Auto LSD malfuntion
Discussion in '2.5 Gen TRD Pro (2014-2021)' started by sleepydoc, Jun 10, 2023.
  1. Jun 10, 2023 at 6:21 AM
    sleepydoc
    sleepydoc [OP] New Member
    2016 TRD Pro Crew Max
    I'm hoping someone can answer this because the dealership is of no help because no code was created when this happened.
    I was starting my drive to work on a level road with no water or obstacles, and the LSD engaged as if I was on a slippery surface. The truck acted like I was losing control, and I essentially lost the ability to drive over 10 mph for a second. It disengaged, and I was able to drive normally. I turned off Auto LSD, but it reengaged a mile later under the same conditions. After turning the truck off and back on again, it did not reoccur for the rest of my drive.
  2. Jun 10, 2023 at 12:27 PM
    Tripleconpanna
    2021 TRD PRO CM; 2008 SR5 CM
    Weird experience...
    One thing a lot of us do if we experience what seems to be an electrical glitch is to disconnect the negative battery terminal for a least 10 minutes and then re-connect. It supposedly resets some of the ECU BS (kinda) like re-booting your phone or computer. If it happens again, you may want to give that a try.
    Also, take a quick photo of your dash lights that are firing off (if you can safely do so) to post w/your follow up... Just helps us make sure we're all on the same page when trying to help out :thumbsup:
    Hopefully, it was just a one time problem; and welcome to the forum!!!
  3. Jun 10, 2023 at 12:35 PM
    SwitchThrottle
    SwitchThrottle Living in Idiocracy
    2021 Barcelona CrewMax
    Wheel speed sensor damaged?
  4. Jun 10, 2023 at 12:43 PM
    Winning8
    Winning8 New Member
    Da Bay Area
    2019 MGM DC 4x4 SR5
    Probably some metal shaving on wheel speed sensors, get some brake cleaner and clean it.
  5. Jun 10, 2023 at 1:00 PM
    sleepydoc
    Thanks everyone! I will do the battery trick and work on the wheel speed sensors. I'm still baffled by the dealership just shrugging it off and not even trying to diagnose it, but I knew I could find help here. Will follow up if anything develops
