Axle swap
Discussion in '1st Gen Tundras (2000-2006)' started by Rstj, Feb 4, 2019.
  1. Feb 4, 2019 at 9:02 AM
    Rstj
    Rstj [OP] New Member
    Ronald
    2004 toyota tundra quad cab sr5
    Does anyone know if I can swap a 2004 Toyota Sequoia Rear Axle Assembly with 4:10 gears into a 2004 tundra with 4:10 gears. My axle is rusted bad and needs to be changed before something happens and was hoping this is possible to do because they have rear disk brakes. Thanks
  2. Feb 4, 2019 at 9:04 AM
    15whtrd
    15whtrd Mr. Blonde
    It’s possible but you’re going to have to change all the mounts because the Sequoia has coil springs in the back. Welding will be involved. I’m sure somebody around here has done it, maybe they will chime in and give you some advice.
    Casper421 likes this.
  3. Feb 4, 2019 at 9:11 AM
    Rstj
    Ronald
    Thanks I knew there would be some modifications thats not a big deal I can handle that
    15whtrd likes this.
  4. Feb 4, 2019 at 9:29 AM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    Might be easier to get a tundra axle and swap disks onto it.
    15whtrd likes this.
  5. Feb 4, 2019 at 11:33 AM
    Rstj
    Ronald
    The Toyota Sequoia Rear Axle is easier to find used then the tundra is. The mount changes are not hard to do. I,ve already found 1 complete with new rotors for 900 delivered.
