Back (rear) window
Discussion in 'General Tundra Discussion' started by Tundra1959, May 8, 2020.
  1. May 8, 2020 at 10:14 PM
    Tundra1959
    Tundra1959 [OP] New Member
    Timothy
    Is the rear window in a 2019 and 2020 the same size.
  2. May 8, 2020 at 10:22 PM
    1lowlife
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    I'd think yes..
    Actually from 2007 to 2020 the same size..
    Welcome to the forum..
  3. May 8, 2020 at 10:25 PM
    TILLY
    TILLY Gently Used Member
    Massachusetts
    2019 MGM TRD Sport D/C
    Which cab size? Crew-max and Double cab are different.
  4. May 8, 2020 at 10:27 PM
    Tundra1959
    Timothy
    Thanks, i am looking for a window vent to go across the back. Do you know where i could find 1 or do they even make them for the 2020 tundra?
  5. May 8, 2020 at 10:27 PM
    Tundra1959
    Timothy
    Crew max, Tilly sir
  6. May 8, 2020 at 10:39 PM
    TILLY
    Massachusetts
    I thought you wanted to replace the entire window, sorry, not sure.
  7. May 8, 2020 at 10:41 PM
    1lowlife
    DADA
    2014 MGM DC SR5
    DC or CM doesn't matter, pretty sure they are still the same physical size.
    Do a few searches on the forum.
    I don't think they make a specific 'vent' but some have modified what they found to work.
    Here is one thread..
    https://www.tundras.com/threads/rear-window-deflector.64378/
  8. May 8, 2020 at 10:42 PM
    Lovetrucks
    Lovetrucks Member
    2019 Ram Rebel
    Welcome
  9. May 8, 2020 at 11:22 PM
    Inquiringone
    Ter
    NorCal 408
    Not many yet, mostly stock.
    I’ve been thinking is there any way of getting a used CM rear window that moves up/down an converting from a slide window back/ forth, that comes with Limited DC.
    Anyone know how involved this pipe dream might be. Or even if it would work.
    Thanks in advance for any info. Id bet there’s some structural differences below the rear window it’s self. And between a CM & DC rear part of the cabs.
    saybng likes this.
