Back electric sliding glass window - does not work
Discussion in '2nd Gen Tundras (2007-2013)' started by Anissa, Apr 25, 2018.
  1. Apr 25, 2018 at 7:07 PM
    Anissa
    Anissa [OP] New Member
    Anissa
    1. Hi,
      Can anyone provide some advice. I just bought a used 2010 Toyota Tundra. The back sliding glass/electric window does not work. When I press the button by the steering wheel there is no sound. Any ideas on how to fix? Or anyone else who had a window just stop working?
      The friend I bought it from said it had always worked as far as he knew, but, he did not use it much.
      Thanks! Anissa
  2. Apr 25, 2018 at 7:09 PM
    Welcome from Texas
  3. Apr 25, 2018 at 7:13 PM
    Y0TA PR0
    Y0TA PR0 Oil & Gas ⛽️
    Rafael
    2017 TRD PRO
    WELCOME!
  4. Apr 25, 2018 at 7:15 PM
    Fuse?
    15whtrd likes this.
  5. Apr 25, 2018 at 7:17 PM
    saybng
    saybng Just a member.
    Gary
    Ventura CA
    16 Tundra 1794 CM in BLACK!
    Welcome from Ventura!..I was going to say maybe the fuse aswell..
  6. Apr 25, 2018 at 7:50 PM
    duece292
    duece292 Appalachian American
    Greg
    Green Bay, WI
    Welcome from WI. +3 on the fuse. The location and size should be in your owner's manual.
  7. Apr 25, 2018 at 7:52 PM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    Welcome Anissa. I'd look for fuses first, then see if you can find the wiring.
  8. Apr 25, 2018 at 7:54 PM
    nk1794
    nk1794 Always torque to spec
    San Jose, CA
    Check the fuse.
  9. Apr 25, 2018 at 8:08 PM
    Pudge
    CT
    2015 Blue Ribbon Platinum
    Like they said. Check the fuse, could be a bad switch. Idk of the rear window had a relay , if so check the relay
    Also...
    :worthless:
    nk1794 likes this.
  10. Apr 26, 2018 at 3:40 AM
    Yeah, what he said ^^^ , let's see your ride
  11. Apr 26, 2018 at 2:50 PM
    Anissa
    Anissa
    Thanks guys - I will try to put up a photo.
    NewImprovedRon likes this.
  12. May 2, 2018 at 8:53 PM
    codeZero
    codeZero New Member
    Pennsylvania
    2018 limited black
    Trd sports grill and bulge color matched door handles and mirror trd front and rear sway bars. Trd intake, trd exhaust
    Oh oh well I​
