Auto Stop/Start
Discussion in '3rd Gen Tundras (2022+)' started by thedudeinpa, Sep 24, 2023.
  1. Sep 24, 2023 at 6:46 PM
    thedudeinpa
    thedudeinpa [OP] New Member
    2023 Tundra SR5
    Bought a “brand used” 2023 Tundra SR5 with 5,000 miles on it last week. Traded a 2017 Limited for it. I was dreading the auto start/stop feature but was surprised that the former owner somehow bypassed it already. The engine will not shut off at stoplights, ever. I’m wondering if he did anything else. ‍♂️
    Thanks former owner!
  2. Sep 24, 2023 at 6:57 PM
    in_the_mud
    in_the_mud GSD
    Raph
    Calgary, AB
    2023 Limited L TRD OR MBM
    Auto Stop / Start feature here is designed the way that the driver has full control over it. I am not saying nothing was done to your specific truck to bypass that but you can easily operate your Tundra and never engage this at any red light or other stop.
    raylo likes this.
  3. Sep 24, 2023 at 6:58 PM
    thedudeinpa
    2023 Tundra SR5
    Interesting. I’ll have to keep messing with it to try to get it to engage.
  4. Sep 24, 2023 at 7:03 PM
    TILLY
    TILLY Gently Used Member
    Massachusetts
    2019 MGM TRD Sport D/C
    Try putting full pressure on the brake pedal when you come to a stop, if that doesn't shut it down then maybe there is an override of some sort installed.
    raylo and GODZILLA like this.
  5. Sep 24, 2023 at 7:06 PM
    in_the_mud
    in_the_mud GSD
    Raph
    Calgary, AB
    Just look for a message on your dash "Push the brake to engage"
  6. Sep 24, 2023 at 10:01 PM
    Rykr
    Rykr New Member
    2023 SR5 TRD Sport 4x4 MGM
    I mean you have the ability to turn it off completely in the settings or just by not mashing the brake pedal down hard at a complete stop.
    Mattedfred likes this.
  7. Sep 24, 2023 at 10:31 PM
    chance12
    chance12 New Member
    GA
    23 Tundra CM Limited
    There is an auto start/stop disable kit that several people on here have installed. It is wired from the back of the on/off switch to a spare fuse in the passenger side footwell. it would be easy to check if you're curious, just look at the fuse box inside on the passenger side or pop the trim piece out by your left knee.
    Here is a link.
    Disable Toyota Automatic Stop Start Permanently Tundra 2022+ Model TDA3 | eBay
    the issue is that most people who complain about this feature also don't want to have to turn the feature off every time they start the truck up.
    GODZILLA likes this.
  8. Sep 24, 2023 at 10:38 PM
    Rykr
    Rykr New Member
    I didn’t know it had to be turned off every single time on startup. On the Highlander once it’s turned off that’s it. Guess I’m one of the ones that it doesn’t bother me. I don’t press the brake pedal hard enough to enable it.
    raylo and chance12 like this.
  9. Mar 9, 2024 at 7:21 PM
    BigTrout
    BigTrout New Member
    2024 Tundra Platinum TRD Off Road
    My F150 work truck had this(not as intuitive as the Tundra with the brake pedal) we simply removed the switch and jump the 2 contacts together so its like the button is always pushed. But that was a work truck. Im not so sure I want to send constant voltage to an input on MY new truck.
  10. Mar 9, 2024 at 9:09 PM
    TundBP
    TundBP New Member
    23 Blueprint Platinum
    Press the brake pedal fully and turn off powered accessories helps so it's not charging the battery.
  11. Mar 14, 2024 at 5:14 PM
    omglas3r
    omglas3r Member
    Purchased and installed this. Works great!
    Got tired of Auto Stop/Start turning engine off when i park.
    Skorch likes this.
  12. Mar 15, 2024 at 2:59 PM
    Breathing Borla
    Northern Illinois
    ya, I just push to turn it off every time as part of the pre-flight checklist, I don't even think about it anymore
  13. Mar 15, 2024 at 3:03 PM
    G3ardnut
    G3ardnut Brushed Chrome is COOL
    Joe
    Canada
    2023 Limited TRD Offroad Crewmax Celestial Silver Metallic
    Just don't push your wife's buttons.
  14. Mar 15, 2024 at 3:07 PM
    Breathing Borla
    Northern Illinois
    lol, good advice. although even those buttons need to be exercised once in a while to make sure they work, HA:nuclear:
  15. Mar 15, 2024 at 3:20 PM
    Fatone
    Fatone New Member
    2022 Tundra TRD Sport Premium
    Why does anyone need an over ride kit? Just do not press the brake when stopped dues not work why?
  16. Mar 15, 2024 at 3:24 PM
    eddiefromcali
    eddiefromcali New Member
    Eddie
    2022 Tundra Platinum
    100% Stock
    exactly...dudes going Fred Flintstone with their brake pedals
    ChucklesToy and Mattedfred like this.
  17. Mar 16, 2024 at 10:12 AM
    22TXAG
    22TXAG New Member
    Because it also shuts off when you go to park then immediately restarts. For me this was the most annoying part.
    22whatwedo likes this.
