Awkward level height and need advice with tire sizing.
Discussion in '1st Gen Tundras (2000-2006)' started by JustGotDuals, Nov 30, 2018.
  1. Nov 30, 2018 at 10:32 AM
    JustGotDuals
    JustGotDuals [OP] New Member
    I have an awkward level height of 2.25" in the front and 1.25" in the rear to give it a small rake in my 2001 tundra 4x4. I was wondering if 285/70r17 would fit under with minimal trim and no rubbing on the uca/frame with a 4.5bs rim. (17x9 -12) If not then I may get the same rims just one inch smaller (16x9 -12 with 4.5bs) and go with 265/75r16. I want to fit the 33" but do want to do excessive trimming with frame rub. Any thing helps! I have found a couple running 285/70r17 on their rigs with just a level (spacer in front) with minor rubbing.
  2. Nov 30, 2018 at 3:16 PM
    Professional Hand Model
    Hand Protectors
    Biggest on a 16” wheel is 285/75 from personal experience as this is what I’ve had for years. Its a very slight rub on inside of frame on hard turn. No spacers or lifts.
    Not sure about 17” wheels.
    mcharfauros and jeremyd like this.
  3. Nov 30, 2018 at 3:25 PM
    JustGotDuals
    Professional Hand Model sweet lookin ride! And thanks for the input. I want to run that exact size 285/75r16 but am nervous that I may have to do extreme pinch weld trimming. But seems like you are on stock rims doing fine! Where does it rub? And what kind of back spacing do you have? Also, are you leveled? Or is that stock?
  4. Nov 30, 2018 at 4:02 PM
    Hand Protectors
    Straight stock for years (except for new this summer Bilstein 5100 shocks) on one notch up from stock height (1/4”? Higher). No spacers. You’ll be fine at that size. Just nurse your tight turns a bit or avoid them. Its only a slight rub if it happens. Not a deal breaker.
  5. Nov 30, 2018 at 4:07 PM
    JustGotDuals
    Thats awesome! I will probably go with it then, and you sound like you like it alot so its worth a shot. Where does it rub? Im just curious, is it on the frame or liner/flaps?
  6. Nov 30, 2018 at 4:10 PM
    Hand Protectors
    Inside frame. Never had an issue anywhere else. Go for it. I have the Michelin Defender Series tires. Been on Michelins for long time and very happy. What are you going with?
  7. Nov 30, 2018 at 4:12 PM
    JustGotDuals
    I like a more aggressive tire so Im thinking either Falken Wildpeak AT3W's or Atturo Trailblade XT's. Ive heard great things about those michelins though! Im just on a lower budget since Im in college right now
  8. Nov 30, 2018 at 6:53 PM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    4.5" bs and 9" width will have different results. I want a 16" wheel that way for years with 285/75 all terrains, it rubbed frame slightly and would hit the pinch weld if I am turning and hit a good dip to compress.
    A 4" bs and 8" wide rim is about as good as can be, you still may hit frame on full lock turns but nothing bad.
    Go for it, you'll trim a bit of plastic liner and bumper but it isn't visible. If you do hit pinch weld badly you can make a single incision and bang the thing inward flat. It's not a big deal.
    because_wumbo-truck likes this.
  9. Nov 30, 2018 at 6:56 PM
    JustGotDuals
    Darkness what is your set up like when you ran 285/75s? And do you know of any decent priced rims with those measurements? Im having a hard time looking for some haha mostly 4.5 bs
  10. Nov 30, 2018 at 7:05 PM
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    Rims all depends what your flavor is. I can probably find an old pic of my truck with the 9" wide wheels somewhere. I'm currently running 8" and the fit is way better.
    My truck has been modified a lot, couldn't tell you what the lift is. Guessing 3" front and 1.5" rear. Hasn't been stock for 10 years so hard to remember.
  11. Nov 30, 2018 at 7:07 PM
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    If you're really concerned go with 265/75. The height difference is minimal, they're a bit skinnier but you'll take less of a hit on MPG and you'll have absolutely no clearance problems. Plus they're cheaper.
  12. Nov 30, 2018 at 7:08 PM
    JustGotDuals
    That one clean tundra! I like it alot, and my taste is all black or black with accents of milling! 9 or 8 inch width doesnt really matter I guess
  13. Nov 30, 2018 at 7:13 PM
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    Thanks! Well 9" tends to hit the body/pinch weld. When you turn it has more swingout so it reaches farther than 8".
    Not sure if pictures show it but I've painted/scraped/painted/scraped my grille and now it isn't quite chrome. It looks like brushed aluminum.
    because_wumbo-truck and jeremyd like this.
  14. Nov 30, 2018 at 7:24 PM
    JustGotDuals
    Still looks sweet to me! Are those 255/85s??
    And thanks for all your help! I will post up what i decide on later
    Darkness likes this.
  15. Nov 30, 2018 at 7:30 PM
    Pudge
    CT
    2015 Blue Ribbon Platinum
    The shadow on the front tire makes those look like pizza cutters. I actually love that look on the gen 1s and also tacomas. I had 255s on my taco and they were great.
  16. Nov 30, 2018 at 7:48 PM
    PSYCHO WHITE TUNDRA
    PSYCHO WHITE TUNDRA Still Gonna Send It...
    Jake
    New Mexico
    White 2011 Tundra SR5 TRD (Psycho White)
    Chopped and dumped dual exhaust; 6" fully adjustable ProComp lift w/ FabTech rear shocks, 12.5x20 Pro Comp rims on 37x12.50x20 tread wright mud tires, pedal commander throttle programmer and sound system from hell which consist of Sony double din headunit, 4 Morel Maximo Ultra 603 component door speakers w/ 4 tweeters ran on a Rockford fosgate P500-4 punch amp under drivers seat then the bass comes from a custom 15” 4000rms sub made from a Skar 15” Skar basket and motor with sundown x series components made by Patrick @ Robot Underground in Mesa AZ which is powered by 2 C.A.B. Audio 2000.1D amps strapped together at .08ohm which produces just under 5000rms. Also installed 100sq.ft. 10mil dynamat sound deadening on all 4doors (both exterior and interior chambers) double layer on roof and back wall as well as inside side mirror covers and behind side mirrors
    Treadwright.com has good tires for dirt cheap. Mud and all terrain. They are remolds but that’s no big deal, they go through the complete tire process. I’ve got almost 15000 on my 35x12.50x20 10 ply and just barely showing wear. Got all 4 tires for $648.00 shipped with a 30,000 mile warranty.
  17. Nov 30, 2018 at 7:48 PM
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    285/75 16
    I considered the 255 pizza cutters but when I wanted them my wheels were too wide.
  18. Nov 30, 2018 at 7:53 PM
    Sunnier
    Sunny
    San Diego, CA
    So you're planning to do 16 wheels then, @JustGotDuals? 4bs? Check out SCS, if you can find some cheap or used. Most styles and colours are back-ordered but they're pretty!
    Darkness[QUOTED] likes this.
  19. Dec 5, 2018 at 9:21 PM
    JustGotDuals
    @Sunnier sorry I didnt know this thread I made was still going lol but Ive decided on 17x8 -19 (3.75bs) pro comp series 05 torq with 285/70r17s. Im waiting for winter to go away before I buy them though because my tires now (265/70r16s stock) are still fairly new! I think those rims will work good, what do you think? Oh and the scs are just too expensive for me, I looked haha
    Sunnier likes this.
  20. Dec 6, 2018 at 11:23 AM
    Sunnier
    Sunny
    San Diego, CA
    Yeah, expensive and not available. I was caught up trying to get a set but will probably stay with stock. Unless I can get a great deal on a used set, of course.
    I wish I could weigh in on your bs, but I haven't wrapped my head around how to figure it out. I'll probably "get it" at some point, but my brain is full of other less complicated Tundra stuff. :rolleyes:
  21. Dec 6, 2018 at 12:04 PM
    Matty4wd
    Matty4wd Young Tundra Enthusiast
    San Antonio, Texas
    2005 Tundra Limited
    I have 285/75r17 , no trimming need since i have a front bumper that doesnt interfere with tire at all. Rims are 17x9 +18 offset49C7390A-819C-4007-A063-7907148FC1B1.jpg
  22. Dec 11, 2018 at 8:24 PM
    Shellback
    Shellback New Member
    Pink/Silver 2001 Tundra TRD
    Peeling door window trim.
    What would the forum recommend on my 2001 Limited Access Cab 4WD:
    - I like Professional Hand Model's ride. 285/75/16 IIRC...?
    - Can I go a bit "thinner"?
    - I commute a bit every week. So maybe try, lol, try to get another mpg squeezed in...
    - Haven't gone off road, not yet :eek2:
    - Everything is OEM, no lift kit.
    Thanks.:)
  23. Dec 11, 2018 at 8:39 PM
    JustGotDuals
    @Shellback if you want a thinner tread then take a look at the 275s and 265s they are slightly thinner and only slightly smaller (1 inch) in overall diameter. They will get you better mpgs for sure compared to the 285s. If youre on stock suspension with alot of commute I would reccomend the 265/75r16 size. It should fill the wheel wells good while still look aggressive. Though it has been proven possible with the replies above to fit 285s (wider and heavier than 265s), your mpgs will drop about 3 mpg give or take.
  24. Dec 12, 2018 at 11:36 PM
    Rkcruza
    Rkcruza New Member
    Bob
    2002 Tundra AC 4WD TRD OR SR5
    De Badged / Decaled, Firestone Ride Rite Air Bags w/ Daystar Cups, 17" Rims, Big Brake kit w/ slotted & drilled rotors, plus lots of work related stuff.
    I agree with the 265/75's on pretty much any stock Toyota wheel (or 265/70/17's if you go 17 inch wheels instead of the 16's). I've run both on my Tundra for years with 0 issues and it sees quite a bit of off pavement stuff for work and was way loaded much of the time.
  25. Dec 16, 2018 at 5:15 PM
    because_wumbo-truck
    because_wumbo-truck TTC#036 & 1st Degenerate
    Jon
    Houston, Texas
    2006 AC Tundra Limited 4x4 v8
    flowmaster 40, DDI injectors, sliders, bumper
    I have 295/75r16 and had to trim a significant amount of the pinch weld. No spacers. I rub frame on full lock. But I alwso have toytec Boss coilovers. I forgot to measure before and after and I didn't adjust them. Not sure if I got 2.5 or 3 inches or what
    Brown Bear likes this.
  26. Dec 16, 2018 at 5:18 PM
    JustGotDuals
    @because_v8 what is your suspension and wheel spec? Any rub/mod besides the pinch weld trim?
  27. Dec 16, 2018 at 5:21 PM
    because_wumbo-truck
    Jon
    Houston, Texas
    Toytec Boss coil overs on the settings they came set to.
    SPC upper control arms
    KMC Enduro 16x8inch, 4.5 back space
  28. Dec 16, 2018 at 5:24 PM
    JustGotDuals
    Looking sweet! Any rubbing on frame?
  29. Dec 16, 2018 at 5:26 PM
    because_wumbo-truck
    Jon
    Houston, Texas
    My buddies 01 has those wheels and same tore size, but his 5100s are maxed out on lift and his tires rub the UCA sometimes. So I sold em my spacers. We still need to install em.
  30. Dec 16, 2018 at 5:30 PM
    because_wumbo-truck
    Jon
    Houston, Texas
    Yours looks so.clean without flares
