Auto on headlights
Discussion in 'Lighting' started by Ghostcruiser, May 5, 2017.
  1. May 5, 2017 at 5:48 PM
    Ghostcruiser
    Ghostcruiser [OP] New Member
    Ben
    2016 inferno
    Pro grill, badges, topper, roof rack, light bar
    I have a '16 sr5 trd Offroad and want to add auto on headlights I've got the sensor and light switch on order. Is this a straight plug and play add on? Or does the dealer have to do something to the ecu?
    4x4_Angel likes this.
  2. May 5, 2017 at 6:06 PM
    MotoTundra
    MotoTundra The Ocho
    Don
    Ben welcome to Tundras.
    I haven't heard of anyone doing a conversion but haven't researched it at all either.
    It definitely doesn't sound like an easy job. What kind of switch will you use? Different turn signal stalk?
    Please post up your results!
  3. May 5, 2017 at 7:00 PM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    I've only done a Second Generation, but changing the signal/light stalk should be straightforward. If you already have wiring connecting the sensor at the base of the windshield to the main ECU, you should be set. If not, you will have to build that and install it yourself.
    Zak3033 and 4x4_Angel like this.
  4. May 5, 2017 at 7:30 PM
    louscrw
    louscrw all jacked up on Mt. Dew
    Lou
    Warner Robins, Ga
    2023 F150 Raptor
    @eledobleu did a write up when he did it to his truck. I don't see his write up on this forum, maybe he'll add it. But, it is easy to do. You need to buy a sensor (located on the center dash speaker) and new light stalk.
    Agitated1 likes this.
  5. May 5, 2017 at 11:48 PM
    Agitated1
    Agitated1 Newish Member
    Los Angeles
    2017 Tundra Crewmax TRD 4x4 Quicksand
    TRD Pro Grill King Coilovers with compression adjuster Tint 5% Rear, 30% front and 70% windshield Husky X-Act Floor liners BA Muffler 8in standard system Truck Covers USA retractable bed cover Yakima bed rails
    Here you go. Hope this helps. I'll eventually do this mod. Should be plug and play but you need to take the steering wheel off. Let me know how it goes.
    http://www.tundratalk.net/forums/tu...-diy-add-autolights-sr5-2014-plug-n-play.html
  6. Sep 16, 2017 at 4:43 PM
    Riverdog
    Riverdog New Member
    2017 White Tundra SR5
    3" Lift, 20" wheels with 295/60/20 Nitto tires, Light bar in hood bulge and lower bumper. Will being doing more mods later
    Wanted thank #eledobleu ... for a great write up on the aforementioned link.
    Just installed on my 2017 Tundra SR5, was nervous since it is only a couple weeks old and less then 800 miles on it.
    Got the final part in yesterday and installed today. Working great.
    Took me about 1.5hrs to complete. Stopped a few times to step back, have a smoke and calm nerves, lol. Once I got all apart, putting back together was easy. Just remember to pull the tape off before you put the steering wheel back on (can not confirm or deny I did that).
    Total cost:
    Headlight switch - $111.01 from OEM Part source
    Sensor - $11.77 from eBay
    Everything works great and I am able to adjust the sensitivity by going to the following:
    apps > setup > vehicle > vehicle customization > lights
  7. Jan 8, 2018 at 8:09 PM
    Chimguy3
    Chimguy3 New Member
    New Jersey
    2015 Tundra Pro
    Rear Ride Rite air bags AJT interior chrome delete
    darkknight2014 likes this.
  8. Jan 8, 2018 at 8:57 PM
    Agitated1
    Los Angeles
    I just clicked on the link and it works fine for me.
  9. Jan 8, 2018 at 8:59 PM
    Chimguy3
    Chimguy3 New Member
    New Jersey
    2015 Tundra Pro
    It worked on my laptop at work, but not at home on iPhone.
  10. Jan 8, 2018 at 9:00 PM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    Welcome Ben.
  11. Jan 8, 2018 at 11:22 PM
    Y0TA PR0
    Y0TA PR0 Oil & Gas
    Rafael
    2017 TRD PRO
    Welcome
  12. Jan 8, 2018 at 11:40 PM
    4x4_Angel
    Bree
    Funky Town, Texas
    2014 SR5 CM Silver Sky
    I get a blank white screen
  13. Jan 8, 2018 at 11:41 PM
    4x4_Angel
    Bree
    Funky Town, Texas
    I wanna do this to my truck. I like the auto on lights
  14. Jan 21, 2019 at 10:25 PM
    TXTundra2722
    2015 Black Tundra
    Anyone that has done this mod had any issues with it? I've read several posts from the higher end trucks having issues with their factory auto lights.
  15. Jan 21, 2019 at 10:26 PM
    TXTundra2722
    2015 Black Tundra
    I believe the turn signal stalk was possibly the issue, (I know this is what several of you bought to add the feature to your truck).
  16. Jun 5, 2021 at 6:32 PM
    infidel
    infidel New Member
    Jesse
    SE Wisconsin
    2016 Silver SR5 Crewmax
    Procomp 3/1 Method 307 18x9 +25 Falken Wildpeak AT3W 295/70r18
    I know this is an old post, but for those of you still wondering about this, it's worth every ounce of work. I just did it in my driveway, took me less than an hour. Follow the write up on tundra talk and go to town, take your time and enjoy. So satisfying to have auto lights.
    Wiesy442 and Ebrperk like this.
  17. Jan 19, 2022 at 2:04 PM
    Borgunit
    Borgunit New Member
    JR
    Ohio
    2013 Black Rock Warrior
    Did this to my 2013 Rock Warrior. Worked like a charm. My Rock Warrior was not pre-wired for this btw. If anyone interested, I have extra sensor, connector, and crimp on leads I can sell if interested. Just PM me.
    SORRY-SOLD
    texasrho83 likes this.
  18. Jan 20, 2022 at 9:02 AM
    TXTundra2722
    2015 Black Tundra
    So we would just need the turn signal stalk?
  19. Jan 20, 2022 at 3:40 PM
    Borgunit
    Borgunit New Member
    JR
    Ohio
    The stalk and a little bit of wire would be what is needed.
  20. Jan 20, 2022 at 3:59 PM
    toyofan87
    toyofan87 Beer thirty
    Seth
    Gettysburg, Penna
    Official welcome for your first post....
  21. Jan 20, 2022 at 6:24 PM
    Borgunit
    Borgunit New Member
    JR
    Ohio
    Thanks. Great group
  22. Feb 15, 2022 at 8:25 PM
    vipgs3
    vipgs3 New Member
    CA
    2015 Toyota Tundra 4x4
    I’ll be adding this mod to the truck. It’s a feature that I’ve had on previous vehicles that I’ve gotten used to.
  23. Apr 23, 2022 at 2:23 PM
    Wiesy442
    Wiesy442 New Member
    2016 Tundra SR5 Double Cab Red
    Auto headlight mod, seat covers, drop down rear seats mod, 2018+ LED Headlights, USA flag Tundra tailgate decal (many compliments on red Tundra), Alpine ILX-F509, front Focals, JL 10TW1-4s, Waxoyl undercoat, StartX remote start.
    So late to the party, but my '16 SR5 is new to me and I just did the mod. So easy and well instructed at Tundratalk. New grille, '18 LED headlights, Alpine ILX 507, Focals amps and subs, StartX remote start all to come. Love this forum and all that it offers! Thanks all.
  24. Oct 13, 2022 at 7:34 PM
    sinclairins1
    sinclairins1 New Member
    So even though your 2013 wasn’t prewired, you still followed the directions in the original post? I have a 2012 that I want to do it to? What did you have to do different on the instructions to fit our truck with no preside?
  25. Oct 13, 2022 at 9:40 PM
    BrandonL812
    BrandonL812 New Member
    Brandon
    2021 Tundra Platinum
    Another option is this.
    545T DEI Automatic Nite Lite automatic Headlight Parking Light Control System.
    I have it on our 2010 rav4. It’s nice. Never forget to turn on Headlights on/off again.
  26. Oct 14, 2022 at 5:31 AM
    sinclairins1
    Who actually done the install on toys module?
  27. Oct 14, 2022 at 5:40 AM
    Borgunit
    Borgunit New Member
    JR
    Ohio
    What you are basically doing is adding the sensor, running 3 wires to it, and then terminating those 3 wires into terminal block J3. Of course, you're adding the new stalk but no special new wiring for the stalk.
  28. Oct 14, 2022 at 5:50 AM
    sinclairins1
    Where did you obtain your terminal block J3?
  29. Oct 14, 2022 at 5:59 AM
    Borgunit
    Borgunit New Member
    JR
    Ohio
    Make sure you refer to the PDF instructions. The J3 terminal block is already mounted in vehicle underneath steering column. You will be pushing 3 terminals into the pin locations shown in the instructions.
