, 2025 at 7:16 PM
    Yes. But it depends on the trailer. Whatcha towin?
  4. Mar 17, 2025 at 7:25 PM
    whodatschrome
    whodatschrome New Member
    North of North Plains, Oregon
    lots of dents
    4x8 harbor freight trailer? You won’t even notice it’s there. Jokes aside, the 1st gen isn’t a heavy hauler. I find that it’s more of a light duty truck. Even though it has a fairly decent v8, the truck just doesn’t have the robust duty rating of a full size. I still love everything about my 2004 access cab, but if i need to haul or tow something heavy, i’ll use one of my other larger vehicles.
    OldGuy03 likes this.
  5. Mar 17, 2025 at 7:48 PM
    Fragman
    Fragman New Member
    TX
    2006 Tundra DC SR5 2WD V8
    Seeing as your 2010 (from your signature) is a 4.6, and the Gen 1 is a fair bit lighter (several hundred pounds lighter IIRC), the difference may not be as much as you would expect.
    ETA - Of course, depending on the trailer also.
  6. Mar 17, 2025 at 8:13 PM
    Bought2Pull
    Bought2Pull New Member
    Greg
    WV
    2006 Tundra 4 door
    OP,
    Gross weight trailer and load needed.
    My 2005 GMC Canyon with 5 cylinder engine nearly overheated pulling my 6x12 foot single axle trailer with 800 pound zero turn and 400(?) pound riding mower up Sandstone Mountain in WV. 7 percent grade and about four miles long. Trailer is 1/8" tube steel throughout. No idea on dead weight but I'm assuming around 1000 pounds.
    Put same load on same trailer and tried with my 2006 V8 Tundra Double Cab (part of the "test drive" before I bought it). Got the same run at the hill. Tundra actually passed other vehicles going up. Easy to maintain 55 mph speed. No change in heat hand on gauge. It was at that point I knew I was buying the Tundra.
    I plan to buy a 2 axle 16 foot or longer trailer this spring as we'll soon add a second zero turn to the fleet and the 6x12 isn't long enough. I'd like to buy aluminum just to keep the weight down but I'll likely buy steel as it's cheaper. My Tundra is rated for 7,000 pounds towing capacity. I'll be some time before we buy any equipment weighing over 5,000 pounds.
    The Black Mamba and OldGuy03 like this.
