Auto LSD & ATRAC LS Additive?
Discussion in '2.5 Gen Tundras (2014-2021)' started by SRM18TRD, Feb 8, 2019.
  1. Feb 8, 2019 at 1:01 PM
    SRM18TRD
    SRM18TRD [OP] New Member
    18 TundraTRDOR
    Stock
    I’ve gone down the “which gear oil” rabbit hole. I have learned a lot. I have an 18 Tundra TRD-OR and a 15 4RUNNER 4x4. I know I have open diff’s, but does AUTO LSD or ATRAC require a limited slip additive? I want to use Mobil Delvac 1 75w90. It does not contain any friction modifiers. I did bend over and buy the liquid gold Toyota 75w LF for the transfer case. Any insight to further my education is appreciated!
  2. Feb 8, 2019 at 1:21 PM
    Nm6300'asl
    Nm6300'asl New Member
    2022 DC SR5 4x4
    Oem tonneau, side steps, spray in liner. Trd skidplate.
    Auto lsd simply uses the abs function, I am only 2 wheel drive but believe the atrac functions in the same way. No friction modifier needed.
  3. Feb 8, 2019 at 6:39 PM
    PA452
    PA452 New Member
    2021 Tundra SR5 CM TRD O/R
    As said it's not a mechanical LSD, it will just use brakes to slow a spinning wheel. No need for friction modifier additives.
    RitcheyRch likes this.
