Auto lsd proper use
Discussion in '2.5 Gen Tundras (2014-2021)' started by ssls6, Nov 15, 2019.
  1. Nov 15, 2019 at 3:48 AM
    ssls6
    ssls6 [OP] Dr. Awesome
    Richard
    South Park, CO
    2020 TRD Pro CM
    Bakflip, Bedstep, Gulfstate stuff
    I have a question on the use of auto LSD (limited slip differential). I've watched a few youtube videos that basically say auto LSD is always active in 2WD and the auto LSD button simply turns off throttle management.
    The manual that came with my 2020 truck implies that auto LSD is ONLY active when you push the auto LSD button....
    from page 318:
    "The system can be used on 2WD models and in 2WD mode on 4WD models. The system is activated when driving at a speed under 62 mph (100 km/h). The AUTO LSD system will be activated with the following two procedures. Press the button briefly to turn on the system. The “AUTO LSD” indicator will come on."
    Does anyone know the truth on this?
  2. Nov 15, 2019 at 3:52 AM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    This, what your manual states, not what people state.
  3. Nov 15, 2019 at 4:04 AM
    Nm6300'asl
    Nm6300'asl New Member
    2022 DC SR5 4x4
    Oem tonneau, side steps, spray in liner. Trd skidplate.
    And to add to the above, auto lsd only works in 2wd, will not work when 4x4 is engaged (iirc).
    Wynnded likes this.
  4. Nov 15, 2019 at 4:12 AM
    ssls6
    Richard
    South Park, CO
    2020 TRD Pro CM
    So not so "auto" then.
  5. Nov 15, 2019 at 4:16 AM
    Uhhhh....
    Uhhhh.... New Member
    Dave
    2016 Silver Limited DC
    7” BDS, 37s
    Lol
  6. Nov 15, 2019 at 4:16 AM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    It has to be turned on.... Like your automatic transmission, you have to be operating the vehicle (on) for it to work. "Auto" in that same sense.
  7. Nov 15, 2019 at 8:13 AM
    panicman
    panicman Everyone remain calm.
    Eric
    2018 SR5 CM TRDoffroad MGM
    I’ll hop in with some possibly dumb questions. -When would one want to use this?
    -Why not just use 4 High if one was concerned about losing traction?
    - does the speed cap of 62 suggest it is not intended to be used on freeways and many highways?
  8. Nov 15, 2019 at 8:16 AM
    CCLJ03
    CCLJ03 Tundra forever
    Craig
    2018 TRD Off-Road - Cement
    How do I get my back tires to lose traction? LSD light on or off?
    I’ve tried hard to drift in the snow this year and I can figure out how to turn off the nannies.
  9. Nov 15, 2019 at 8:19 AM
    Scuba
    Scuba Sober member
    Austin, Tx.
    2012 Texas Edition CM.
    Press and hold the Trac off button for 3-5 seconds. You'll see LSD on and VSC light light up. Then press and hold trac off for another 3-4 seconds. The Auto LSD light will turn off and the VSC and TRAC lights will both light up. Then you have no nannies.
    Tundra family and CCLJ03[QUOTED] like this.
  10. Nov 15, 2019 at 8:19 AM
    TRDFerguson
    Jake
    Southeast Greater Basin, AZ
    2018 MGM CrüeMax
    You could turn on tow/haul-ass mode and prepare to pucker your butthole... :burnrubber:
    3 second press on Auto LSD, followed by another 3 second press on Auto LSD, then short press on Tow/Haul.
    Tundyfundy likes this.
  11. Nov 15, 2019 at 8:23 AM
    CCLJ03
    Craig
    My sphincter is ready.
  12. Mar 29, 2025 at 1:29 PM
    Marvthehamster
    Marvthehamster New Member
    CO
    2018 CM
    ADS/Deaver, Method's, 35's, RCI sliders
    By “turning off the Nannie’s” what is really being achieved?
    Are 2nd gen’s an open diff or does it actually have an lsd?
  13. Mar 29, 2025 at 1:48 PM
    HulkSmurf14
    2014 Tundra Limited
    Tastefully enhanced...
    No traction control so you can one wheel peel...Not a "real" LSD, but an electronic "try" at one...
  14. Mar 29, 2025 at 1:52 PM
    Tundra family
    Tundra family New Member
    limited slip but it uses TCS (brake applications) to control wheel spin.
    At least that is my understanding, I'm probably wrong on this. When I romp the rowdy pedal it spins the passenger in a straight line, but it will send power to the wheel that grips and apply brake on the wheel that slips if I'm power sliding in the rain. Learned the quick way that this thing will cook rear brake pads if you drive it too hard.
