Auxiliary “Gas” tank
Discussion in 'Towing & Hauling' started by dodoug, Apr 5, 2019.
  1. Apr 5, 2019 at 7:34 AM
    dodoug
    dodoug [OP] New Member
    Doug
    Tundra
    Hi guys, Doug here, I pull a camper with my Tundra and the small gas tank is very frustrating. You lose so much time on gas stops when traveling across the country. Transferflow no longer sells their replacement tank and all the “in bed” auxiliary tanks are labled not for gasoline. Has anybody found a good solution for “gas?”
  2. Apr 6, 2019 at 5:14 AM
    dodoug
    Doug
    Tundra
    Ron, thanks for the info. I've sent e mails requesting info. I see LongrangeAutomotive is in Australia. Shipping I'm sure will be prohibitive. I'll let you know.
    Watt maker likes this.
  3. Apr 6, 2019 at 5:36 AM
    Doug, what's your truck configuration? Year, Cab, 4wd?
  4. Apr 6, 2019 at 5:41 AM
    Stroke250 and Watt maker like this.
  5. Nov 25, 2019 at 6:23 PM
    Tundra-Canuck
    Tundra-Canuck New Member
    Les
    2014 Crewmax
    Bags, command air, flares, light bars, titan tanks
    I went to the Titan saddle tanks. Installed one on each side to the box. Not cheap, but at least I can remove them if I change trucks.
