Ba muffler question
Discussion in 'Performance and Tuning' started by Rica25, Jan 15, 2018.
  1. Jan 15, 2018 at 4:27 PM
    Rica25
    Rica25 [OP] Got Bam? IG ......@TNDRA08
    Ricardo
    Tulare
    Anyone that has installed ba muffler have a leak between the y pipe and the stock end..........also how close the the helmholtz resonator to the bed as far as the angle ?
  2. Jan 15, 2018 at 6:57 PM
    Casper3
    Casper3 New Member
    Jay
    CT/OH
    2017 Super White 5.7 SR5 TRD off road
    Had a slight leak with the stock gasket, couldn't really hear it but condensation would drip from it and gasket was toast when I installed my 8" system. As far as the resonator there's a video on Keith's site on how to mock it up, just leave enough room so it doesn't contact the bed/spare while driving rough roads etc
    SouthBoundSteve likes this.
  3. Jan 15, 2018 at 7:02 PM
    BlueBottle
    BlueBottle not a PRO
    '16 Platinum 4x4
    See fine print
    Casper3 and SouthBoundSteve like this.
  4. Jan 15, 2018 at 7:20 PM
    Casper3
    Casper3 New Member
    Jay
    CT/OH
    Replaced with same gasket during install all is good
    BlueBottle[QUOTED] likes this.
  5. Jan 15, 2018 at 7:57 PM
    Rica25
    Ricardo
    Tulare
    I did use the new gasket Keith sent me ......I just was also wondering how much slant resonator should have
  6. Jan 15, 2018 at 8:14 PM
    BlueBottle
    '16 Platinum 4x4
    See fine print
    Mine is about an inch from the bed. It will make sense once you are under there.
  7. Jan 15, 2018 at 8:19 PM
    Rica25
    Ricardo
    Tulare
    Ok.....thanks so I need to lift mine a little higher then
  8. Jan 15, 2018 at 8:21 PM
    BlueBottle
    '16 Platinum 4x4
    See fine print
    If it fits fine and clears your spare you are fine. Don’t move it.
  9. Jan 15, 2018 at 8:22 PM
    Rica25
    Ricardo
    Tulare
    My concern is not having enough slant to not let water sit in resonator
  10. Jan 15, 2018 at 9:41 PM
    Rica25
    Ricardo
    Tulare
    How does the 6 inch ba muffler sound with resonator installed compared to 8 inch with out resonator?
  11. Jan 16, 2018 at 9:28 AM
    dirtydeeds
    Keith
    USA
    more than I can list here
    Just a very slight slant is all that is needed.
    15whtrd likes this.
  12. Jan 16, 2018 at 5:00 PM
    15whtrd
    15whtrd Mr. Blonde
    The resonator is just to limit the drone inside the cab. It shouldn’t affect how loud it is outside. If it does it’s negligible.
  13. Jan 16, 2018 at 5:05 PM
    dirtydeeds
    Keith
    USA
  14. Jan 16, 2018 at 5:12 PM
    UTTundra
    UTTundra New Member
    Lou
    Utah
    The difference will be subtle. If you had a chance to compare back to back, you could hear it, but it's subtle. The 8 w/out resonator might have a somewhat deeper tone with normal driving, but obviously more drone at highway speeds.
