Auto stop/start disable
Discussion in '3rd Gen Tundras (2022+)' started by Dpoll995, Feb 6, 2024.
  1. Feb 6, 2024 at 4:47 PM
    Dpoll995
    Dpoll995 [OP] New Member
    Houston TX
    2024 Tundra Limited
    Backflowguy, Skorch and Dugnor like this.
  2. Feb 6, 2024 at 4:50 PM
    Markysharky
    Markysharky New Member
    Or just don’t press the brake pedal too hard. Or have the HVAC cranked it will barely ever kill the engine
    Siblue likes this.
  3. Feb 6, 2024 at 5:05 PM
    PNW Tundra Mike
    Back in So Cal
    MX4 Tonneau, Talon's Trans/Cat Shield, Vantrue Cam
    I can easily avoid activating it with the brake pedal. What drives me nuts is it shutting off when I shift to Park and then immediately auto starting right back up. I’ve been shutting off in Drive just to avoid it. Maybe this dongle would stop that.
    *Update 7/4/25 - Found that unbuckling the drivers belt before shifting out of Drive stops it from shutting down in Park. Swear I tried that 2 yrs ago but it works now.
  4. Feb 6, 2024 at 5:29 PM
    MrKABC
    MrKABC Not so new Member
    Art
    Corona, CA
    2023 Mesquite 1794 TRD OR Hybrid
    Miller Cat Shield, Sumo Springs Blue, Diode Dynamics Stage Series hidden light bar.
    Or get the Hybrid. :D
    Hella Krusty likes this.
  5. Feb 6, 2024 at 6:16 PM
    xc_tc
    xc_tc New Member
    If you wait a a second or two longer after it shuts off to shift to park, it will stay off.
    22whatwedo likes this.
  6. Feb 6, 2024 at 8:12 PM
    PNW Tundra Mike
    Back in So Cal
    It doesn’t shut off until I shift to Park. Even if I sit there in Drive for a few secs. But you gave me an idea. Pull up to the house, stomp on the brake so it shuts down, then push the Ignition button to shut down while it’s Off. Gonna have to try that out to eliminate the extra restart.
  7. Feb 6, 2024 at 8:20 PM
    xc_tc
    xc_tc New Member
    If you stomp the brake, let it shutdown, wait 2 seconds, then shift to park and it stays off. If you shift immediately after it’s shut off, it’ll restart. I always shift to park then shut the ignition off.
    PNW Tundra Mike likes this.
  8. Feb 7, 2024 at 8:22 AM
    teab
    teab 2023 Platinum w/ PRO bits
    Ty
    Denver
    2023 Platinum MGM 6.5
    TRD Pro Wheels, Go Rhino D6, Airlift bags/compressor, Talons Alum Cat Shield, Cheap-o Amazon Mud Flaps, Fastop Tonneau/Topper, Rear TRD Pro Shocks
    Keep your seatbelt on and the truck won't start back up after you put it in park. Now that your truck is off in park and your seat belt is still buckled hit the push button start and the the truck shuts down and doesn't start back up again. It was driving me nuts and I figured out I was unclicking my seatbelt right after putting it in park and the truck kept starting back up. I made an effort or mental note to not unbuckle my seatbelt until I am able to push the start button to shut it down. Only time it starts back up is when I forget again. Keep your seatbelt buckled... put it in park wait a second....if the truck engine shuts down....push the start button to shut off the non running truck....then unclick your seatbelt and no more annoying restarts
    TundraChuck likes this.
  9. Feb 7, 2024 at 8:26 AM
    sask3m
    sask3m New Member
    Alberta
    Black 2019 SR5
    What's their reasoning behind the auto shutdown?
  10. Feb 7, 2024 at 8:35 AM
    teab
    Ty
    Denver
    You get zero miles to the gallon sitting there idling and not moving. Simply fuel economy targets.
    sask3m[QUOTED] and Mattedfred like this.
  11. Feb 7, 2024 at 8:42 AM
    az 3rdGen
    az 3rdGen New Member
    Arizona
    2022 Black Tundra SR5
    Back to the OP- I saw this in a different thread yesterday and ordered it from Amazon. This seems perfect for me and only 20ish dollars is a decent deal. I always forget to press the button until it shuts off and reminds me.
    I will be installing tomorrow. Do you pull out the panel and add the cable or just reach from underneath?
  12. Feb 7, 2024 at 11:23 AM
    Goobax
    Goobax New Member
    2024 SR5 4x4 Tundra
    You can just pop the panel off and install.
    az 3rdGen[QUOTED] likes this.
  13. Feb 8, 2024 at 5:20 PM
    az 3rdGen
    Arizona
    Installed this today.. took about 5 minutes and it works.. I was kind of surprised at how tight the wiring harness is behind there. I could barely pull out the cluster 2 inches.
  14. Feb 8, 2024 at 6:53 PM
    Dpoll995
    Houston TX
    2024 Tundra Limited
    lol yea I was thinking the same. I found 1 downside to it though. In the morning I remote start my truck then I go open the door and it shuts off then when I start the truck again the auto start it back on. Apparently the module needs the truck to be off for a minute or so before it works again. I generally don’t remote start, just when it’s cold outside, so I’ll just have to remember to turn it off manually on those days.
  15. Feb 9, 2024 at 5:27 AM
    Delta1Seven
    Delta1Seven New Member
    Damien
    Just curious, why does it do this where it shuts off when switching to park?
    I never have the truck turn off when in drive (as I don't typically mash on the brake at a red light). But man it happens like 1/10 times when shifting to park.
  16. Feb 9, 2024 at 5:28 AM
    Hella Krusty
    Hella Krusty New Member
    And environment
  17. Feb 9, 2024 at 5:29 AM
    Delta1Seven
    Damien
    Thanks for the post. Are there any downsides to this that you have noticed? Any dash light, warning light, etc?
  18. Feb 9, 2024 at 6:39 AM
    Breathing Borla
    AZ
    IDK, plugging some cheap china device into my 70K rig just so I don't have to hit a button on start up, not sure Im in on that
    Im just used to hitting it off every time on my pre-flight check list, I don't even really thing about it anymore
  19. Feb 9, 2024 at 6:42 AM
    Dpoll995
    Houston TX
    2024 Tundra Limited
    no error lights, just the orange light that shows the auto start is turned off. also, In the morning I remote start my truck then I go open the door and it shuts off then when I start the truck again the auto start it back on. Apparently the module needs the truck to be off for a minute or so before it works again. I generally don’t remote start, just when it’s cold outside, so I’ll just have to remember to turn it off manually on those days.
  20. Feb 9, 2024 at 7:20 AM
    Siblue
    Siblue Old member
    Ryan
    25 Tundra TRD pro
    This module is also popular in GRC community enabling iMT at key ON
  21. Feb 17, 2024 at 12:43 PM
    LB-1889
    LB-1889 New Member
    You can also pull the side dash panel off pretty easy and reach in and unclip the wiring harness from back of the dash. Then push in the back of the switch cluster and it will pop out and be able to pull it out 6 inches or so to access the switches.
  22. Feb 17, 2024 at 2:16 PM
    az 3rdGen
    Arizona
    Thanks for the pics! I kind of saw that clip holding the wiring harness when I installed wire. I want to add some lights in the future and wire the buttons in that cluster so this will come in handy!
  23. Feb 18, 2024 at 6:48 PM
    NOEVSh*t
    NOEVSh*t 53 Toyota Buys - 2016 382,000 M - 2011 528,000 M
    The Great State of Texas
    2024 Platinum 4X4 Non-Hybrid Night Shade Crew Max
    Start/Stop Disabled, Ceramic Tint, 305/55/20 BFG KO2's on No Lift or Level, EFF Replace OEM Charger, Wireless Charge Iphone Mount, Exceed Bed Cover, etc.
    https://www.ebay.com/itm/125666096660
    This model does not change. Remote start or not it stays either active or not active according to your last setting. I have it on my 2024 Crew Max Plat Non-Hybird for 4 months steady and no faiure.
    Looks like the other model that was posted above post does not have a constant power to keep the unit in set position. Note no power wire to attach to fuse box for steady on power of 12V
    ScottieBones and Woocawachie like this.
  24. Feb 18, 2024 at 8:16 PM
    LB-1889
    LB-1889 New Member
    I have this same model and auto start / stop is always disabled at startup and doesn’t remember last setting. eBay listing description is somewhat helpful and may say the same thing.
    I installed the new one that is being sold on Amazon in a buddy’s truck.
    Pros - No power wire like other one.
    Cons - Starts “off” automatically and doesn’t remember previous setting as the other one that needs power.
  25. Feb 19, 2024 at 2:25 AM
    NOEVSh*t
    Did I miss-understand your statement above quoted?
    If installed with the power wire to constant 12V fuse the unit will REMEMBER last setting.
    SC4333 likes this.
  26. Feb 19, 2024 at 6:13 AM
    Fatone
    Fatone New Member
    2022 Tundra TRD Sport Premium
    I was wondering what the heck this thread was about since start/stop never happened to me when parking. Just control it with the brake when idling which I like as opposed to the automatic ones. I guess my default park method sequence (park, push button, belt removed) does not trigger it. Seems easier just to alter your shutdown sequence than alter the truck but that's just me
  27. Feb 19, 2024 at 6:51 AM
    PNW Tundra Mike
    Back in So Cal
    Mine still randomly shuts down shifting to Park only to immediately restart no matter the sequence. Belt on/off, pausing in Neutral, etc. Must use the button Or plant the Brake pedal to just kill it, shift to Park, then tap Shutdown.
  28. Feb 19, 2024 at 3:31 PM
    LB-1889
    LB-1889 New Member
    The new version with no power wire is by default, off at startup.
    The older version with the power wire is defaulted to off at power. Mine is connected like the instructions to the power outlet fuse.
    Ideally I would like it to remember my last setting since the starting stopping annoyance when coming to a stop seems to happen seasonally when the temps aren’t excessively hot or cold.
    I did try to run constant power to it and test it again but couldn’t get it to remember the last setting as you had stated.
  29. Feb 20, 2024 at 5:26 AM
    captn_Rob
    captn_Rob New Member
    Rob
    Maine
    2024 Toyota Tundra SR5 with Off-Road package
    1.75 in leveling, Loadlifter rear airbag suspension, Access roll-up tonneau cover, EGR fender flares and hood guard, GoRhino sport bar, off-road lights, 185/75R18 Nitto Ridge Grapplers on XD 18x9 +18 offset rims.
  30. Apr 3, 2024 at 1:45 PM
    Backflowguy
    Backflowguy New Member
    W
    2024 1794 4WD
    Have you had good service with this one so far? The S/S thing is running me crazy.
