Aux port in 2006 limited tundra
Discussion in 'General Tundra Discussion' started by 1stgentundradriver, Dec 2, 2020.
  1. Dec 2, 2020 at 1:54 PM
    1stgentundradriver
    1stgentundradriver [OP] Each sticker adds at least 5hp
    Josh
    Silverdale Washington
    2006 DC 4x4 Limited
    A few
    Hey all I really need some help figuring out the sound system on my first Gen. I swear there’s a way to use an aux port in it without swapping head units just with a cord. Really needing some help as this is starting to get frustrating. I purchased a cord that goes in the rear audio inputs (red and white) and can’t get this to work either. I’m at my wits end.
  2. Dec 2, 2020 at 2:01 PM
    1stgentundradriver
    Josh
    2006 DC 4x4 Limited
    A few
    I do have the JBL system in the truck as well. With the navigation system.
  3. Dec 3, 2020 at 2:26 AM
    artsr2002
    artsr2002 2005 Tundra DC SR5
    'Yonder
    Post a pic of your headunit. Is it the factory Toyota headunit? I am not familiar with any red/white inputs on the back of those. My 05 DC had CD unit from factory but no JBL so maybe the JBL unit does have RCA inputs on the back? Pics will help us help you out better.
    Tundra2 likes this.
  4. Dec 3, 2020 at 8:49 AM
    DIYDad
    DIYDad New Member
    2020 Tundra 1794
    Dating myself here, but my first tundra had a tape deck. I used an adaptor to plug in my iPhone, and it worked great.
  5. Dec 3, 2020 at 9:15 AM
    1stgentundradriver
    Josh
    2006 DC 4x4 Limited
    A few
    I will post in a second. I have the big sorta clunky touchscreen and it has two CD players behind it as well as the DVD player in the center console. Give me a couple mins and I’ll have come pics. The two plugs I used are on the back of the center console.
  6. Dec 3, 2020 at 9:57 AM
    1stgentundradriver
    Josh
    2006 DC 4x4 Limited
    A few
    Also yes, it is the factory head unit.
    I’m pretty cheap just so you guys know but I would be willing to pay for something that works. However the cheapest solution would be best.
  7. Dec 3, 2020 at 7:46 PM
    artsr2002
    'Yonder
    That headunit pic doesn't help much. Can you post a clear one up closer? I think I found a similar headunit on eBay and will try to find info in the manual for it to see about getting the rca input working.
    1lowlife likes this.
  8. Dec 3, 2020 at 9:09 PM
    1lowlife
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    I think this is it...
  9. Dec 3, 2020 at 9:16 PM
    artsr2002
    'Yonder
    That's the same one I found but I haven't been able to find anything regarding those audio/video jacks in the console. I think, I think they may be part of the entertainment system with video screens for the DVD player. I'll keep looking.
  10. Dec 3, 2020 at 9:41 PM
    RainMan_PNW
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    You have a rear DVD unit? Those audio jacks are for the rear seat entertainment to play sound if you hooked up a video game console for the kids in the back seat.
    my guess is that to hear audio from them you may need to switch the head unit over to the DVD or RSES (rear seat entertainment system) setting if it has one or the other. And not sure how that works if you’re trying to use Nav or anything else (or how it works with when driving).
    you should be able to get the manuals here:
    https://www.toyota.com/owners/resources/warranty-owners-manuals/tundra/2006
    You might need to use the remote for the DVD system to set it/switch it to the right settings
  11. Dec 3, 2020 at 10:21 PM
    artsr2002
    'Yonder
    Found some info but not much. The way I'm reading it, I feel those a/v inputs are only for an a/v device that would play back video on the rear screens and audio through the headphone jacks on the back of the console near the a/v inputs. For example, kiddoes playing a nintendo gaming system on the back screens and listening to the audio on the headphones connected to the headphone jacks. I don't think the a/v inputs are wired to play sound through the front speakers. That's a bummer. Then again, it does appear to be part of the Rear Seat Entertainment System.
    I saw somewhere else where it mentioned pressing the DISC button on the headunit faceplate but that may be just for the DVD player already in the console not those a/v inputs. Not sure.
    As for a possible alternate solution I refer you to this post:
    https://www.tundras.com/threads/upg...hout-losing-factory-functions.783/#post-16309
  12. Dec 3, 2020 at 11:25 PM
    1stgentundradriver
    Josh
    2006 DC 4x4 Limited
    A few
    Sorry all for the late response. Had a pretty busy day. Sorry about the head unit pic @artsr2002 and yes @1lowlife that is my head unit. @RainMan_PNW I do have the rear entertainment system. I was hoping those cords to the back would work.
    as for pressing disc, it doesn’t work. I’m pretty sure I’ve tried every possible thing without removing anything. @artsr2002 I will look at that post. I will let you all know what happens. Thanks!
  13. Dec 20, 2020 at 4:57 AM
    abcinv
    abcinv OEM (+) Junkie
    Tommy
    South of ATL
    2006 Tundra 4X4 Limited Dbl Cab
    Pretty late here but believe if you want AUX you'll need to add an adapter to the back of the head unit; something like a GTA kit (assuming you have an unused plug for a CD changer on the back of the head unit). I use the GTA kit and am happy with it. It provides BT, hands free call receiving (with a mic), an AUX and a USB charger. And you still retain the steering wheel controls.
    I have the cheaper version of the Rear Entertainment system (called Rear Seat Audio) that allows me to listen to one source up front and the backseat passengers a different source thru headphones BUT both sources come from the head unit already (FM, CD, cassette).
    Good luck!
  14. Dec 20, 2020 at 5:40 PM
    1stgentundradriver
    Josh
    2006 DC 4x4 Limited
    A few
    I will look into that! Thank you very much @abcinv!
