Axle question: can an axle's number of lugs be easily changed?
Discussion in 'General Automotive' started by Bought2Pull, Feb 14, 2025.
  1. Feb 14, 2025 at 5:30 AM
    Bought2Pull
    Bought2Pull [OP] New Member
    Greg
    WV
    2006 Tundra 4 door
    Tried to ask this on another website but the response wasn't very kind.
    Can an axle's number of lugs be easily changed?
    Further, how much different is the axle between an F 350 and an F 450?
  2. Feb 14, 2025 at 6:18 AM
    koditten
    Kirk
    Midland of the Mitten
    Interesting.
    Theoretically if the diameter, length, number of splines, bearing position and tone rings are the same, axles could be swapped out.
    The difference between an F350 and 450 most likely would be spring capacity.
  3. Feb 14, 2025 at 6:37 AM
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    Do F350 and F450 axles have different numbers of lugs?
    1lowlife likes this.
  4. Feb 14, 2025 at 7:05 AM
    joseph_womack
    joseph_womack @ 4x4bound
    Joe
    Louisiana
    2007 RCLB, 4WD, 4.7L V8
    3/1 Lift, 35s, Front Bumper, etc etc
    Also material of the axle would need to be strong enough
  5. Feb 15, 2025 at 3:17 AM
    Bought2Pull
    Greg
    WV
    2006 Tundra 4 door
    F350 has 8 lugs, F450 has 10.
    Now that I think about an axle, seems the hub is pretty integral.
    Cpl_Punishment likes this.
  6. Feb 15, 2025 at 7:59 AM
    snivilous
    snivilous snivspeedshop.com
    SW UT
    300k+ Supercharged 2008
    Yes, pretty common depending on the axle. The unit bearings on my F250 axles are drilled for 8x170 and 8x6.5, and I can buy quite a few other sizes and I think even blanks. Can a F350 hub be converted to a 10 lug pattern? I don't see why not, but not sure if that's a readily available off the shelf product. For unit bearing and full float axles it's pretty easy to do generally speaking.
  7. Feb 15, 2025 at 8:18 AM
    Better question is, what are you trying to accomplish?
    1lowlife and Cpl_Punishment like this.
  8. Feb 15, 2025 at 8:28 AM
    Bought2Pull
    Greg
    WV
    2006 Tundra 4 door
    There is an F450 dump truck I may be able to buy and it appears to have been a 4x4 at some point. I was wondering if it could be a 4x4 again as I came across an F350 being parted out that has 4x4.
  9. Feb 15, 2025 at 9:23 AM
    Way easier to find the F450 axle for the swap.
  10. Feb 15, 2025 at 9:27 AM
    Bought2Pull
    Greg
    WV
    2006 Tundra 4 door
    Oh I'm sure it is. I wouldn't be doing any of the work, hire that done. No facility and definitely no spare time for such.
    It was just an idea I was tossing around.
  11. Feb 15, 2025 at 9:28 AM
    I might swap a 450 into a 350, but not the other way around.
  12. Feb 15, 2025 at 9:40 AM
    Bought2Pull
    Greg
    WV
    2006 Tundra 4 door
    OK, probably most agree with you.
