Automatic Headlights - Tundra 22
Discussion in '3rd Gen Tundras (2022+)' started by TundZ22, Aug 3, 2022.
  1. Aug 3, 2022 at 8:01 AM
    TundZ22
    TundZ22 [OP] New Member
    E
    2022 Tundra TRD
    I've been trying to get my headlights off, using the "daylight auto", but the headlight wont turnoff during the day.....Thought I post on the forum see if anyone knows a trick.
  2. Aug 3, 2022 at 8:04 AM
    TRDFerguson
    Jake
    Southeast Greater Basin, AZ
    2018 MGM CrüeMax
    Post your trim level and location - there are differences between SR5 and limited/plat/etc, as well as the Canadian versions that I believe are always on.
  3. Aug 3, 2022 at 10:33 AM
    TundZ22
    E
    2022 Tundra TRD
    I have the SR5 TRD Off Road Package (4X4). I see the Auto feature. I assume that this is just a standard feature to all vehicles in the past 20 yrs.
  4. Aug 3, 2022 at 10:55 AM
    Medic343
    Medic343 5+4+3=2
    Kenny
    New Mexico
    '22 SR5 TRD off-road
    The auto feature controls the headlights only. Meaning the lights you see on during the day are the daytime running lights (DRL). The auto feature will detect low light conditions and turn on the headlights, taillights, and illuminate the dash.
    If you don't want the DRLs on you have to switch the selector to the off position.
    forzamrit and TK1979 like this.
  5. Aug 3, 2022 at 11:54 AM
    Coasty
    Coasty New Member
    Pat
    Oregon
    2022 SRS Crew Max 6.5 4x4
    The sensor that the lights use to determine if it's day or night is on the dash and if you have something covering it and your lights are in auto, your headlights will be on instead of your DRL's
    TK1979 likes this.
  6. Aug 3, 2022 at 1:09 PM
    DBWA
    DBWA New Member
    Dave
    2022 Tundra TRD Limited 6.5' Bed
    @TundZ22 post a photo of what you're seeing in plain daylight?
  7. Aug 4, 2022 at 8:18 AM
    TundZ22
    E
    2022 Tundra TRD
    Gotcha! This helps...Makes sense now why the DRLS's our a bit dimmer than the night. I was really looking to have NO lights at all (including the DRL), and have my lights switch at dark.
    Thanks, I'll post what I see in plain daylight.....
  8. Aug 4, 2022 at 1:50 PM
    4genRunner
    4genRunner New Member
    Southwestern MO
    2022 SR5 CrewMax TRD OR 4x4 CSM
    RB20's, Extang Xceed Cover, Tint.
    If you have access to Techstream or Carista, you can disable the daytime running lights. You should then be able to use the auto setting and have the lights turn on at dark but not have the DRLs on during the day.
  9. Aug 4, 2022 at 3:51 PM
    TakiEvo
    TakiEvo New Member
    Allentown, PA
    2022 SR5 TRD Sport Crewmax White
    Or just disable it in the radio setting. :)
    =JSG= likes this.
  10. Aug 4, 2022 at 4:02 PM
    4genRunner
    Southwestern MO
    Hahahahaha. I didn't know it could be done there! Thanks!
  11. Aug 4, 2022 at 7:04 PM
    Yaboy
    Yaboy New Member
    Canada
    22 limited off-road
    All cars in Canada have full time DRL and can’t be turned off it’s our safety requirements. Here’s my settings and switch.
    AND likes this.
  12. Mar 1, 2023 at 8:25 AM
    Adammitt
    Adammitt New Member
    2022 Tundra SR5 TRD Off-road Crew Max
    Super helpful, I was trying to figure out the same thing (lights were always on)… didn’t know the sensor was right where I put my hat so it was covered. Appreciate you all!
  13. May 26, 2024 at 12:08 AM
    SSTundraStan
    SSTundraStan New Member
    Stan
    2023 Tundra Limited TRD Off Road crewmax
    Soon To Have Probably 3.5 inch Lift, Some kind of Tow hooks, Bud Built Skids,
    I cannot for the life for me understand why anybody would be silly enough to want to turn off their headlights during the day?
  14. May 26, 2024 at 9:19 AM
    brhodea
    brhodea New Member
    Michigan
    '24 CM Limited
    I can't understand for the life of me why anyone would be considered "silly" for not running they're DTR in the day. If it was so silly, we'd be like our communist brothers to our north, and not have the option.
    SWB Tundra likes this.
  15. May 26, 2024 at 9:27 AM
    SSTundraStan
    Stan
    Communist, hardly. Smarter, absolutely. It's called lights on for safety! It has been proven many times that driving with your headlights on or your daytime running lights or some kind of a front marker light is significantly safer! Hopefully one day the US will catch up to this and mandate this with their manufacturers as well!
  16. May 26, 2024 at 9:29 AM
    brhodea
    brhodea New Member
    Michigan
    '24 CM Limited
    Ok Buddy, let me know how many accidents happen with lights on, daytime or night for that matter. Must be a hardcore Trudeau fan boy.
    Tundrastruck91 likes this.
  17. May 26, 2024 at 11:48 AM
    SSTundraStan
    Stan
    There's always one ignoramus that is spewing stuff he doesn't know anything about, Trudeau has nothing to do with it it's just you. Everybody on the planet or at least it was that no better understand the Research indicates it is many times safer to have your lights on 24/7. You're probably the idiot that drives around without his lights on just to see if people see you or something. So you go ahead and believe what you believe and I just hope one day that your government whichever one is in power is smart enough to put the lights on for life because again it's much safer all the statistics prove it and clearly you've never seen them! Have a safe day!
  18. May 26, 2024 at 11:51 AM
    brhodea
    brhodea New Member
    Michigan
    '24 CM Limited
    Hey buddy, you too. Just be careful cause you probably won't see me coming.
  19. May 26, 2024 at 11:52 AM
    SSTundraStan
    Stan
    You clearly know nothing about the Canadian military!
  20. May 26, 2024 at 11:54 AM
    brhodea
    brhodea New Member
    Michigan
    '24 CM Limited
    Nope, could care less also. Carry on
  21. May 26, 2024 at 11:56 AM
    brhodea
    brhodea New Member
    Michigan
    '24 CM Limited
    They're possibly easy to troll, Just a guess, silly sailor.
