Automatic door lock/unlock.
Discussion in 'General Tundra Discussion' started by lone_wolf, Mar 11, 2021.
  1. Mar 11, 2021 at 7:57 AM
    lone_wolf
    lone_wolf [OP] New Member
    Cape Coral, FL.
    2018 Tundra SR5
    Stripes. cap, alarm, marker lights, reflectors.
    Good day all. Somehow my doors started to automatically unlock when I put it into park. I looked in the manual and searched on here but can't find how I can program to change that.
    Thank you!
  2. Mar 11, 2021 at 8:48 AM
    TILLY
    TILLY Gently Used Member
    Massachusetts
    2019 MGM TRD Sport D/C
    There's settings to change that in the H/U. Forget exactly where it is at the moment, but its in there. Good luck.
  3. Mar 11, 2021 at 8:50 AM
    adamreinhardt
    adamreinhardt Blk 17 Platinum 4x4
    Seattle
    2017 Platinum in Midnight Black Metallic
    When/if you received manuals for the truck, you may have gotten a supplemental manual for the entertainment systems. I found that info in there the other day and have been having a blast with all the settings I wasn’t aware of. That’s one of them.
  4. Mar 11, 2021 at 8:50 AM
    lone_wolf
    Cape Coral, FL.
    2018 Tundra SR5
    Thanks so much but I can't figure out what H/U is. Sorry.
  5. Mar 11, 2021 at 8:53 AM
    TILLY
    Massachusetts
    The Head Unit, the display panel where your nav/radio is.
  6. Mar 11, 2021 at 8:55 AM
    lone_wolf
    Cape Coral, FL.
    2018 Tundra SR5
    Okay thanks, I do have all the manuals that I've looked at and I checked the H/U but will look again. Any idea where in the H/U the option is?
    Thanks again!!
  7. Mar 11, 2021 at 8:57 AM
    TILLY
    Massachusetts
    If you can't find it I can take a look at mine if you want.
  8. Mar 11, 2021 at 8:58 AM
    lone_wolf
    Cape Coral, FL.
    2018 Tundra SR5
    Thanks Tilly. I'll see if I can find it again and let you know!
  9. Mar 11, 2021 at 8:59 AM
    TILLY
    Massachusetts
    No problem.
  10. Mar 11, 2021 at 9:01 AM
    mountainpete
    mountainpete Explore more
    2018 Cement Crewmax TRD
    Function before sparkle.
    Then go to door locks...
  11. Mar 11, 2021 at 9:34 AM
    lone_wolf
    Cape Coral, FL.
    2018 Tundra SR5
    Thanks Tilly. I don't have that paperwork and yours was helpful! I looked in that area of the display earlier but the "vehicle" option was faded out like it was unavailable but discovered I had to have the engine running to access. So it worked like you said it would!! Thanks again!!
  12. Mar 11, 2021 at 9:37 AM
    TILLY
    Massachusetts
    :thumbsup:
