Axle angles
Discussion in 'Suspension' started by TXRailRoadBandit73, Aug 15, 2016.
  1. Aug 15, 2016 at 10:01 AM
    TXRailRoadBandit73 [OP] YOTAS,RAILROADIN',RÖKnRÖLLN',BEER,MAX/GEMMA
    Any one out ther have a 4" lift with 2" rear blocks I would like to see some photos of your CV axle angels
  2. Aug 15, 2016 at 10:26 AM
    2" rear blocks...
    No Bueno.
    zcarpenter92 likes this.
  3. Aug 15, 2016 at 10:45 AM
    Large
    Large New Member
    Nothing wrong with blocks in the rear for a street queen .. you still have the same payload and ride quality, only downside is axle wrap which should be non existent on road
  4. Aug 15, 2016 at 11:04 AM
    Mike Tread lightly.
    south carolina
    Few states blocks are now illegal now.
  5. Aug 15, 2016 at 11:18 AM
    No axle wrap on the road (or pavement) huh?
  6. Aug 15, 2016 at 11:20 AM
    Large
    Large New Member
    Maybe if you floor it everywhere, Tundra leafs are stout. Don't get me wrong, I don't recommend blocks to anyone, but they are cheap, give rake with minimal downsides especially on pavement
    @Mike
    did not know this, got a link?
  7. Aug 15, 2016 at 11:22 AM
    Large
    Large New Member
    I wheeled the piss out of rear lift blocks for 2 years, only downside was the ride sucked .. and even when I ditched the block and used an AAL there was more axle wrap than with the blocks. Firsthand knowledge, not hearsay.
  8. Aug 15, 2016 at 11:49 AM
    So which one is it? You contradict yourself. Does the ride suck or is it like factory ride?
    The reason you had more axle wrap after two years of wheeling the piss out of it is most likely the damage is already done from the blocks. An add-a-leaf is not going to help damaged springs, u-joints failing since your pinion angle is going straight up.
    Toyota springs are not known for strength...LOL.
    Look at this video. This is a Jeep with axle shims to correct pinion angle. Look at the spring before the axle when it flexes. The spring is worn and has other areas to look at as well. Oh, notice the pavement...
    Here is another great video. Look at all the nice thin leafs stacked up high to get a lift. With the nice flexy springs, big tires and V8 power, look at that pinion go up and he is going to break u-joints and drop shafts.
    Here is a nice video of 4" blocks on a diesel. I love diesels since it is so easy to see the problem and how to fix it.....traction bars.
    Axle wrap is not something you are getting away from on a spring over axle leaf spring unless you are adding a traction bar setup or go to a linked suspension. Axle wrap is minimal on a factory truck and is in the limits of the u-joint so they don't self destruct all the time.
    I get it, most people do not want to invest the money in lifting a truck right. It takes a lot, especially when you start going over 4" regardless of make. Geometry gets a little more tricky to get right.
  9. Aug 15, 2016 at 12:33 PM
    Large
    Large New Member
    The ride sucked period, blocks on the back, spacers up front. Damage was done? Where did I say I used blocks and an AAL on the same truck? I like how you have non-Toyota videos backing up your claim. Also the second video, the guy was power braking .... :facepalm:
    Have you run blocks in the back, or are you listening to everyone on the internet? What do you suggest the OP do? Link his truck? That's comical. New leaf pack? But the second vid you posted he doesn't have blocks and he still has axle wrap.
    I wheeled with blocks on an 2006 taco, aal on a 2011 taco, new leaf pack on a 2012 taco. Obviously a new leaf pack is your best bet but they aren't cracked up to what they should be either. Squeak after 20 miles, leafs get out of alignment, bushings are shit unless you spend the money for delrin bushings right off the bat and all for them to get seized up after a year and have to cut them out cause there are no zerks to grease them with and depending on what pack you get you have to have weight in the bed for a comfortable ride. You can get a shop to make you some steel or poly lift blocks for $50? and billet ones for $100, put them on and good to go. Yeah linking the rear end would be the best thing period, but it's also expensive as hell if you want it done right, and to get the right height you want and what you normally carry in the bed (I usually have 150 lbs of tools / equipment) is trial and error. Blocks work for 90% of people who want a lift.
    Lee's rig likes this.
  10. Aug 15, 2016 at 12:34 PM
    Mike Tread lightly.
    south carolina
    http://www.liftlaws.com
    Click on your state and see what is legal and not legal... If you have inspection stations they pay close attention to what you have done..
  11. Aug 15, 2016 at 12:36 PM
    Large
    Large New Member
    I looked and couldn't find anything saying rear lift blocks are illegal. I did see several states saying front lift blocks are, and rear having a height restriction.
  12. Aug 15, 2016 at 12:48 PM
    Mike Tread lightly.
    south carolina
    If your state you live in has no marks about blocks then who cares about other states. It all comes down to your state you live in. This site is NOT UPDATED constantly.. laws change.. always best to ask DMV/DOT to confirm...
    Btw: blocks are not DOT APPROVED.. if the cop wants to be ass, ticket for improper equipment..
  13. Aug 15, 2016 at 12:52 PM
    mudsweatngearz
    mudsweatngearz New Member
    Grant
    Arizona
    2016 Limited TRD CM 2016, Tacoma TRD Sport, 2005 Tacoma TRD Sport
    Window tint
    I have never ran axle angels but I have run axle devils
    tomsinamerica likes this.
  14. Aug 15, 2016 at 12:52 PM
    Large
    Large New Member
    well I advised against them, just saying they aren't as shitty as everyone makes them out to be
  15. Aug 15, 2016 at 12:58 PM
    Mike Tread lightly.
    south carolina
    You sure?
    Calling the kettle black..
    They are not dot approved..
  16. Aug 15, 2016 at 1:16 PM
    Large
    Large New Member
    uhh yeah?
  17. Aug 15, 2016 at 1:27 PM
    I don't need a toyota leaf spring to show axle wrap. Really? Don't be retarded. You didn't say if you used lift blocks and AAL on the same vehicle. A smart person with limited information can only guess. Last week I bumped my head and no longer have the ability to read minds, so you will have to mention that in the future ok Chief. Hoping that this gift comes back next week after a few beers.
    The 2nd video he is going over a parking block, but anyway you look at it, does that not show axle wrap and the effects? Does it not? It also shows what big leaf packs do. I posted it for your education.
    No I do not run rear blocks unless they came from the factory that way. I have been off-roading long enough to understand what happens to leaf springs and why nobody runs them....that are doing anything more than the average off-roading trails.
    I gave him options in PMs. Would I link a Tundra? No, unless I was doing hard core desert racing and wanted huge amounts of travel. I would do CB +3 shackles and then look to do leaf pack upgrades.
    Blocks are not the all evil suspension mod, you just have to add a few things to make them work...which most do not. One has to do the same thing with lift spring packs too (as the second video I posted clearly showed...and you missed).
  18. Aug 15, 2016 at 1:38 PM
    Mike Tread lightly.
    south carolina
    You said nothing wrong with blocks correct? Yes or no answer..
  19. Aug 15, 2016 at 1:53 PM
    Large
    Large New Member
    just having a discussion, no need to get your panties bunched .. op made his decision already more than likely anyway
    yes that's correct .. as far as them being not dot approved, can you provide a link like you failed to last time? Some trucks come with a block from the factory
  20. Aug 15, 2016 at 1:56 PM
    Oh I don't get mad. It is a website dude. Take it or leave it. It matters not to me. Been laughing for hours.
  21. Aug 15, 2016 at 1:57 PM
    Large
    Large New Member
    I wouldn't say I've been laughing but a good chuckle every now and then. What did you tell op to do
  22. Aug 15, 2016 at 2:11 PM
    Mike Tread lightly.
    south carolina
    Are the blocks STAMPED DOT approved?
    If the blocks are NOT STAMPED DOT they are NOT approved for Highway use..
    End of story..
    Edit find me a block that's dot approved I'm waiting...
  23. Aug 15, 2016 at 2:16 PM
    Large
    Large New Member
    you're the one that brought up the blocks being not DOT approved and I wanted some proof, and you've failed to provide it again. Just admit you're wrong man .. lol
  24. Aug 15, 2016 at 2:30 PM
    Mike Tread lightly.
    south carolina
    Prove me wrong, that they are dot approved to say they are if they are from the factory, I want to see the stamp... NO PROOF YET.. STILL WAITING.. you failed
    Until you show me a block with a dot stamp. STFU ... Im WAITING.. you failed again..
    This comes from a guy that's bipolar #3 post says blocks are Ok them says they aren't the say hey are ok again.. REST MY CASE..failed again.
    Three strikes man I'm done.. go have fun.. talking to yourself...
  25. Aug 15, 2016 at 2:41 PM
    Lee's rig
    Lee's rig Party naked
    Lee
    North nj
    2014 DC and 2014 single cab both 8' bed with 5.7
    To many
    I run blocks ,. Yes mostly mall queen, even tho I don't go to malls ever. 3/2 ready lift. No problems in 20,000 miles. Quick, easy, cheap. I hate that everyone says the suck. They are perfect for what I need. I have seen your perfect set ups fail. All those king shocks and so forth. I have seen more failures posted about them than blocks. Shit my rear driver's side shock failed even before the blocks. As for a axle wrap, I have it on my single cab, that has no lift or blocks and it is far worse than my DC with the blocks . Once again I do not off road much and when I do it is an trails that is low speed! If I wanted to beat the shit out of a truck I would by a beater and tow it with the tundra. Don't get me wrong I use my trucks but to have fun off roading I need a dedicated ride
  26. Aug 15, 2016 at 2:46 PM
    Lee's rig
    Lee
    North nj
    To many
    I don't have any larger bump stops or straps for front orrear which will help prevent failure will spacer lifts. Most failures with spacer lifts is due to not installing larger bump stops or limiting straps new Jersey only cares about emissions for cars that don't care about anything else
  27. Aug 15, 2016 at 3:30 PM
    I have honestly never seen a king/fox/ads shock fail on a Tundra with pretty hard use. I have seen springs break....
    I will be rebuilding a 14" King 2.0 RR shock this weekend. After 6 long years of beating the shit out of it without limit straps it has taken its toll on it.
    Hope there is no shock body internal damage, but I will remain optimistic until we get it apart. I think the retaining clip popped out due to not having limit straps. We'll see.
    It is up to the user on what to use. Just because it is marketed and sold doesn't make it a great product. Cheap usually is just that and for the same reason stuff fails over time.
    Mike and bandit like this.
  28. Aug 15, 2016 at 3:51 PM
    Lee's rig
    Lee
    North nj
    To many
    So you have to fix it. Must be broken then. I don't have 6 years yet, but I do have 3 and no problems. Visit other forums and look at all the problems they have with after market suspensions. I am just saying, stop telling people that it is wrong or it is crap. I see it in almost every forum. It works for the right situations, which happens to be alot of them. Most people get a truck and think they are off roading when in reality I already brought my 1980 chevette up that trail when I was 17. Yes I said chevette, rear wheel drive car went more places than any of my friends trucks went. Most people are going for a look, not just performance. Once again I do not argue that there are better more expensive ways to get a lift. My argument is that it isn't as bad as you say it is. When my shocks fail or need to be replaced then I will up grade. For the next 60,000 they will stay stock with the 3/2 lift
  29. Aug 15, 2016 at 4:21 PM
    mdavis
    mdavis I need a beer.
    Michael
    Rock Hill, SC
    CaptainJohnnySR5 likes this.
  30. Aug 15, 2016 at 4:28 PM
    Lee's rig
    Lee
    North nj
    To many
    ^^^^^ what say you about this topic? Let's escalate it even more.
