Avoid Overheating Turn Off AC Next XX Miles
Discussion in 'General Tundra Discussion' started by IowaGuy, Jul 26, 2022.
  1. Jul 26, 2022 at 5:16 PM
    IowaGuy
    IowaGuy [OP] New Member
    Arizona by way of Iowa
    2019 SR5 upgrade MGM
    In Process
    I live in AZ and there is a sign similar to this on I-17 North from Phoenix going up the grade around Black Canyon City. Summer temps here can easily hover around 110 plus. The grade is not that bad and the speed limit is 65+ on most of the stretch. With modern vehicles and properly working cooling systems is this even a thing or necessary? I have traveled this route many times in 7-8 different vehicles with my AC going and the temp gauges only went a bit above 1/2 but not even close to overheating.
  2. Jul 26, 2022 at 5:35 PM
    Azblue
    The Dirty T ( ^_^)_且
    I have never turned my AC off or had a problem. I tow my travel trailer up those hills at 65-70 with the AC on full blast in July on my way up to Williams or in your area at Dead Horse Ranch.
  3. Jul 26, 2022 at 5:39 PM
    Mr Badwrench
    Mr Badwrench New Member
    If we have to turn our air conditioning off for hot weather and 8% grades, then we purchased the wrong trucks.
  4. Jul 26, 2022 at 5:46 PM
    EmergencyMaximum
    EmergencyMaximum New Member
  5. Jul 26, 2022 at 5:59 PM
    Vizsla
    Vizsla 2 = 2.5
    It is. Next time you go up I-17 look for the burn marks on the road from vehicles catching fire. Usually transmission overheats and vents tranny fluid, everything else is hot and poof fire. We have Toyota Tundras though, AC on, hammer down, left lane.:D
  6. Jul 26, 2022 at 5:59 PM
    WBW
    WBW Resident lurker
    Bruce
    Surface of the Sun - AZ
    2015 CM Tundra SR5 2WD
    From what a trusted old-timer mechanic friend of mine told me, that comes from an earlier era where derated and underpowered engines required high RPMs to climb the grade and the A/C clutches were cycling causing premature failure combined with engine cooling issues and the need to reduce the load on the engines to keep them from overheating. Manufacturers have learned a thing or two about cooling systems since then. We now pressurize the cooling systems to rather high pressures thereby increasing the boiling point of the coolant by roughly 3°F for every PSI increment at sea level.
    I live and travel in AZ during the summer and never turn off my A/C climbing any grade regardless of the vehicle we take even when towing my trailer fully loaded.
    Vizsla and FrenchToasty like this.
  7. Jul 26, 2022 at 6:04 PM
    icodeintx
    icodeintx New Member
    Scott
    Palacios, Texas
    2021 Cement Gray Tundra SR5 CrewMax
    LED Headlights, LED Fog Lights, LED Interior lights
    I used to live there... gosh I miss it. But I think those signs are mainly for our little friends missing most of their cylinders o_O
  8. Jul 26, 2022 at 6:23 PM
    FrenchToasty
    Mo
    The SoAz….. big surprise
    Bone stock
    I’ve never had to turn mine off in all my years of traveling the basins.
    TRDFerguson, Azblue and Vizsla like this.
  9. Jul 26, 2022 at 6:36 PM
    Azblue
    What about in the valleys?
  10. Jul 26, 2022 at 6:47 PM
    IowaGuy
    In Process
    Yes, my dad was a truck driver in the later 50's and I remember him talking about vehicles limitations back in those decades. He also used to mention about having to change the timing when in higher elevations.
    MS22 likes this.
  11. Jul 26, 2022 at 6:48 PM
    FrenchToasty
    Mo
    Bone stock
    The true valleys have no issues either.
    Azblue[QUOTED] likes this.
  12. Jul 26, 2022 at 6:49 PM
    IowaGuy
    In Process
    This is one of the things that makes me wonder if I should install a trans cooler on my '19 since I occasionally pull a trailer.
  13. Jul 26, 2022 at 6:51 PM
    e30cabrio
    West Valley, Phoenix, Az.
    Boosted 2013 Sequoia TRD FAUX
    My parents used to live in Prescott Valley and I passed that sign a lot, always chuckled, left the AC on full and drove past it.
    FrenchToasty likes this.
  14. Jul 26, 2022 at 6:54 PM
    FrenchToasty
    Mo
    Bone stock
    I’ll take it out of OD but that’s about it, and not even for that reason.
  15. Jul 26, 2022 at 6:58 PM
    It's not going to hurt you to install one. If you have the time and money for it, pop it in and then you don't have to wonder. Just don't pin the thermostat. There's a silly myth that this makes it cool better, but it doesn't. It just makes it take longer to heat up the fluid to operating temps where it works best.
    ViktorG, Bammer, TXBrit and 1 other person like this.
  16. Jul 26, 2022 at 7:11 PM
    Silver17
    Eastern PA
    2017 TRD 4x4 Harrop SC
    Luckily this must largely be an issue of the past. The tundra cooling system seems quite adequate I will say (both engine and transmission) I’ve noticed no higher coolant temps or transmission fluid temps towing heavy in the dead of summer even pushing the truck on hills with the added heat of pushing around 600 horsepurrs and torque on the stock cooling system. Might upgrade to the CSF radiator one day if mine springs a leak.
    reywcms likes this.
  17. Jul 26, 2022 at 7:17 PM
    Vizsla
    Vizsla 2 = 2.5
    Lol. Do you live here and have any experience with pinning thermostat open? It’s a thing here to pin it in hot temps, and I have a few Toyota friends, they do a tiny bit of testing in the basin or valley or whatever the hell I live in.
    TRDFerguson, des2mtn, WBW and 2 others like this.
  18. Jul 26, 2022 at 7:30 PM
    EmergencyMaximum
    I take it I'm the only one to turn ac off during desperate times?
    Azblue and FrenchToasty like this.
  19. Jul 26, 2022 at 7:32 PM
    In hot temps the detriment of it staying too cool longer is reduced, but there's not a real benefit to pinning it. At least I've not seen any data to support it. If you have the data I am completely open minded on the topic, but if it actually worked better to pin it, why would it be engineered with the thermostat in the first place? Why wouldn't they recommend pinning it in hot climates? It's unnecessary.
    Say it's super hot so you want the thermostat open all the time, well it opens based on temp and if it's hot enough it will be open all the time. Pinning just makes it take a little longer to get up to the (random number here) 200* that it's going to be cooled to and run at anyway.
    Silver17 likes this.
  20. Jul 26, 2022 at 7:36 PM
    Silver17
    Eastern PA
    Like people who put their AC setpoint at 60 thinking it’s going to give them colder air, when in reality it’s nothing but an on/off switch at said temperature.
  21. Jul 26, 2022 at 7:45 PM
    EmergencyMaximum
    Well, this is a rhetorical statement, but...
    If ac doesn't cycle on and off, it gets the vents cooler and cooler vents mean less cool air is needed to cool the vents, hence cooler air coming out of the vents.
    It should technically give you cooler air, but not for the reasons you might think. Simple folk are genius!
    Vizsla likes this.
  22. Jul 26, 2022 at 7:58 PM
    Johnsonman
    Johnsonman New Member
    Austin
    Sequoia
    DIVERT not convert is what the Cap'n says....
  23. Jul 26, 2022 at 7:58 PM
    Azblue
    Do you honestly expect me to take advice from somebody that doesn't even know if they live in a valley or a basin?
  24. Jul 26, 2022 at 8:00 PM
    Azblue
    Yes, you are.
  25. Jul 26, 2022 at 8:10 PM
    FrenchToasty
    Mo
    Bone stock
    Rivers and boundaries need to be drawn……
    des2mtn, Vizsla and Azblue[QUOTED] like this.
  26. Jul 26, 2022 at 8:12 PM
    PennSilverTaco
    PennSilverTaco Encyclopedia of useless information...
    Charlie
    Central Bucks, Pennsylvania
    2010 Zombie Truck
    Please see signature!
    I think that was for older cars; I met a guy at a car show who said he had to crank his heat driving through Death Valley in the 1960s. I believe he was either in a Ford or a Plymouth, but I don't remember...
    equin and YardBird like this.
  27. Jul 26, 2022 at 8:28 PM
    TucsonTundra1794
    Anthony
    Tucson, AZ
    2023 1794 Edition TRD Package
    There's always that guy driving the 94 geo metro that is struggling to make it up the hill going 37 mph and not letting anyone pass. That signs for him.
  28. Jul 26, 2022 at 8:35 PM
    WBW
    WBW Resident lurker
    Bruce
    You are correct about the era. The early 1960s cars had a vented radiator cap and therefore atmospheric pressure. That means boil point is 212°F at sea level and somewhere around 210°F at 1200 feet. Those cars boiled over really easy. We've come a long way since then. Our engines last longer now too along with the longer oil change intervals.
  29. Jul 26, 2022 at 8:35 PM
    FrenchToasty
    Mo
    Bone stock
    So I’ve had to much fun zipping up that hill in my sisters civic, maybe to close to, to much fun. But the most fun might have been in the duramax; I deleted lots of the logged max and top speed points on my dads controller thingy after that, the old Italian tune up (@Darkness)
  30. Jul 26, 2022 at 8:41 PM
    PennSilverTaco
    Charlie
    2010 Zombie Truck
    My Tacoma boiled over once but didn't actually overheat. My truck is a 2010 with the 2.7L 2TR-FE, and more than 155K miles, and it has had no major engine work done. I found the coolant in the expansion tank to be low and filled it. This was a mistake because my coolant level fluctuates greatly with outside temperature, and there was actually plenty of coolant in the system. It literally blew the expansion tank cap open and splattered coolant all over the engine bay. I say again that my truck has never overheated., and I ended up using a medicine dropper to decrease the coolant level.
    WBW[QUOTED] likes this.
