Automatic Truck starter
Discussion in '2.5 Gen TRD Pro (2014-2021)' started by Kdub4life, Jan 11, 2021.
  1. Jan 11, 2021 at 6:54 AM
    Kdub4life
    Kdub4life [OP] New Member
    2019 Toyota tundra trdpro
    I live in northern NY. Have to have a truck starter. Any suggestions out there on which brand or style is the best?
    Bad Cow likes this.
  2. Jan 11, 2021 at 7:04 AM
    Fiesta346
    Fiesta346 New Member
    PA
    2013 Rock Warrior
    Have used compustar on many vehicles including my tundra no complaints
  3. Jan 11, 2021 at 7:09 AM
    Bad Cow
    Bad Cow GOD Bless The USA
    Georgia USA
    2019 TRD PRO - SUPER WHITE
    Leather Steering Wheel, +1.5" Shackles
    I assume you are referring to Remote Start? There's this cool thing out there called The Internet. If you go onto this thing, you can search for things, anything. And more than likely you will find what you are looking for. Had to go there with you buddy, please don't be offended. There are lots of aftermarket remote starting systems out there. Found this one in less than a minute on Amazon. Good luck.
    Amazon.com: Start-X Remote Starter For Toyota Tundra 2018-2020 || Plug N Play || Lock-Lock-Lock to Remote Start || ZERO WIRE SPLICING!: Car Electronics
  4. Jan 11, 2021 at 7:20 AM
    Randy Morton
    Randy
    Deepinahearta, Texas
    2012 Tundra Double Cab (I call it my Land Yacht)
    I have a Viper alarm/remote start on mine and I'm very happy with it. I also had one installed on my daughter's car and it's also working fine. If you decide on a viper system, you can find an authorized dealer here: https://www.viper.com/wheretobuy/
  5. Jan 11, 2021 at 7:29 AM
    timsp8
    NY
    I got a compustar from a local installer. I like it because I can still use the fob to unlock the doors and it doesn’t shut the engine off when opening the door.
  6. Jan 11, 2021 at 1:43 PM
    drewpweinerMD
    drewpweinerMD MPG’s are for your moms Prius.
    Jeremy
    2024 Limited TRD OR
    RB20 Slims, BAK X4s, Fabtech Level, Cooper 35's
  7. Jan 11, 2021 at 2:10 PM
    I have a Compustar, no issues.
  8. Jan 11, 2021 at 2:21 PM
    xdmelarton
    xdmelarton New Member
    Richard
    2017 Tundra TRD Pro CM
    I have the Tech12volts plug and play and works off your factory fob. I followed his youtube instruction video and was installed and working in an hour. Also does not shut off when you open the door. I have had mine installed a few months and no issues.
    Uhhhh.... likes this.
  9. Jan 11, 2021 at 2:40 PM
    AlmightyCrash
    AlmightyCrash Tundra Rookie, Jeep Veteran
    Crash
    San Leon, TX
    2015 Tundra MGM SR5 TSS CrewMax
    I’ve had the Start-X remote start for over a year with no problems. Works every time. Plug and play. Factory fob...just press lock button 3x.
  10. Jan 11, 2021 at 2:56 PM
    jalam321
    jalam321 New Member
    2018 Tundra CM Platinum 4x4 and Sequoia Platinum 4x4
    I've always used Viper, Clifford (DEI products) for over 10 years in all my cars. Always been happy with them and no complaints.
  11. Jan 11, 2021 at 3:05 PM
    Uhhhh....
    Uhhhh.... New Member
    Dave
    2016 Silver Limited DC
    7” BDS, 37s
    I have a Fortin from tech12volts for about a year & half. Love it. Got it with the long-range remotes. They're great. Best part is James at tech12volts - his customer service is fantastic. Maybe he'll have another group buy - that's when I got mine. @james@tech12volts
    xdmelarton[QUOTED] likes this.
  12. Jan 12, 2021 at 12:59 PM
    DIYDad
    DIYDad New Member
    2020 Tundra 1794
    For any of you who have installed aftermarket starters and it DOES NOT turn off when you open the door - is that on a push-to-start vehicle or a key start?
    It occurred to me the other day that it would be awfully easy to leave home without my keys and get stranded at my destination when I couldn't restart the truck.
    (I changed clothes after remote starting, and in doing so, left my keys on counter. When the truck turned off, I had to go back inside to get my keys). For the first and only time so far I was thankful for the shut-off "feature".
  13. Jan 12, 2021 at 1:05 PM
    Mr. Wasteland
    Mr. Wasteland New Member
    2013 Tundra crewmax platinum
    N2DesignsInc likes this.
  14. Jan 12, 2021 at 1:05 PM
    APalmTree
    APalmTree Sometimes helpful
    Brandon
    SW Washington
    A few... Definitely more than 2
    I have a starter that does not turn off when I open the door but as you mentioned, I have a key. I think the door shut off is specific to a push to start for the exact reason you have in your post. My truck will only shut off if I put my foot on the brake and try to shift out of park without the key in the ignition and in the on position.
  15. Jan 12, 2021 at 1:08 PM
    Mr. Wasteland
    From what I've seen the push to start equipped trucks will still shut off when you open the door with an aftermarket remote starter(I know the N2 designs does).
  16. Jan 14, 2021 at 9:53 AM
    Kbar691
    Kbar691 Hmmm
    Kenny
    2019 TRD Pro
    I have a brunette. It works every time and has never failed me.
    tttrdpro likes this.
  17. May 26, 2021 at 4:40 PM
    MochiBella
    MochiBella New Member
    2021 Tundra PRO
    Any chance you have one built in like the 2021s do?
