Axle leak
Discussion in '1st Gen Tundras (2000-2006)' started by duggie_208, Dec 26, 2024.
  1. Dec 26, 2024 at 9:47 AM
    duggie_208
    duggie_208 [OP] New Member
    2002 Tundra
    None
    What axle is this? It's not the CV, correct? What all do I need to order to repair it? Thanks!!
  2. Dec 26, 2024 at 9:58 AM
    Red&03Taco
    Red&03Taco YUT
    Jerad
    2018 Platinum Tundra, 1997 FZJ80, 2003 Tacoma SR5 V6 5Spd
    That's your tie rod/steering rack. The inner tie rod connects to the rack right under that boot (known as a bellow).
    Unless there's an oil source dripping down onto that bellow, then you have a leaking steering rack, and the rack will need replacement or a rebuild.
  3. Dec 26, 2024 at 10:52 AM
    Just adding to that already-great reply:
    If it's a seal leaking inside the rack, a seal conditioner like AT-205 may shore up the leak. I had a similar leak on the driver's side of my rack after lifting, and after about 600 miles, I haven't seen any evidence of new leaking.
    That said, these 1st gen trucks are known to leak at the power steering lines above this spot, passenger side. And are absolutely freaking notorious for valve cover leaks dripping on everything below, it's something that always seems to happen once the truck is 10-15 years old if the valve cover gaskets and/or their hardware aren't replaced.
    With how wet that appears on the top half of that spot, I'm very skeptical this is your rack leaking. Seems more likely something above it is leaking. Dig around, take some photos and post them up.
    BroHon and duggie_208[OP] like this.
  4. Dec 26, 2024 at 11:12 AM
    duggie_208
    2002 Tundra
    None
    Thanks for the info. I will look a little closer and see.
    shifty` likes this.
  5. Dec 26, 2024 at 1:15 PM
    bfunke
    bfunke Tundra Curmudgeon
    South Carolina
    Look at the high pressure hose above this where the clamp holds it to the frame.
    duggie_208[OP] likes this.
  6. Dec 26, 2024 at 1:19 PM
    duggie_208
    2002 Tundra
    None
    I will. Thanks a bunch!
  7. Dec 26, 2024 at 1:20 PM
    We just want to help you fix the issue! No judgment here. Come with more questions, drop some pics. Lots of people on this forum know the weirdest details about these trucks. You'll get a lot more help here, more accurate help, than you'll find on Facebook groups.
  8. Dec 26, 2024 at 3:26 PM
    Desert Dog
    Desert Dog Nobody rides for free
    2001 SR5 AC 2WD 4.7l
    Bilstein 5100's, SPC UCA's, ATS HD leaves
    Just to ad to your statement on the helpfulness of the forum members, there isn't a single thing I haven't gleaned from here that hasn't helped me. I've never had to go anywhere else in nearly 4 yrs of ownership. Fantastic group with a common passion.
  9. Dec 27, 2024 at 5:32 AM
    FishNinja
    FishNinja HIDE YOUR DAUGHTERS
    Lee
    TEXAN....big surprise
    06DC2wd
