***Automatic Traction Control Disabler***
Discussion in '2.5 Gen Tundra Parts Marketplace (2014-2021)' started by Sting Ray, Jan 16, 2018.
Thread Status:
Not open for further replies.
  1. Jan 16, 2018 at 3:05 PM
    Sting Ray
    Sting Ray [OP] New Member
    Ray
    Vegas
    2017 SR5 Crewmax
    Not enough space here...
    Are you sick and tired of pressing and holding that pesky traction control button twice every single time you start your truck? Let’s be real, it’s a lot of work disabling those nannies. We have better things to be doing than holding a button down! We just want full control, full power, and we like burnouts…oh and doughnuts too! Did you ever wish there was a way to automatically disable the traction control every time you start your truck and enable it when you wanted with the push of a button? Well now you can!!
    It’s a simple wiring harness/trigger assembly that connects to two wires and a ground behind your dash via t-taps. I made myself one and have been testing for a few days. It basically simulates 2 button presses and holds but still maintains the ability to turn the nannies back on by pressing the traction control button at any time. It works absolutely flawlessly.
    Price is $125 Payment will be made via PayPal, shipping will be $8 for USPS Priority. Payment can be sent via friends and family or add $4.65 to cover the fees.
    Please let me know if you are interested. Here’s a video of the nannies disabling automatically. And a pic of the harness. Thank you!
    https://youtu.be/VcMZGO_qqYU
    Automatic Traction Control Disabler Install Instructions
    -You are installing this device at your own risk. This device is only for off road use as it disables your vehicle’s traction control system automatically when you start your engine.
    -Installation should be accomplished by a certified professional mechanic.
    To Install
    -Disconnect the negative terminal on your battery
    -Remove the left kick panel, lower dash panel, trailer brake controller, and traction control/tow haul mode/parking sensor switch panel that is just above the trailer brake controller.
    -Remove the cigarette lighter panel.
    -Install one wire tap onto the brown wire on the trucks traction control switch wiring harness. Your wire may be a different color, some older years are yellow, regardless of color it will be the top wire on the plug as you are looking at it if it were connected to the switch. This is the signal wire. See pictures below.
    -Connect the wire t tap connector that is on the white and orange wire on the traction control dissabler (labeled signal in the very first pic) to this t tap. The wire is blue in this pic above, it is not blue on your disabler, it is orange and white.
    -Install the 2nd t-tap on the red wire that leads to your cigarette lighter and connect the remaining t-tap connector that is on the black wire to this t-tap. It is labeled power in the very first pic. This connections provides a 12V switched on power source to the traction control disabler.
    -Loosen the 10mm bolt on your dash brace that is to the bottom left of the trailer break controller, slide the spade connector under the bolt head and tighten the bolt back down.
    -temp install the trailer break controller and traction control/tow haul/parking sensor switch panel electrically
    -connect the negative battery terminal
    -start the truck, the led's on both triggers should flash then turn off, nannies should turn off automatically at 9 seconds after the triggers receive power. Press the traction control button once and all nannies should turn on. To re-enable the disabler you will either have to restart the truck or come to a complete stop, press and hold the traction control button for 4 seconds, release, and press and hold again for another 4 seconds just like you normally would.
    -check all other disturbed wiring that was disconnected for proper operation. Parking sensors, tow/haul mode, USB/cigarette lighter power, trailer break controller, etc.
    -once everything works as advertised zip tie the triggers to the dash brace on the lower right corner of the dash next to the center console or another location of your choosing so they are secure and not bouncing around
    -fully install trailer brake controller, and switch panel
    -install lower dash panel, USB/cigarettes lighter panel, left kick panel
    -you could also add a switch if you wanted to be able to disable the disabler
  2. Jan 16, 2018 at 3:06 PM
    Sting Ray
    Ray
    Vegas
    2017 SR5 Crewmax
    Also works on Gen 2's
  3. Jan 16, 2018 at 9:29 PM
    Slayer
    Slayer Member
    Slayer
    what's your background Sting Ray?
    how did you come up with this clever devise?
    what is involved in connecting this up?
    can a simple minded (stupid) carpenter perform this addition?
    more info please
    Smiley likes this.
  4. Jan 16, 2018 at 11:29 PM
    TheBeast The Beach
    that is cool
    Mountun Goat and Sting Ray[OP] like this.
  5. Jan 17, 2018 at 5:48 AM
    Sting Ray
    Ray
    Vegas
    2017 SR5 Crewmax
    I'm an aircraft mechanic in the Air Force for the last 19 years. Now I'm an adult babysitter of aircraft mechanics lol. Before that I raced quads and dirt bikes. Rebuilt my first motor when I was about 9 years old lol. I found some info from about 10 years ago floating around on the net about these, got into contact with a guy that had experience doing the mod on an older truck so it was just a matter of figuring it out. It's as close to plug and play as it can get. You will have to use wire taps to tap into 2 wires. 1 for power, 1 for signal. Then attach a ground wire to a bolt under the dash. Install should take a normal person about an hour, and most of that time is spent removing and reinstalling the lower dash panels. Instructions are pretty detailed that I will send and of course I'll always be able to help should you run into an issue with install, or even after install for that matter.
  6. Jan 17, 2018 at 11:14 AM
    Theyfzman
    Theyfzman New Member
    Pa
    08 TRD
    I’m interested !!!!
  7. Jan 17, 2018 at 11:20 AM
    Sting Ray
    Ray
    Vegas
    2017 SR5 Crewmax
    Pm me!
  8. Jan 17, 2018 at 11:20 AM
    Theyfzman
    Pa
    08 TRD
  9. Jan 17, 2018 at 4:24 PM
    sstoddard
    sstoddard New Member
    Shawn
    2019 Crewmax Sport
    Alarm/start (Compustar Ft7000,Rf2wl1b 2-way remotes and Drone Mobile) Tailgate inserts NSV Lightbar Tailgate actuator Blacked out decals
    Looks like a few tr7's interesting application for them.
    Sting Ray[OP] likes this.
  10. Jan 17, 2018 at 8:02 PM
    Sting Ray
    Ray
    Vegas
    2017 SR5 Crewmax
    All sold. If you are interested in getting on the waiting list please let me know. Thank you!
  11. Jan 17, 2018 at 8:35 PM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    PM sent.
  12. Jan 17, 2018 at 8:48 PM
    Sting Ray
    Ray
    Vegas
    2017 SR5 Crewmax
    Replied
    831Tun[QUOTED] likes this.
  13. Jan 17, 2018 at 9:30 PM
    theraven
    theraven New Member
    Central AZ
    16 DC / KI7LWX
    Icon 2.5 cdc front and rear. MCM UCA's, RXT rear leafs , wheelers bump stops, Icon hydrolic Bump stops, Icon six speed 17x8.5 w/35x12.5R17 Nitto Ridge grapplers, A.R.E. CX,, Smittybilt Gen2 12k synthetic on SSBuilt Front bumper, factor 55 fair lead, factor 55 flat link-E, SSBuilt high clearance rear with S2Pro, BD squadron pro fogs and side lights, BD 40" Onx6 behind the grill on SDHQ mount, BD XL80's on SDHQ a pillar/ hood mounts. Switch pros 9100, SDHQ panel mount and SDHQ under hood mount. Pro Grill, SDHQ ABS guards, P&P Sliders, Full RCI skids. Kenwood TM-V71a, Dual GPS antenna, Rago dash mount, WE Boost inreach
    Very interested
  14. Jan 17, 2018 at 9:40 PM
    Tacogrande
    Tacogrande New Member
    Jeremy
    2016 SR5 dbl. cab long bed gray
    Husky weatherbeaters,short antenna,window deflectors
    Interested! Post video of burnouts and donuts and count me IN!! How much longer wait?
  15. Jan 18, 2018 at 5:05 AM
    Sting Ray
    Ray
    Vegas
    2017 SR5 Crewmax
    Pm me to get added to the waiting list
  16. Jan 18, 2018 at 5:06 AM
    Sting Ray
    Ray
    Vegas
    2017 SR5 Crewmax
    Going out of town for work. I'll have parts waiting for me when I get back and will have more units ready for shipping by 7 Feb. pm me to get on the waiting list
  17. Jan 19, 2018 at 6:51 PM
    Sting Ray
    Ray
    Vegas
    2017 SR5 Crewmax
    Updated with install instructions. Pics to follow
  18. Jan 23, 2018 at 8:57 AM
    Theyfzman
    Pa
    08 TRD
    Installed mine today super easy and an awesome mod !!
  19. Jan 23, 2018 at 9:31 AM
    Sting Ray
    Ray
    Vegas
    2017 SR5 Crewmax
    Awesome! Glad you like it! Thank you!
  20. Jan 28, 2018 at 11:07 AM
    Sting Ray
    Ray
    Vegas
    2017 SR5 Crewmax
    I will be back in town 3 Feb and have parts waiting on me to build 2 more that are not yet spoken for. Please pm me if interested.
  21. Jan 30, 2018 at 9:01 PM
    Sting Ray
    Ray
    Vegas
    2017 SR5 Crewmax
    1 left. Anyone?
    GNTundra likes this.
  22. Jan 31, 2018 at 5:10 AM
    Tacogrande
    Jeremy
    Ordered.
  23. Jan 31, 2018 at 9:00 AM
    Mike's Custom Toys
    Mike's Custom Toys New Member
    This works great. I have been doing this for my customers since 2010. Glad to see someone has the time to put some together for sale. The only thing to keep in mind if you throw the truck into gear under three seconds of starting the process will get interupted. However most of us start our trucks then put on seat belts, check mirrors all things that take longer than 3 seconds. I originally was paid to do this MOD for a S/C 2010 5.7 DC whose owner wanted to do burn outs without having to push any buttons.
    csuviper and Sting Ray[OP] like this.
  24. Feb 3, 2018 at 6:27 AM
    Sting Ray
    Ray
    Vegas
    2017 SR5 Crewmax
  25. Feb 3, 2018 at 9:20 AM
    Sting Ray
    Ray
    Vegas
    2017 SR5 Crewmax
    More then 1 as of tomorrow. Pming.
  26. Feb 5, 2018 at 3:42 PM
    andy9743
    andy9743 New Member
    andrew
    nw ohio
    08 tundra cm 4x4 trd sc, +2 pulley, 4.88s, 37's, other things
    Super excited to get this on my supercharged truck! Free bump.
  27. Feb 9, 2018 at 2:21 PM
    JH5370
    JH5370 Member
    Josh
    Eastern WA
    2017 White DC TRD PRO
    Well this is awesome.
  28. Feb 9, 2018 at 2:28 PM
    cu52
    cu52 New Member
    Denver Metro
    13 Platinum CM
    Supercharged, TRD Dual Exhaust, Bilstein 6112's/5160's, TSS wheels, Toyo AT Xtreme 285/60R20, LED bed lights, Hellwig sway, PopNLock tailgate lock
    Interesting! Can it automatically turn tow/haul mode on also? or be added as a feature?
  29. Feb 9, 2018 at 2:41 PM
    Sting Ray
    Ray
    Vegas
    2017 SR5 Crewmax
    Yes yes it is!
  30. Feb 9, 2018 at 2:43 PM
    Sting Ray
    Ray
    Vegas
    2017 SR5 Crewmax
    No unfortunately it only does the traction control, but I could probably design it to also do the haul ass mode button....pm me if you are seriously interested.
Thread Status:
