Back passenger tire keeps going flat
Discussion in '1st Gen Tundras (2000-2006)' started by PatTRD2001, Oct 16, 2019.
  1. Oct 16, 2019 at 10:00 AM
    PatTRD2001
    PatTRD2001 [OP] New Member
    Pat
    East Coast
    2001 Tundra TRD SR5 4.7V8
    Hi all, first post here. A month ago I woke up to my rear passenger tire flat. No holes were found but I replaced the tire and wheel (as well as the 3 others) b/c I just acquired a new set. I went from the 245/70/16s to 265/70/16 bc they were Coopers and newer tires. Fast fwd to yesterday and bam....rear passenger tire flat again. And again tire is fine as I just had it filled and drove home with no issues. I will say over 40mph there is a considerable general humming noise. Could this be a bearing issue? It’s not the tire or valve. Something else??
  2. Oct 16, 2019 at 10:06 AM
    TokerJoker
    TokerJoker ΜΟΛΩΝ ΛΑΒΕ
    Travis
    Nowhere, Specific
    2014 Black SR5 4.6 Dbl Cab
    None.....yet
    It could possibly be a bad valve stem. Had the same issue on same tire, more than once.
    marbleville, DalTee and mtTundra like this.
  3. Oct 16, 2019 at 10:07 AM
    TokerJoker
    Travis
    Nowhere, Specific
    None.....yet
    Howdy from DFW and :worthless:
  4. Oct 16, 2019 at 10:07 AM
    koditten
    Kirk
    Midland of the Mitten
    Bent rim? Chance there is a crack in the alloy. Spray some soapy water all along the bead. The leak will show itself.
  5. Oct 16, 2019 at 10:09 AM
    PotentPotables
    Washington
    Does your tire
    I second spraying some soapy water.
    The hum...is it constant above 40mph or rhythmic (more like a wah wah wah)?
  6. Oct 16, 2019 at 10:21 AM
    PatTRD2001
    Pat
    East Coast
    Tried the soapy water on both rims and tires. Nothing. The hum is more like a wah wah wah. Worst between 40-60mph. Slightly better over 60mph or less quiet would be more accurate.
  7. Oct 16, 2019 at 10:44 AM
    PotentPotables
    Washington
    I'm not a technician. However, the "wah wah wah" sound for me has been a wheel bearing for both vehicles and bikes.
  8. Oct 16, 2019 at 10:54 AM
    Trooper2
    JR
    Houston, TX (Suburban South)
    Recently learned that gunk can build up on the inside of rim where the tire seals, preventing a good seal. If gunk present it can be removed with soap/degreaser, Emmery cloth, fine grit sandpaper, or wire wheel.
    There are some youtube vids about it. You will have to take tire off rim to inspect.
    There is always a chance that there is a cracked rim as well, sometimes hard to locate.
    Good luck!
  9. Oct 16, 2019 at 11:01 AM
    Skip_TRD_Sport
    Skip_TRD_Sport Less is More.
    2019 Cavalry Blue TRD Sport
    Westin Pro Traxx 4 Step Bars, Bed Mat, Color Matched Door Handles
    Had that happen on my X-Runner. Fortunately it was the spare and my tire light would remind me to fill it every couple of months. Efforts to clean the seal did not help.
    Trooper2[QUOTED] likes this.
  10. Oct 16, 2019 at 11:03 AM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    Wife bought tires while I was out of town. They UPC stickers weren't removed from the tires and every 2 weeks the tires required air. Then I found that one of the schrader valves was also leaking and simply tightening it fixed the issue.
    To clarify, the UPC stickers were at/on the bead and preventing the bead from sealing properly
    joonbug and Boerseun like this.
  11. Oct 16, 2019 at 11:03 AM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    One of my pressure sensors was cracked and caused a leak that wasnt fixed by replacing a valve stem
  12. Oct 16, 2019 at 11:07 AM
    mtTundra
    mtTundra New Member
    Bozeman MT
    2016 Platinum 4X4, 1997 Tacoma 4x4
    Longer list than the wife needs to know about....
    My guess would either be the rim is flawed or the valve stem as stated above.
    Wheel bearing shouldn't have anything to do with your tire holding pressure.
    marbleville, Black Wolf and koditten like this.
  13. Oct 16, 2019 at 12:04 PM
    remington351
    remington351 New Member
    2006 SR5 DoubleCab
    Soapy water is your friend. Spray around the valve stem inside and outside. Sometimes schrader valves get microscopic dirt in them. Last year when I had tires mounted the tire tech ate too many marijuana gummy bears and installed the tpms wrong. Correct is black oring/washer on inside of wheel, then silver metal washer on outside that threaded collar tightens against. This moron put the silver washer on the inside, nothing on the outside and cranked the tpms collar tight. It sealed enough that it would only leak about 3-4psi a week, so I would only notice the tire bulging every 3-4 weeks.
  14. Oct 16, 2019 at 12:36 PM
    speedtre
    speedtre New Member
    Inland Northwest
    This EXACT same thing happened to me on a brand new 2017 Tacoma. It would take about 3 weeks to lose enough PSI to set my TPMS light off and remind me to fill it....pissed me off to no end, but the dealer was so far away I never bothered taking it back. It was like that when I traded it in with 12K miles...
    831Tun[QUOTED] likes this.
  15. Oct 19, 2019 at 5:18 PM
    BubbaW
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
    Have you been a good neighbor, early April fools from a friend ?
    Not that I would know anybody that's done that to a friend :spy:
  16. Oct 20, 2019 at 5:41 PM
    marbleville
    marbleville Agent Provocateur
    Yep, last name too.
    State of Confusion
    2002 Thunder Gray Metallic TRD.
    Air freshener died, washer fluid empty, wipers streak.
    Have your mother-in-law sit on the other side.:anonymous:
    koditten likes this.
  17. Oct 21, 2019 at 12:34 PM
    marbleville
    Yep, last name too.
    State of Confusion
    All I can come up with is the bad valve or rim that's bent or cracked. I would first exchange the leaking wheel with the other rear wheel so as to definitely rule out other factors should the replacement wheel have no leaking issue. I would then replace the valve and wait to see if it still leaks. If it does, I would move on to testing the rim with tire on by immersion in a water bath while holding the wheel vertically and slowly rotating wheel looking for bubbles. And don't dismiss the tire too quickly, there may well be something small embedded in it that simply hasn't shown itself to the naked eye.
    And if the replacement wheel shows up as leaking once switched, I would suspect a prankster at work. Catch'em, shoot'em, bury'em, and forget'em. Or send them a mean Valentine's Day card.:homer:
    Trooper2 likes this.
  18. Oct 21, 2019 at 2:11 PM
    TX-TRD1stGEN
    TX-TRD1stGEN Privileged
    Seth
    South East Texas
    2000 Tundra 4x4
    Just put some more Dawn soap water on that thing.
    The bubbles don't lie
    koditten and Trooper2 like this.
