AWD Tundra?
Discussion in 'New Member Introductions' started by LTWLouis, Dec 22, 2021.
  1. Dec 22, 2021 at 8:54 AM
    LTWLouis
    LTWLouis [OP] New Member
    Louis
    2012 DCLB
    Thanks for the add! Trying to lear about an AWD Conversion for the Tundra!
  2. Dec 22, 2021 at 8:57 AM
    mountainpete
    mountainpete Explore more
    2018 Cement Crewmax TRD
    Function before sparkle.
  3. Dec 22, 2021 at 8:58 AM
    jpod
    jpod its Finally here
    London Canada
    2020 Tundra CM Cement Grey
    Diamondback HD, 1Up Racks, Yakima Bars, Garbage Weston Steps
    I think you mean auto-4WD. AWD's are on Subaru's and SUV/sedans.
  4. Dec 22, 2021 at 8:59 AM
    snivilous
    snivilous snivspeedshop.com
    SW UT
    300k+ Supercharged 2008
    Swapping a Sequoia or 200 series tcase makes it AWD too.
    @Wynnded also has a AWD conversion
    Wynnded and mountainpete like this.
  5. Dec 22, 2021 at 9:00 AM
    jpod
    London Canada
    wouldn't that make it less truck-like? I was under the impression that AWD is like Auto-4WD-Lite?
  6. Dec 22, 2021 at 9:04 AM
    snivilous
    SW UT
    I guess it depends on what you consider a truck. The Sequoia tcase allows for 2WD, AWD, and true 4WD. AWD is different than auto 4WD since it's always active, but it's different than 4WD in the fact one wheel spinning is capable where as 4WD one front and one rear at a minimum is always spinning. AWD and 4WD have the same traction/power put down up until the point a tire slips and then 4WD is better (again since one front and one rear is forced to spin), but the allowance of tires to slip (differential speed between tires) from AWD is what let's it be fine to be used onroad.
    Saltyhero13, Wynnded and jpod[QUOTED] like this.
  7. Dec 22, 2021 at 12:46 PM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    The Sequoia and LC t-cases have the ability to lock and unlock the center differential whereas the Tundra does not. In the Tundra it's always locked, that's why the system binds on high traction surfaces during turns. The Sequoia has the ability to select 2WD only just as with the Tundra, but the LC does not. The LC is in AWD at all times by default with the center differential unlocked (open) like a normal front or read differential.
    There are a dozen ways to explain it...:thumbsup:
  8. Dec 22, 2021 at 3:37 PM
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
  9. Dec 22, 2021 at 4:38 PM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Oh, and I neglected to mention that the center diffs in the Sequoia are Torsen differentials, and the "open" center aspect works in 4lo too. :headbang:
    https://en.wikipedia.org/wiki/Torsen
    Here's the write up I did for my install.
  10. Oct 24, 2023 at 6:14 AM
    Zappa
    Zappa New Member
    Switzerland
    2010 Tundra Sr5
    LED headlights. Rhino Lining
    I want my 4WD, 2010, 5,7 l, convert into permanent AWD and swap the T-case.
    Does anyone know the partnumber of the JF3A T-case from the 2008+ Sequoia?
    Seems to be one of those; 3610034190, 3610034191, 3610034192, 3610034193 but which one...
    Thanks , Zappa
  11. Oct 24, 2023 at 6:21 AM
    Welcome from NY.
