auxiliary power outlets
Discussion in '1st Gen Tundras (2000-2006)' started by Mid-Atlantic Slots, Nov 19, 2019.
  1. Nov 19, 2019 at 12:46 PM
    Mid-Atlantic Slots
    Mid-Atlantic Slots [OP] Living the semi retired life, Life is good!
    Wayne
    Franconia Va
    2004 Tundra Dbl cab SR5 / TRD 4wd
    A few little things
    Today I added a rear camera, nothing fancy but something that will do the job. Went the easy way out and used the Auxiliary plug and when I plugged it in.. Nothing, the two on the side of the console are not working, but the cig lighter is.
    I am hoping it is a fuse, or am I wrong?
  2. Nov 19, 2019 at 1:10 PM
    BubbaW
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
    Once you check the fuse, you'll know the answer. The fuse panel by left driver knee has a door that labels the fuses on the back side. Check the 15 amp fuse labeled Power Outlet.
  3. Nov 19, 2019 at 1:20 PM
    Mid-Atlantic Slots
    Wayne
    Franconia Va
    A few little things
    LOL, that is true. And thank you for the reply. It does help knowing that info.
    BubbaW likes this.
  4. Nov 20, 2019 at 5:25 PM
    Mid-Atlantic Slots
    Wayne
    Franconia Va
    A few little things
    You were 100% correct, it wasn't even there. LOL
    BubbaW[QUOTED] likes this.
