Auxbeam vs switch pro
Discussion in 'Electrical' started by ryanw58, Dec 26, 2021.
  1. Dec 26, 2021 at 8:18 PM
    ryanw58
    ryanw58 [OP] New Member
    Ryan
    TRD Pro
    Well I need switches. Who’s got experience with these 2
    Wallygator likes this.
  2. Dec 26, 2021 at 8:25 PM
    angkorstrong
    angkorstrong New Member
    2020 Sequoia TRD Pro
    $100 vs $600
    pandapro likes this.
  3. Dec 26, 2021 at 8:30 PM
    pandapro
    pandapro New Member
    What are you adding?
  4. Dec 26, 2021 at 8:52 PM
    fisherman951
    fisherman951 MT dreams
    Tony
    2017 crewmax 4x4
    Switchpro has a ton of settings
    Auxbeam I think are just on and off
    how much do you want to spend?
  5. Dec 26, 2021 at 8:57 PM
    MadMaxCanon
    MadMaxCanon New Member
    '21 CM SR5 4x4 6 seater
    Too many, but not enough....
    Switch pro setup if you wanna do it all out will be a grand. 600 for the switch pro, 100 for the mount plate, couple hundred for the upgraded wiring and battery fuses and terminals plus taxes. Not counting install if you don't do it yourself and not counting any tools you would need to do it yourself. 10000% worth it for me for a proven product that makes life a million times easier moving forward.
    I have read more negative comments on the aux and quality but it's $100 so it's to be expected.
    bulldog93 and Wallygator like this.
  6. Dec 26, 2021 at 9:03 PM
    cctxquicksand
    cctxquicksand IG - TRDistheWrd
    Option c: trigger controller
    good middle ground between the two, been running it over a year with zero issues
    texasrho83 likes this.
  7. Dec 27, 2021 at 12:20 PM
    Vang530
    Vang530 New Member
    I have the Auxbeam for a few months now. There's nothing fancy about it, but it works and is nice. I have zero complaints. The only thing I'd want is a strobe feature like the Switch Pros, but I'm not going to pay extra just for that.
    therealjonwick and Wallygator like this.
  8. Dec 31, 2021 at 10:50 PM
    ryanw58
    Ryan
    TRD Pro
    I’m adding a few sets of lights for new front bumper and a winch eventually. But not sure how to operate the winch will probably buy a wire less one
  9. Dec 31, 2021 at 11:09 PM
    snivilous
    snivilous snivspeedshop.com
    SW UT
    300k+ Supercharged 2008
    I wouldn't say the switch pro is a grand, all of those "added costs" listed above is what's needed to run any accessories so isn't mutually exclusive to the switch pros. If anything the switch pro eliminates those costs due to not needing fuses or relays or extra wiring in most cases. As for the winch, you should be able to tie into the control port just like the handheld or wireless controller does to control it. I have a switch pros on my UTV and got it because it's extremely versatile and is internally fused and can pump a lot of power out. Can't speak to the auxbeam controller, but it sounds like a typical cheap Chinese unit. If you want quality go with the switchpros, if that doesn't matter to you and you just want switches go with the auxbeam.
    Wallygator, shellshock and 831Tun like this.
  10. Jan 7, 2022 at 12:14 PM
    rdiddy5
    rdiddy5 New Member
    Ryan
    Arizona
    2018 Crewmax 1794 4x4
    I've got the 6 switch Auxbeam in my truck, had it in my 4runner before for 2+ years. Installed an 8x Auxbeam switch on my neighbors truck. They have worked just fine.
  11. Jan 8, 2022 at 2:17 PM
    eick
    eick New Member
    2020 CrewMax TRD Off Road
    I got the voswitch on Amazon and it has a little more than on/off, can strobe etc. nothing fancy though
    RobertD likes this.
  12. Jan 19, 2022 at 11:42 AM
    coTony
    Tony
    Montrose, CO
    At SwitchPro has a hefty price tag and the main harness from the power module to the lights are not long enough to reach my panel area. I hate adding a few inches to a wire just to reach where it terminates, makes a mess if all 20 wires have to be extended
  13. Jan 19, 2022 at 11:49 AM
    alb1k
    Left Coast
    05 2WD DC w/ attitude
    It's good
    Those wires were never intended to be full runs. Depending on the load and the distance to the accessories(s) you run your own wires of appropriate gauge. It's why many attach those wires to a terminal block for ease of adding stuff.
  14. Jan 22, 2022 at 11:06 AM
    coTony
    Tony
    Montrose, CO
    a few inches short… missed it by that much. The 4 pin cable is much longer for some reason
  15. Jan 22, 2022 at 11:11 AM
    alb1k
    Left Coast
    It's good
    Are you talking about the ign, trigger, tail light trigger wire, or the accessories you are attaching (like bajas, scene lights, etc)?
  16. Jan 22, 2022 at 11:17 AM
    coTony
    Tony
    Montrose, CO
    I am talking about the 20 pin connector. The triggers, blue and white are all fine.
    It is what it is
    Wallygator and alb1k like this.
  17. Jan 22, 2022 at 11:18 AM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    Switch Pro is a small mom & pop business down in San Diego. When I've called I've spoken to the developers wife. They're friendly and helpful. I'd much rather give them my money, have no problems and support an American company as opposed to giving money to a faceless overseas conglomerate. Actually contacted Aux one time too. The response, as I recall, was curt and somewhat offensive. But, that's just my experience.
  18. Jan 22, 2022 at 11:30 AM
    alb1k
    Left Coast
    It's good
    I think next time I wire a switchpros, instead of a tray, Ill just run all the power accessories wires into one of these and make the connections in there.
  19. Jan 22, 2022 at 11:33 AM
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    Nice and compact, what's the amperage rating?
  20. Jan 22, 2022 at 11:35 AM
    alb1k
    Left Coast
    It's good
    I don't think it's even rated because each connection is on a single post, at least I haven't seen any amp ratings on these.
  21. Jan 22, 2022 at 11:39 AM
    alb1k
    Left Coast
    It's good
    The other thing you could do is run the wires into an empty box like this, and just splice them together like switch pros wants you to do anyway. Gives you a place to hide the not connected yet wires and hides the connections as well.
  22. Jan 22, 2022 at 11:46 AM
    coTony
    Tony
    Montrose, CO
    I don’t mind spending my money there but they were not interested in selling a longer cable. Could be an option when you buy. My total was 32” needed so not even 3 feet
  23. Jan 22, 2022 at 11:48 AM
    coTony
    Tony
    Montrose, CO
    That looks like a nice box, where did you find that one? The 9100 I had on a terminal block because the wires determined which switch it went to but the RCR-Force 12 is programmable
  24. Jan 22, 2022 at 11:50 AM
    alb1k
    Left Coast
    It's good
  25. Feb 7, 2022 at 4:33 PM
    NueveTundra
    NueveTundra Mod list in Bio
    Planet Earth
    07, Black Tundra SR5 CrewMax
    Doesn't the universal Switch Pro come in like 7 different harnesses lengths?
  26. Feb 8, 2022 at 8:16 PM
    coTony
    Tony
    Montrose, CO
    If they do then I was shut down immediately when I asked. I was told they could not do that and I offered to pay. Funny the high amp wires are much longer than the lower amp wires and all part of the same harness or at least end up in the same harness
  27. Feb 8, 2022 at 8:49 PM
    BiggHertz
    BiggHertz DZTLIMO
    Chandler, AZ
    IG: dztlimo
    Stuff and Things
    with the exception of the trigger inputs, all outputs are same length of 14 awg TXL wire.
    If you want a “seamless” install, the connector is a Molex MX 150 Sealed connector and you can depin, and create your own pigtails if desired?
    I want to be helpful here, just not following along with what the issue is here?
  28. Feb 8, 2022 at 8:51 PM
    coTony
    Tony
    Montrose, CO
    I was not interested in adding 3” of wire to each of them. I asked for that from SwitchPros and that would void my warranty I was told
  29. Feb 8, 2022 at 8:53 PM
    BiggHertz
    BiggHertz DZTLIMO
    Chandler, AZ
    IG: dztlimo
    Stuff and Things
    interesting, because in-order to pass the control panel cable into the cab, the instructions tell you to de-pin the 4 pin controller cable.
  30. Feb 8, 2022 at 9:24 PM
    alb1k
    Left Coast
    It's good
    I ran my controller up the the overhead console and have a fair amount of extra loom above my headliner. Granted, my switchpro is mounted near the firewall. Is yours mounted by the headlight?
