AVS suspension issues - are there any?
Discussion in '3rd Gen Tundras (2022+)' started by Kap1, Oct 6, 2023.
  1. Oct 6, 2023 at 4:21 PM
    Kap1
    Kap1 [OP] New Member
    San Francisco, CA
    Are we aware of any issues with the AVS suspension on the new Tundra's?
    What's the approximate life expectancy on these Toyota AVS / air bag suspensions? 5 years? 10 years?
    What are the common things to break with AVS/air suspension on Toyota's and how expensive does the repair get?
    Trying to decide between AVS or TRD suspension on a new 2024 Hybrid.
    Thanks!
  2. Oct 6, 2023 at 7:09 PM
    PERRY1060
    PERRY1060 Hammer Down
    Perry
    Indiana
    Blk on Blk 22 Ltd 4x4
    TRD wheels, skid plate, black fender flares, mud flaps and running boards. Pirelli Scorpion 275/70/20 Allterrain Plus tires
    The base system is very similar to the rear air suspension on my 05 Sequoia. I replaced the bags around 210,000. Also had to replace a small arm that attaches to height sensor at that time. My 22 Tundra Limited has base air suspension without the AVS. Very simple system and it works awesome. Great ride and no sag when pulling our boat. Hopefully someone else can add an opinion about AVS part of the higher trim versions of air suspension.
    Kap1[OP] likes this.
  3. Oct 7, 2023 at 5:27 AM
    DMackler
    DMackler New Member
    Dustin
    Burleson, Texas
    2023 Celestial Tundra CM TRD OR
    I haven't heard or seen anything negative, only praise for the system. It's an option I avoided due to added complexity and now I really regret not getting it. I'm going to have to add aftermarket airbags to kill the sag when towing the boat which is about the only time I drive the truck.
  4. Oct 7, 2023 at 5:34 AM
    DimSum07
    DimSum07 New Member
    Steven
    Annandale VA
    2024 Silverado 1500 LZ0
    I think its too early to tell. I would not have purchased a Tundra if it didn't have AVS b/c Tundras sag too much when towing.
    I love my AVS system, but they can be tough to find.
  5. Oct 7, 2023 at 12:27 PM
    Breathing Borla
    Northern Illinois
    Kap,
    get the avs and air bag suspension, you won’t be disappointed, rides awesome in comfort and then you can dial all the way to sport plus and let it rip, it adjusts steering , suspension, shifting etc
    the load level works awesome as well, I towed 600 miles recently , loaded the wagon and it rode perfect and was nice and level.
    these systems have been around for a long time in other models, etc,
    highly recommended, you’ll be kicking yourself later if you don’t get it again, much much better and more functional than some shocks on a trd model
    anyway , good luck in your search and the newer builds are great as I have stated before , mine is solid
    Kap1[QUOTED][OP] likes this.
  6. Oct 7, 2023 at 3:24 PM
    rdavenp3
    rdavenp3 New Member
    I have the Limited with the ride level rear air suspension and tow a a 6000 lb. camper. Works great, no sag and the truck rides very well. Towed over 5k miles this year and no problems.
  7. Oct 7, 2023 at 3:34 PM
    Ipaddick
    Ipaddick New Member
    Canada
    Platinum hybrid w/advanced package
    AVS does nothing for sag... Air bags do. Two separate systems.
    OP I have the bags and AVS and love it. I like the stiffer steering, and comfort suspension.
  8. Oct 7, 2023 at 6:18 PM
    Kap1
    San Francisco, CA
    You guys are evil... I'm now even more inclined to get the 2024 :spending:
  9. Oct 7, 2023 at 6:21 PM
    Kap1
    San Francisco, CA
    By the way, I've been looking but don't see ANY Capstone Tundras with AVS option available... It seems that dozens of capstones around me have regular suspension...
    Are they not making Capstone with AVS at this time? I mostly see platinum with avs and very few 1794
  10. Oct 8, 2023 at 5:21 PM
    pwpblue
    pwpblue My ignor list just keeps growing!
    Greensburg,PA
    2023 Toyota Tundra Platinum ADV
    I don't think the capstone comes without it.
  11. Oct 8, 2023 at 6:18 PM
    DimSum07
    DimSum07 New Member
    Steven
    Annandale VA
    I mentioned that problem in my post as well. On the Capstone / 1794 / Platinum, you need the advanced package that bundles the AVS and airbags together. I found it really tough to find AVS and the high end trims together. I settled on exterior color to get the rest of the combination right.
  12. Oct 8, 2023 at 9:09 PM
    Kap1
    San Francisco, CA
    Yep...
    I can find AVS on lots of Platinum around my area, but 1742 with brown interior is not available... Closest one is like 10 hour drive
    And absolutely no capstone with AVS/advanced package , which isn't terrible as black/white interior is a deal killer for me
  13. Oct 10, 2023 at 9:25 AM
    nodak67
    nodak67 New Member
    JR
    for someone that DOESNT tow for 99% of the time the avs imo rides worse than our 2018 platinum. comfort wallows over bumps, and normal and above it thunks way harder than our 2018 even after the TSB was done.
  14. Oct 10, 2023 at 9:29 AM
    Ipaddick
    Ipaddick New Member
    Canada
    Im assuming you’re talking about air ride, not avs.
  15. Oct 10, 2023 at 10:14 AM
    nodak67
    nodak67 New Member
    JR
    avs since i have platinum with avs+hud. the tsb helped dampen the thumps but its still worse than our 2018.
    tried to like the comfort mode but the wallowing is more annoying than running normal or higher modes and the thumps.
    edit: the load leveling really doesnt affect much when you dont tow 99% of the time from what i can tell.
  16. Oct 10, 2023 at 10:46 AM
    Breathing Borla
    Northern Illinois
    wow, you and I have 100% differing experiences, I can even fathom how someone can think a old gen rides better, wow.
    I was bottoming out at first but I had them adjust within spec and it rides AWESOME now
    Maharisc likes this.
  17. Oct 10, 2023 at 10:51 AM
    eddiefromcali
    eddiefromcali New Member
    Eddie
    2022 Tundra Platinum
    100% Stock
    I'll take an air ride truck vs leaf springs any day. Yes, off the lot the ride is too low, but once you adjust the levers, you're golden.
    Maharisc and Breathing Borla like this.
  18. Oct 10, 2023 at 10:52 AM
    Breathing Borla
    Northern Illinois
    100%, I can't believe how nice this thing rides for a truck, outstanding.
    towing/hauling was also much more stable
  19. Oct 10, 2023 at 10:07 PM
    Kap1
    San Francisco, CA
    I test drove 2024 platinum AVS couple weeks ago and it rode veeery nicely - all bumps and holes were absorbed nicely and quietly.
  20. Oct 15, 2023 at 7:40 AM
    Toytech6466
    Toytech6466 New Member
    Tracy
    Santa Cruz
    23 Tundra 1794
    If you are worried about reliability, Lexus has used very similar systems on their vehicles, and they have been highly reliable! I run an Asian Specialty/Toyota/Hybrid shop in California, and we probably do not see an issue with their system, but once a year on all the Lexus we work on!
    I am also looking for a 1794 hybrid with AVS, tow mirrors in white and the dealers can't find one. I am talking to a dealer to put in a special build request for one of their allotted Tundra's to that dealer
  21. Oct 15, 2023 at 10:35 AM
    Kap1
    San Francisco, CA
    Good to know!
    You're my completion.. Almost. I'm looking for a silver 1749 with avs, no tow mirrors!
  22. Oct 15, 2023 at 10:55 AM
    BoulderGT3
    BoulderGT3 New Member
    Glen
    2023 1794 4X4 BP/Saddle ADV Steps
    My barber has a cousin who's paperboy read on Facebook that AVS is failing left and right....
    I have AVS and I think it's one of the best features of the truck.
    doublethebass and Maharisc like this.
  23. Oct 15, 2023 at 11:07 AM
    rx3
    rx3 New Member
    So, I'm still trying to figure out this system on my Platinum. Doesn't the level automatically return to it's default level if you adjust it to your liking and it decides it's not where it should be? Is there a way to keep it at your preferred height setting?
  24. Oct 15, 2023 at 11:12 AM
    eddiefromcali
    Eddie
    100% Stock
    Adjusting the air ride levers under the truck sets the "default" higher
  25. Oct 15, 2023 at 11:18 AM
    rx3
    rx3 New Member
    I didn't know that. Pretty cool. I'd like my truck to be about an inch higher in the back. Is that something easy to do, or does a dealer need to do it?
  26. Oct 15, 2023 at 11:22 AM
    BoulderGT3
    Glen
    It works really well too. Every time I put a trailer on or >750lbs in the bed I wonder why all my pick ups didn't have this.
    The mag valve shocks also work well. They pretty much eliminate the typical empty bed skip when you hit bumps going around curves. AVS is a must do package.
    Kap1[OP] and Breathing Borla like this.
  27. Oct 15, 2023 at 11:24 AM
    Breathing Borla
    Northern Illinois
    ask Dr z to help you, he can locate trucks
    @DrZoidberg
    pwpblue likes this.
  28. Oct 15, 2023 at 11:26 AM
    Breathing Borla
    Northern Illinois
    ya I really agree , avs and air bag set up is super nice , I towed earlier this summer and it was really nice with trailer and full bed
    BoulderGT3[QUOTED] likes this.
  29. Oct 15, 2023 at 11:30 AM
    eddiefromcali
    Eddie
    100% Stock
    All you need is a 10mm wrench
    rx3[QUOTED] likes this.
  30. Oct 15, 2023 at 11:32 AM
    Breathing Borla
    Northern Illinois
    And may need to re aim the headlights as well
    eddiefromcali and rx3 like this.
